Yes, you're right, let polish this stuff. And we also need to figured out why 64 bits are not working.
About '_apsta', I presume/guess that allows firmware to run in both mode, while the other can only work in STA or AP, but not both at the same time.
Some news : The trick is also working with the fw_bcm43438a1.bin for Non-A of my BananaPiM2Plus ... :rolleyes:
(The only small problem is they ship me this board without antenna, fortunately, it still work since it sit by few feet of the AP)
On 4/28/2017 at 9:38 PM, martinayotte said:
AP6212 WiFi still not working on any Mainline (OPiZeroPlus*/OPiPrime/OPiWin), we still investigate ...
The only one working is Legacy OPiZeroPlus-H3.
Are you 100% sure that OPiPrime has AP6212(A)?
In my case I believe it has Realtek 8723
$ lsmod | grep 80211
cfg80211              294912  1 r8723bs
rfkill                 28672  3 cfg80211
As for OPiWin, my has AP6212A - maybe my experience might be useful to someone here.
Mainline.
Could not make it work with mainline 5.32 and upgraded 5.41 (both same kernel 4.11.8)
It is using brcmfmac module, that I tried with various firmware (/lib/firmware/brcm/brcmfmac43430-sdio.bin and -=-.txt files). All have the same result - system reboot after first wifi frames go - e.g. client get's dhcp address and the system reboots.
The only thing in dmesg:
[    9.458442] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct  8 2016 15:31:47 version 7.46.57.4.ap.r4 (A1 Station/P2P) FWID 01-3621395e es6.c5.n4.a3
[    9.741314] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code (0x30 0x30)
[    9.924496] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code (0x30 0x30)
Tracking similar (freez instead of reboot) issue:
https://github.com/raspberrypi/linux/issues/1342
Strange, but have the feeling that it did work with mainline before on 5.32 (card was corrupted and had no backup) but might confuse with prime.
Legacy.
Could make it work in legacy kernel. First the hostapd was starting fine, but was no ESSID in iwconfig and got some error in dmesg
CFG80211-ERROR) check_dev_role_integrity : device role select failed
Fixed it with module parameter.
(by Igor advice from here http://forum.banana-pi.org/t/how-to-setup-a-wifi-ap/2437)
# echo 'options bcmdhd op_mode=2' > /etc/modprobe.d/bcmdhd.conf
Iwconfig should show the ESSID name.
# iwconfig
wlan0     IEEE 802.11  ESSID:"ARMBIAN"
          Mode:Master  Frequency:2.432 GHz  Access Point: 02:1A:11:F8:B9:12
          Bit Rate=96 Mb/s   Tx-Power:32 dBm
          Retry min limit:10   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Managementmode:All packets received
Works fine despite some errors in dmesg
CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
Will appreciate any ideas with mainline and will try to provide any logs if required.
Of course, but this is really old post ! At that time, I've just received my OPiPrime board. Later, I've succeeded to get the Realtek using Icenowy's branch from that time, I don't remember which kernel version.
