Recommendations for an Arm Development platform.
Hi,
I've been looking around for an Arm development platform. Banana Pi seems to be about the best value for money. I've been looking around at some TV boxes. However, I see mixed opinions about these being a option. SBCs seem to be almost twice the price of similar spec Arm TV box. Processing power and memory are mostly my priorities. Anything over 4GB seems insanely expensive.
I can do SMD soldering work. So modding at TV box is an option.
Are there any options for an 8gb Octa core system that isn't going to cost more than a decent PC?
Have a look at the FriendlyElec NanoPi R6C or other boards using the Rockchip RK3588 if you want an 8-core CPU and 8GB of RAM. It's priced roughly the same as an Intel N100 Mini-PC.
If you're a dev, I wouldn't restrict myself to boards with standard support only, since many great boards are community supported. If you stumble over any problem with the board that is Armbian-related, you can also contribute to the code 😄
