otalado Posted June 25, 2024 Posted June 25, 2024 A while ago (February '24), I downloaded and installed Armbian_23.11.3_Rpi5b_bookworm_current_6.1.68_cinnamon_desktop. It is running OK, and I only have a few issues with it. One issue is that the vcgencmd is not working. I posted a question about it on the forum and received a reply saying that this would be solved "when possible." However, it is still not resolved. Without this command working, I cannot get the CPU temperature, so I cannot control the cooling fan. I checked for a newer release today to see if this issue is fixed. I was shocked to see no Bookworm with Cinnamon release available. I'd like to know if it is in the works or has been dropped and will not be offered again. 0 Quote
Werner Posted June 25, 2024 Posted June 25, 2024 We cannot afford to provide pre-made images in every kernel-userspace combination for every board. The amount of resources necessary could be just insane. However that is what the build framework is made for so you can choose exactly what you want and build it by yourself. https://github.com/armbian/build 0 Quote
otalado Posted June 25, 2024 Author Posted June 25, 2024 Ok, I tried to run the build on a Linux PC equipped with the Intel I5 CPU and 16 GB RAM. It failed. So I switched to another PC (Intel I7 / 16 GB RAM. It failed the same way. On both PCs, the error was: [] error! [ Unsupported build system: 'virginia' ] [] Exiting with error 43 [ at /home/remote/build/lib/functions/logging/traps.sh:1 exit_with_error() --> lib/functions/logging/traps.sh:1 obtain_and_check_host_release_and_arch() --> lib/functions/host/host-release.sh:41 check_basic_host() --> lib/functions/host/prepare-host.sh:33 prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:16 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] In desperation, I tried to run the build on RPI5. It seems that it works, but who knows how long will it take with just 8 GM RAM ... 0 Quote
Werner Posted June 25, 2024 Posted June 25, 2024 3 hours ago, otalado said: [ Unsupported build system: 'virginia' ] https://docs.armbian.com/Developer-Guide_Build-Preparation/ 0 Quote
andrewufrank Posted January 16, 2025 Posted January 16, 2025 I just set up an Rpi5 with MATE: I copied the files from Minimal/IOT images with Armbian Linux v6.6 to an SSD (no SD card is required!) and then installed the MATE desktop with `apt install mate-desktop-environment`; I then added other utilities ... so far, I seem to have a full functional Debian MATE desktop. I appreciate the efforts to offer the minimal installation, based on debian; it is easy to build on top! 0 Quote
