Igor P. please help me what to do and what is missing?
Step0.(run) ./compile.sh
Step1. Choose a board (cubietrack)
Step2. Choose a distribution (trusty)
Step3. Install desktop with HW accel… (No)
Step4. Choose a branch (default)
And I get the message in console error:
[ o.k. ] Dependencies check [ @host ]
[ o.k. ] Building [ Armbian 4.6 Cubietrack Ubuntu trusty default ]
[ error ] Installation of package failed
The core is not collected :(
how to fix the situation???
And another question:
Why different values have BogoMIPS on Cubieboard (proc/cpuinfo) in distributions  desktop (956.10) and CLI (27.14)? :o
Cubie operates in CLI mode on a lot slower?
This is because HW acceleration use on desktop mode?
And how to enable HW acceleration in CLI mode?
Or this is a normal situation and run all the CPU cores the same everywhere?
That means you probably use incompatible distribution. What do you use?
Please add more details - especially which kernel are you using / comparing.
Both should work the same speed, just different kernel generations can show different numbers. 3.4 vs 4.x is a big diff.
There is no HW acceleration in CLI mode. This is only for playing movies.
