GMagician Posted July 9, 2024 Posted July 9, 2024 If I would like to build myself an image with all content present in images posted on web, downloading code at https://github.com/armbian/build and choosing my board, when I build image if I don't change anything I will get what I want? Thanks 0 Quote
Werner Posted July 9, 2024 Posted July 9, 2024 Not sure if I understand correctly. The images available for download are made with the very same build framework you find on Github: https://github.com/armbian/build 0 Quote
GMagician Posted July 23, 2024 Author Posted July 23, 2024 Sorry for my bad request When building image with ./compile.sh, if I don't change anything in kernel configuration, will I get the same configuration I may have when I download a premade image? Answer seems "not really". I compared downloaded image kernel configuration and "my image" kernel configuration and there are some different "devices" and some different drivers linkage. Maybe is just a little difference in kerner version (my image new built image uses 6.1.75 while site image uses 6.1.43). 0 Quote
SteeMan Posted July 23, 2024 Posted July 23, 2024 The Armbian build framework is constantly evolving. As well as the software that it is building. So generally each day a build will be slightly different from the previous days build (that is why there are nightly builds produced). I don't know what you are trying to accomplish so I can't really help you any further than that. 0 Quote
