Wilson Wilson Posted June 1, 2024 Posted June 1, 2024 (edited) Hello, Installed some updates recently on OrangePi PC Plus and after reboot I'm stuck on boot screen with message "Starting kernel...". Would this be logged somewhere? Any way to recover from this or should I start from scratch? boot error Edited June 1, 2024 by Wilson Wilson Title edited 0 Quote
mikhailai Posted June 4, 2024 Posted June 4, 2024 I have a similar issue on "Banana PI M1", so I can provide more details. Basically, what I've found out is the linux kernel contained in the latest "linux-image-legacy-sunxi" (version 24.5.1) package appears to broken to the point of locking-up right from the start. It prints "Starting kernel...", and no more messages appear even with "verbosity=6" setting in the "armbianEnv.txt". * "linux-image-current-sunxi" version 24.5.1 with 6.6.31 kernel: boots fine. * "linux-image-legacy-sunxi" version 24.2.1 with "6.1.77" kernel: boots fine. * "linux-image-legacy-sunxi" version 24.5.1 with "6.1.92" kernel: broken as described above. In the "boots fine" cases, the kernel prints multiple other messages, before starting the OS boot. Here are the steps to reproduce. I've done it for "Banana PI M1", but I think any board with Allwinner "Cortex-A7"-based SOC should work. 1. Download and write the Armbian image to a MicroSD card. 2. Connect the serial console, boot the board, finish setup, do all the upgrades: assume everything works fine at this point. Double-check that "linux-image-current-sunxi" is what's being used. 3. Set "verbosity=6" in the "armbianEnv.txt", reboot and observe the kernel messages. 4. Install "armbian-config" and use it to switch to the legacy kernel. After step (4) reboots, observe the boot process gets stuck at "Starting kernel..." message. What I'm guessing could've happened is something went wrong during the build process for that specific target (e.g. data corruption, wrong architecture being used). 0 Quote
Werner Posted June 4, 2024 Posted June 4, 2024 5 hours ago, mikhailai said: verbosity=6 Should be 7 0 Quote
mikhailai Posted June 4, 2024 Posted June 4, 2024 Tried the verbosity=7, the same effect. With 6.1.77 kernel: Working FDT set to 49630000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 6.1.77-legacy-sunxi (armbian@next) (arm-linux-gnueabihf-gcc (Ubuntu 11.4.0-1ubuntu1~ 22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Fri Feb 23 08:12:53 UTC 2024 [ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: LeMaker Banana Pi ...... With 6.1.92 kernel from "linux-image-legacy-sunxi" version 24.5.1 Working FDT set to 49630000 Starting kernel ... I tried the Device Trees from both "linux-dtb-legacy-sunxi" and "linux-dtb-current-sunxi": makes no difference. This again points to the "linux-image-legacy-sunxi" version 24.5.1 being broken. I wonder if someone with more authority can try running the kernel from that package on any Allwinner A20 board, or any Allwinner H3 Board (e.g. Orange Pi One, Orange Pi PC Plus), and confirm or disprove my claim. 0 Quote
TRay Posted June 5, 2024 Posted June 5, 2024 I can add that Orange Pi Zero 3 users have similar problems, i.e. after turning on the power or, for example, after reboot. This is not a cyclical phenomenon. So when it happens that you need to reboot remotely, it may turn out that Orange Pi Zero 3 requires physical intervention by turning the power on and off. 0 Quote
Aleksey Vasenev Posted June 29, 2024 Posted June 29, 2024 (edited) On 6/4/2024 at 8:18 PM, mikhailai said: I wonder if someone with more authority can try running the kernel from that package on any Allwinner A20 board, or any Allwinner H3 Board (e.g. Orange Pi One, Orange Pi PC Plus), and confirm or disprove my claim. Same problem on Orange Pi Zero: 6.1.53 work 6.6.31 work 6.1.92 stuck on "Starting kernel..." Edited June 29, 2024 by Aleksey Vasenev 0 Quote
Aleksey Vasenev Posted June 29, 2024 Posted June 29, 2024 From latest sources also not work Armbian-unofficial_24.8.0-trunk_Orangepizero_bookworm_legacy_6.1.96_minimal.img May be size problem? 6.1.92 size more than 8MiB. Older kernel size less than 8MiB. But this does not explain why 6.6 and 6.7 work despite the larger size. 0 Quote
going Posted June 30, 2024 Posted June 30, 2024 There have been changes in the 6.1.78 kernel that negatively affect arm (Cortex-A7). Try not to use kernels more than 6.1.78. I hope this will be fixed soon. 0 Quote
Aleksey Vasenev Posted June 30, 2024 Posted June 30, 2024 6.1.77 good 6.1.87 good 6.1.88 bad 6.1.89 bad 6.1.90 bad 6.1.92 bad 6.1.96 bad 0 Quote
going Posted June 30, 2024 Posted June 30, 2024 55 минут назад, Aleksey Vasenev сказал: 6.1.88 bad Alexey, will you be able to publish the console boot log with the debug message parameter 7? 0 Quote
TRay Posted July 4, 2024 Posted July 4, 2024 My friend who had problems with OZPI v3 did not start after reboot, and sometimes after turning on the power, he had to turn the power on again for the system to start. Run armbian-config and select SYSTEM -> INSTALL from the menu and then select option 5 "Install/update the bootloader on SD/eMMC" Since then, there have been no problems with the computer not starting from time to time after reboot or after turning on the power It looks like updating the bootloader helped ? 0 Quote
Aleksey Vasenev Posted July 7, 2024 Posted July 7, 2024 (edited) On 6/30/2024 at 2:43 PM, going said: Alexey, will you be able to publish the console boot log with the debug message parameter 7? armbianEnv.txt: verbosity=7 1.log Edited July 7, 2024 by Aleksey Vasenev 1 Quote
going Posted July 8, 2024 Posted July 8, 2024 @Aleksey Vasenev The problem will be solved with this PR: # 6893 0 Quote
Aleksey Vasenev Posted July 8, 2024 Posted July 8, 2024 2 hours ago, going said: @Aleksey Vasenev The problem will be solved with this PR: # 6893 Same problem on my another board in latest build, sometime boot (30%), sometime not (70%): Armbian_community_24.8.0-trunk.314_Orangepi3-lts_bookworm_current_6.6.36_minimal.img.xz 0 Quote
going Posted July 8, 2024 Posted July 8, 2024 1 час назад, Aleksey Vasenev сказал: Orangepi3-lts You shouldn't expect help from me for this device. 0 Quote
