uriukti Posted April 15, 2017 Posted April 15, 2017 Dear colleagues, good afternoon. I have 3 problems with the display. I have a orange pi zero. Installed armbian. I set the 2.8-inch display ili9341 spi for instructions, all works very well, but ... expansion of the display - 320x240. But the system is set up as 640x480. Font on the console - Terminus framebufer 6x12. And I am looking for a smaller. Help me please. I want to make the setting expand in the system - 320x240. Font still less. And it passes the wrong color, and I want to make the right color.
uriukti Posted April 15, 2017 Author Posted April 15, 2017 I'm a musician and I love sound. I was always interested in linux and I wanted to learn it. But I could not sit down at the computer. And now my dream to learn it can come true. I want to build myself the smallest, real pocket linux computer with a console. I do not need a GUI. I want to learn linux, its commands, bash, console programs and write it on this computer. And also record a sound with it. I do not know linux well today, but I can adjust everything according to the instructions. So then here to study linux. )
zpimp Posted April 15, 2017 Posted April 15, 2017 good luck, im on linux completely for couple of years, its not been easy but i have adapted my needs to the universal operating system i myself ordered an orange pi for the portability if you want to learn linux, i think it would be more convenient to just use a bootable usb flash drive and x86 pc's (laptop/desktop with intel/amd) the main reason being that x86 architecture is better supported, and with the right distro, you can just boot up the usb on any pc, and have drivers for any device on x86 there are livecd-isos (wich you can boot without installing, even from usb), dont know if theyre available for arm architecture but progress is made on arm too, and hopefully soon, it gets the same support as x86 but the most important advice is to keep searching, keep asking, and never give up its not hard to learn, you just need to know where to ask 1
uriukti Posted April 15, 2017 Author Posted April 15, 2017 I can agree. But now I have already chosen my device and now I want to finish the job and set it up.
uriukti Posted April 17, 2017 Author Posted April 17, 2017 Help me, please. Other people will find this manual too. And they will been happy. )
gnasch Posted April 17, 2017 Posted April 17, 2017 Hi did you check this thread? https://forum.armbian.com/index.php?/topic/1080-tiny-3-lcd-on-orange-pi/#comment-29367 best, gnasch
uriukti Posted April 17, 2017 Author Posted April 17, 2017 Yes, my display work very good. But it has very big size in system. It is 640x480 in system. But my display is 320x240. I must change this size to 320x240 in system. For my display. And i want change size of text from 6x12 to 6x8 or 6x6 if this posible.
uriukti Posted April 24, 2017 Author Posted April 24, 2017 Hey. Now I know how to fix the color to the right one. At the end of the display initialization line, enter bgr = 1. But the remaining questions are urgent. I need your help!!!
tao Posted April 24, 2017 Posted April 24, 2017 Are you running the graphical windows environment (X windows) on this display and you need to customize it to make it usable, or are you using the display as a text console and you'd like to get more text on the screen? 1
nopnop2002 Posted April 25, 2017 Posted April 25, 2017 On 2017/4/18 at 1:15 AM, uriukti said: Yes, my display work very good. But it has very big size in system. It is 640x480 in system. But my display is 320x240. I must change this size to 320x240 in system. For my display. And i want change size of text from 6x12 to 6x8 or 6x6 if this posible. please show us your config file. My wiring TFT OPi(Pin#) -------------------- MISO N/C LED 3.3V SCK SCLK(23) MOSI MOSI(19) D/C GPIO12(03) RES GPIO11(05) CS CS0(24) GND GND VCC 3.3V My config orangepi@orangepipc:~$ cat /etc/modules-load.d/fbtft.conf flexfb fbtft_device orangepi@orangepipc:~$ cat /etc/modprobe.d/fbtft.conf options flexfb width=320 height=240 buswidth=8 init=\ -1,0x28,-2,20,-1,0xCF,0x00,0x83,0x30,-1,0xED,0x64,0x03,0x12,0x81,-1,0xE8,0x85,0x01,0x79,\ -1,0xCB,0x39,0x2c,0x00,0x34,0x02,-1,0xF7,0x20,-1,0xEA,0x00,0x00,-1,0xC0,0x26,-1,0xC1,0x11,\ -1,0xC5,0x35,0x3E,-1,0xC7,0xBE,-1,0xB1,0x00,0x1B,-1,0xB6,0x0a,0x82,0x27,0x00,-1,0xB7,0x07,\ -1,0x3A,0x55,-1,0x36,0x38,-1,0x11,-2,120,-1,0x29,-2,20,-3 options fbtft_device name=flexfb gpios=dc:12,reset:11 speed=1600000 1
uriukti Posted April 28, 2017 Author Posted April 28, 2017 Sorry, I disappeared. My wiring. TFT OPIZERO ------------------- SCLK (SCK) - 23 MOSI (SDA) - 19 MISO - 21 CS - 24 DC (AO) - 13 RST - 11 VCC - 4 GND - 25 LED - 15 My config. in /etc/modules-load.d/fbtft.conf fbtft_device in /etc/modprobe.d/fbtft.conf options fbtft_device custom name=fb_ili9341 gpios=reset:1,dc:0,led:3 speed=48000000 fps=25 rotate=90 busnum=1 bgr=1 txbuflen=65536 I was able to fix the color and install my small font. But I still could not explain to the system that my screen is less than 640x480. Opened mc. 9 menu items out of 10 are open at the bottom.
nopnop2002 Posted April 28, 2017 Posted April 28, 2017 17 hours ago, uriukti said: I was able to fix the color and install my small font. But I still could not explain to the system that my screen is less than 640x480. Opened mc. 9 menu items out of 10 are open at the bottom MC adjusts the menu indication automatically. This is MC side issue.
uriukti Posted April 29, 2017 Author Posted April 29, 2017 This means that if I configure the output to the 320x240 screen inside the system, mc and other similar programs will not fit their borders into 320x240 frames? Will they be cut back?
nopnop2002 Posted April 30, 2017 Posted April 30, 2017 On 2017/4/29 at 1:31 PM, uriukti said: This means that if I configure the output to the 320x240 screen inside the system, mc and other similar programs will not fit their borders into 320x240 frames? Will they be cut back? I think so.
uriukti Posted April 30, 2017 Author Posted April 30, 2017 Hmm. Good. But how can I see what's left behind the screen? Or is it impossible? Do I need to make another permission for the console then?
radiomanoff Posted May 14, 2018 Posted May 14, 2018 (edited) I also encountered this problem. When the con2fbmap 1 8 console is loaded, the size corresponds to 320x240, but when the X server (startx) is loaded, the size does not match github.com Edited May 14, 2018 by radiomanoff
MichaelEliP Posted May 10, 2019 Posted May 10, 2019 Hi everyone. I have a problem that maybe you can help me with. I have a 3.5 LCD --- https://www.amazon.com/gp/product/B01IGBDT02/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 an Orange Pi Zero running ARMBIAN 5.59 testing Ubuntu 16.04.5 LTS 3.4.113-sun8i Ive tried so many different options to get my lcd working. The last steps i took were the following 1.Make SD card with ARMBIAN 5.59 testing Ubuntu 16.04.5 LTS 3.4.113-sun8i 2. set up new password and reboot. 3.Edit files /boot/armbianEnv.txt overlays=spi-spidev spi-add-cs1 param_spidev_spi_bus=1 param_spidev_spi_cs=1 /etc/modules-load.d/fbtft.conf fbtft fbtft_device /etc/modprobe.d/fbtft.conf options fbtft_device rotate=90 name=piscreen speed=16000000 busnum=1 gpios=reset:2,dc:18 txbuflen=32768 fps=25 4.Reboot 5. apt-get upgrade. the gpios are wired the according to the pinout from the lcd I got from the link. Still I just have a blank screen. Ive spent 3 days trying different linux versions and different methods. Can any one help me figure this out. I would truly appreciate. Thank you
Igor Posted May 11, 2019 Posted May 11, 2019 14 hours ago, MichaelEliP said: overlays Works only with modern kernel, not in 3.4.y ...
MichaelEliP Posted May 13, 2019 Posted May 13, 2019 Just wanted to give you an update. Thank you Igor. That solved the issue for the LCD to display. I did everything i said in my first message but I changed the Armbian to this version Armbian Bionic mainline based kernel 4.19.y. It worked like a charm. Now I just need to see if my touchscreen is working. Thanks again!!
