larva Posted May 31, 2015 Share Posted May 31, 2015 Hi! I'm trying to use the image Cubietruck_Debian_3.8_jessie_4.0.4.raw with my CubieTruck, but run into problems when trying to use an external LUKS-disk which is encrypted using aes-xts-plain64. 'cryptsetup luksOpen' informs the following: device-mapper: reload ioctl on failed: No such file or directory Failed to setup dm-crypt key mapping for device /dev/disk/by-uuid/<xxxx>. Check that kernel supports aes-xts-plain64 cipher (check syslog for more info). 'cat /proc/crypto | grep name' lists only this, which seems kinda minimal: name : stdrng name : stdrng name : crc32c name : deflate name : ecb(arc4) name : arc4 name : aes name : des3_ede name : des name : sha224 name : sha256 name : sha1 name : md5 name : md4 Directory /lib/modules/4.0.4-cubietruck/kernel/crypto/ has these files: af_alg.ko algif_rng.ko async_tx ccm.ko crypto_null.ko ctr.ko fcrypt.ko gcm.ko gf128mul.ko ghash-generic.ko pcbc.ko seqiv.ko So, it seems that some crypto modules for the kernel are missing, but I don't know which ones are needed ('aes-xts' or similar, at least, maybe?). Any ideas on what to do? Do I need to compile the kernel to include the modules? Does the older 3.4.x(?) kernel have these included? Thanks. Link to comment Share on other sites More sharing options...
Igor Posted June 1, 2015 Share Posted June 1, 2015 New kernel config: https://github.com/igorpecovnik/lib/blob/next/config/linux-sunxi-next.config CONFIG_DM_CRYPT=m This is enabled as module. I also don't know what exactly is needed without research and can only add blindly some new modules in this area but it will take some time before I rebuild a kernel. In such cases is better and faster if you try to build a kernel by your own. That's why I made a script When compiling remember to save the .config because it's overwritten on each run. Old kernel config: https://github.com/igorpecovnik/lib/blob/next/config/linux-sunxi.config Don't know. Simply try it and than we have at least something to compare to. Link to comment Share on other sites More sharing options...
