chbram Posted April 20, 2017 Posted April 20, 2017 Hi all, I am running a lime2 board with trusty as a server. Now I wanted to upgrade to xenial and used the standard Ubuntu way using "do-release-upgrade". Since that failed and resulted in a not booting image I was now wondering if this is the right approach for armbian as well. I was searching the docs but couldn't find what I was looking for. Thanks Chris
Igor Posted April 20, 2017 Posted April 20, 2017 It should work also on Armbian, in theory, but such upgrade is always critical. There are many things, which could and go wrong ... if you provide some logs, we could at least learn something.
chbram Posted April 23, 2017 Author Posted April 23, 2017 Took me a while to rerun. It looks like the error is around systemd. The screenlog.0 file shows: Quote Initializing machine ID from D-Bus machine ID. Adding group `systemd-journal' (GID 112) ... Done. Your account has expired; please contact your system administrator chfn: PAM: Authentication failure adduser: `/usr/bin/chfn -f systemd Time Synchronization systemd-timesync' returned error code 1. Exiting. dpkg: error processing package systemd (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: systemd Error in function: A fatal error occurred And the main.log has those entries: Quote 2017-04-22 20:16:16,678 ERROR got an error from dpkg for pkg: 'systemd': 'subprocess installed post-installation script returned error exit status 1' 2017-04-22 20:16:16,681 DEBUG running apport_pkgfailure() systemd: subprocess installed post-installation script returned error exit status 1 2017-04-22 20:16:20,496 ERROR not handled exception: SystemError: E:Sub-process /usr/bin/dpkg returned an error code (1) 2017-04-22 20:16:20,498 DEBUG running apport_crash() 2017-04-22 20:16:20,507 ERROR failed to import apport python module, can't generate crash: No module named 'apport_python_hook' 2017-04-22 20:16:20,509 DEBUG can't find apport 2017-04-22 20:16:21,007 ERROR SystemError from cache.commit(): installArchives() failed 2017-04-22 20:16:21,008 DEBUG can't find apport 2017-04-22 20:39:03,535 DEBUG Running PostInstallScript: './xorg_fix_proprietary.py'
