armbian-config
- wireless network connect,
- AP (hotspot) in bridged or NAT mode,
- freeze and unfreeze kernel and BSP upgrades,
- edit boot environment, network, FEX, welcome screen items,
- switching between available kernels and nightly builds,
- enabling read only root filesystem (Ubuntu only),
- set display resolution (H3 boards with legacy kernel),
softy
- TV headend (IPTV server)
- Syncthing (personal cloud)
- SoftEther VPN server (VPN server)
- Transmission (torrent server)
- ISPConfig (WEB & MAIL server)
- Openmediavault NAS (NAS server)
- PI hole (ad blocker)
- MiniDLNA (media sharing)
Welcome to submit / push your modifications if you think they are interesting for general public.
also another thing that i find better is Syncthing rather then Bittorrent Sync since BT got greedy been messing around with it and its really easy and faster then BT Sync with more options for Backups
I agree. I also dumped BTSync from usage some time ago but haven't adjust the build script yet. Currently I am developing the backup / restore part which hanged somewhere in the middle.
All general services are open / free to change. I don't prefer any - it must work / suit the purpose.  :)
Posted (edited)
Igor first of all thank you for your work and for allowing us we can use it.
Sorry to use google translator.
I am a total and complete novice, but I can follow directions.
I'm trying to setup SAMBA so as to share folders with other devices in my home.
I'm using the img I downloaded from your site:
Bananapi_Debian_3.0_wheezy_3.4.107
And I'm using your scrip Micro Home Server
I connected a hard disk formatted in NTFS to BPI and is configured to mount on startup within this folder /media/HDD1 (from the console I can see and enter the disk).
My fstab looks like this:
/dev/sda1 /media/HDD1 ntfs-3g defaults, locale = es_AR.UTF-8 0 0
Within the smb.conf file parameters copied to the folder /ext shared but changing routes to the folder riding my record.
 [HDD1]
        comment = HDD1
        patch = /media/HDD1
        writable = yes
        public = yes
        valid users = banana
        force create mode = 0777
        force directory mode = 0777
Both Windows and android I can see the folder /ext, but since neither OS I can see my hard drive
Any hints of what can I be doing wrong?
Thanks in advance
EDIT:
Some progress I've made:
no matter where I create a folder, smb.conf does not recognize or show that shared folder.
But if I edit the first block that comes after the settings for sharing printers recognize any folder you configure it. It is as if he had a cap of lines that can be read EJ:
In this case it recognizes and shares the folder / ext but does not recognize or share /HDD1
[Ext]
        comment = Storage
        patch = /ext
        writable = yes
        public = no
[HDD1]
        comment = HDD1
        patch = /media/HDD1
        writable = yes
        public = no
In this case it recognizes and shares the folder / HDD1 but does not recognize or shared / ext
[HDD1]
        comment = HDD1
        patch = /media/HDD1
        writable = yes
        public = no
[ext]
         comment = Storage
         patch = /ext
         writable = yes
         public = no
In this case if I mention the first block does not recognize or share anything:
# [ext]
# Comment = Storage
# Patch = /ext
# Writable = yes
# Public = no
# Valid users = banana
# Force create mode = 0777
# Force directory mode = 0777
[HDD1]
         comment = HDD1
         patch = /media/HDD1
         writable = yes
         public = no
Edited by enredar
You are typing patch instead of path. This works for me
[TV] #This is the name of the share it will show up as when you browse
comment = TV Folder
path = /mnt/usbstorage/TV
create mask = 0755
directory mask = 0755
read only = no
browseable = yes
public = yes
force user = pi
#force user = root
only guest = no
I have forked your repo to add a lot of media server stuff, I added syncthing too with the code below
install_syncthing () {
# Install syncthing
SYNCTHINGUSER=$(whiptail --inputbox "Enter the user to run Syncthing as (usually pi)" 8 78 $SYNCTHINGUSER --title "$SECTION" 3>&1 1>&2 2>&3)
exitstatus=$?; if [ $exitstatus = 1 ]; then exit 1; fi
if ! getent passwd $SYNCTHINGUSER > /dev/null; then
echo "User $SYNCTHINGUSER doesn't exist, exiting, restart the installer"
exit
fi
if !(cat /etc/apt/sources.list.d/syncthing-release.list | grep -q Syncthing > /dev/null);then
cat >> /etc/apt/sources.list.d/syncthing-release.list <<EOF
# Syncthing
deb http://apt.syncthing.net/ syncthing release
EOF
wget -O - https://syncthing.net/release-key.txt | apt-key add -
debconf-apt-progress -- apt-get update
debconf-apt-progress -- apt-get install syncthing -y
sudo -u $SYNCTHINGUSER timeout 120s syncthing
#Make syncthing webui remotely accessible
sed -i "/ <address>127.0.0.1:8384/c\ \<address>0.0.0.0:8384\<\/address\>" /home/$SYNCTHINGUSER/.config/syncthing/config.xml
cd /etc/init.d/
wget https://raw.github.com/blindpet/MediaServerInstaller/usenet/scripts/syncthing
sed -i "/DAEMON_USER=root/c\DAEMON_USER=$SYNCTHINGUSER" /etc/init.d/syncthing
chmod +x /etc/init.d/syncthing
cd /tmp
update-rc.d syncthing defaults
service syncthing start
echo Syncthing is running on $showip:8384
fi
I also changed btsync so it uses a repo and makes it much easier
cd /tmp
wget http://debian.yeasoft.net/add-btsync-repository.sh
( echo yes && \
echo yes ) \
| sh add-btsync-repository.sh
apt-get update
apt-get install btsync -y
I haven't ever made a pull request but will try sometime next month
I have installed Samba, CUPS and RPiMonitor, but I wanted to install mysql as well, so I git-cloned again and marked just the mysql option during installation.
But I am getting this error after marking "apache" in webserver config:
./Debian-micro-home-server/install.sh: line 99: install_Apache: command not found
./Debian-micro-home-server/install.sh: line 101: create_ispconfig_configuration: command not found
./Debian-micro-home-server/install.sh: line 102: install_PureFTPD: command not found
./Debian-micro-home-server/install.sh: line 102: install_Fail2BanDovecot: command not found
./Debian-micro-home-server/install.sh: line 102: install_Fail2BanRulesDovecot: command not found
./Debian-micro-home-server/install.sh: line 102: install_ISPConfig: command not found
Any ideas why? I have redownloaded the whole thing again, so I am sure it is complete.
Mysql is a part of the whole package and can't be installed this way.
You can issue a simple command to install it:
apt-get intall mysql-server
If this is what you need.
root@homeserver:~# cd ./Debian-micro-home-server
root@homeserver:~/Debian-micro-home-server# sudo ./install.sh
sudo: unable to stat /etc/sudoers: Permission denied
sudo: no valid sudoers sources found, quitting
sudo: unable to initialize policy plugin
try:
chown root:root /etc/sudoers
sudo chown root:root /etc/sudoers.d
sudo chmod 755 /etc/sudoers.d
does not work
If you are running as root, you can left out "sudo" otherwise install sudu and add your user to sudoers.
Configuring phpmyadmin +-------------------------¬
 Â¦        ¦
 Â¦ An error occurred while installing the database:                          Â¦
 Â¦        ¦
 Â¦ ERROR 2002 (HY000): Can't connect to local MySQL server through socket    Â¦
 Â¦ '/var/run/mysqld/mysqld.sock' (2)                                         ¦
 Â¦        ¦
 Â¦ If at this point you choose "retry", you will be prompted with all the    Â¦
 Â¦ configuration questions once more and another attempt will be made at     ¦
 Â¦ performing the operation. "retry (skip questions)" will immediately       ¦
 Â¦ attempt the operation again, skipping all questions. If you choose        Â¦
 Â¦ "abort", the operation will fail and you will need to downgrade,          Â¦
 Â¦ reinstall, reconfigure this package, or otherwise manually intervene to   ¦
 Â¦ continue using it. If you choose "ignore", the operation will continue,   ¦
 Â¦ ignoring further errors from dbconfig-common.
 Unable to set password for the MySQL "root" user                          â”‚
 â”‚        │
 â”‚ An error occurred while setting the password for the MySQL                â”‚
 â”‚ administrative user. This may have happened because the account already   │
 â”‚ has a password, or because of a communication problem with the MySQL      â”‚
 â”‚ server.        │
 â”‚        │
 â”‚ You should check the account's password after the package installation.   │
 â”‚        │
 â”‚ Please read the /usr/share/doc/mysql-server-5.5/README.Debian file for    â”‚
 â”‚ more information.
These are errors when attempting to perform
sudo apt-get -y install git
cd
git clone https://github.com/igorpecovnik/Debian-micro-home-server
chmod +x ./Debian-micro-home-server/install.sh
cd
sudo
./install.sh
not available mysql-server :(
Stopping MySQL database server: mysqld.
150911 23:00:30 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
150911 23:00:30 [Note] /usr/sbin/mysqld (mysqld 5.5.44-0+deb7u1) starting as process 9717 ...
150911 23:00:30 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
150911 23:00:30 [Note] Plugin 'FEDERATED' is disabled.
150911 23:00:30 InnoDB: The InnoDB memory heap is disabled
150911 23:00:30 InnoDB: Mutexes and rw_locks use GCC atomic builtins
150911 23:00:30 InnoDB: Compressed tables use zlib 1.2.7
150911 23:00:30 InnoDB: Using Linux native AIO
/usr/sbin/mysqld: Can't create/write to file '/tmp/ibD31lDv' (Errcode: 13)
150911 23:00:30  InnoDB: Error: unable to create temporary file; errno: 13
150911 23:00:30 [ERROR] Plugin 'InnoDB' init function returned error.
150911 23:00:30 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
150911 23:00:30 [ERROR] Unknown/unsupported storage engine: InnoDB
150911 23:00:30 [ERROR] Aborting
150911 23:00:30 [Note] /usr/sbin/mysqld: Shutdown complete
I tried last week on Jessie. Tested just now on Wheezy. In both cases full install with samba, tvheadend and ispconfig.
Working without a problem!
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 44
Server version: 5.5.44-0+deb7u1 (Debian)
Copyright (c) 2000, 2015, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql>
Can u elaborate what are you doing? Which steps are you taking that you fail?
On just installed system I start a script:
cd ~
sudo ./install.shEverything works without problems to a stage of request of the password of root mysgl.
I import any passwords: both simple and difficult.
There are mistakes:
│ An error occurred while setting the password for the MySQL
 â”‚ server.
 â”‚
 â”‚
Unable to connect to the specified MySQL server Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
And so around. Mysql asks the password, I import and again these mistakes. On all kernels.
Before such wasn't. I don't know why. I tried early assemblies, the same situation.
Can do it it is connected with that that at me costs SSD? and there remains of unsuccessful transfer of system?
But do you input any password or you leave blank? I always use a password. Maybe you use too short or invalid. I don't know exactly what is allowed by mysql. Script just read a password and pass it to mysql install program.
It should not be connected to SATA / SSD / NAND install.
apt-get update
prior to starting is good thing but not necessary.
Script is working properly only on a clean system. If you break and start over it might fail.
It's not that bullet proof.
I found the reason why so occurs: if to establish only the last point in a script (ISPconfig) that everything perfectly works. If to select one more item of the menu: transmission and VPNserver that Mysql won't be established and if it worked earlier that will cease to work.
I for the present didn't find out precisely what point of the menu in a script breaks work of Mysql
I guess VPN server must be the problem since I was testing without, but installing Transmission and TVheadend.
Thanks for this info. It will save time for others and I'll fix this somehow.
Maybe it's time that we do some updates to the script.  :P
You can include minidlna, a media server software fully compliant with DLNA/UPnP-AV clients.
I use it to watch my downloaded films on my smart tv.
sudo apt-get install minidlna
The version in the repo (even jessie) is a year old. Build miniDLNA from source in case you get any problems with the old version.
