Creating a build for OPiPCPlus, mainline/dev/4.11, xenial,desktop.
Need to enable the UDA1380 device in my local kernel build, yet I see some ..obstacles..
Tried initially to do a KERNEL_CONFIGURE="yes" in compile.sh but after started the compile and reached the point of menuconfig the UDA1380 option did not got presented (might be because there is no tristate string in mainline sound/soc/codecs/Kconfig..) so I reverted it back to normal.
After the first attempt, I tried by modifying the lib/config/kernel/linux-sun8i-dev.config and added "CONFIG_SND_SOC_UDA1380=m", tried the compile again and waited to finish, yet at the end, although the other .o object files (bt, spdif) created correctly in the sources/linux-sun8i-mainline/orange-pi-4.11/sound/soc/codecs folder, the required UDA1380 did not.
So, is there something that I miss here or doing it not right?
Is there another 'proper' way to enable a mainline kernel device in Armbian?
Christos
@martinayotte , yep, as I said, I did that (the actual file on filesystem is relative to armbian start, lib/config/kernel/linux-sun8i-dev.config ) but afterwards the required .o did not got presented in kernel's sound/soc/codecs  folder..
Actually, I also got a message on screen stating
scripts/kconfig/conf  --oldconfig Kconfig
.config:4034:warning: override: reassigning to symbol SND_SOC_UDA1380
# configuration written to .config
This indicates that dependencies for this option are not satisfied. You may have to use Kconfig search option to see the dependencies and their state
@zador.blood.stained
Did the Kconfig search and got
Symbol: SND_SOC_UDA1380 [=n]
Type  : tristate
Defined at sound/soc/codecs/Kconfig:901
Depends on: SOUND [=y] && !M68K && !UML && SND [=y] && SND_SOC [=m] && I2C [=y]
Selected by: SND_PXA2XX_SOC_MAGICIAN [=n] && SOUND [=y] && !M68K && !UML && SND [=y] && SND_SOC [=m] && SND_PXA2XX_SOC [=n] && MACH_MAGICIAN [=n] && I2C [=y] || SND_SOC_SAMSUNG_H1940_UDA1380 [=..
Does it looks correct?
It has no prompt value, so it is an invisible option that is selected by other Kconfig symbols
According to a quick search, it is selected by
  • SND_SOC_ALL_CODECS
  • SND_SOC_SAMSUNG_H1940_UDA1380
  • SND_SOC_SAMSUNG_RX1950_UDA1380
  • SND_PXA2XX_SOC_MAGICIAN
so it must be a SoC specific option
@zador.blood.stained , ok, did now something quite drastic, added "CONFIG_SND_SOC_ALL_CODECS=m" in lib/config/kernel/linux-sun8i-dev.config.
While compilation did not got this time the warning mentioned above but..
[ o.k. ] Using kernel config file [ lib/config/kernel/linux-sun8i-dev.config ]
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/basic/bin2c
  HOSTCC  scripts/kconfig/conf.o
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf  --olddefconfig Kconfig
 Armbian building script, http://www.armbian.com | Author: Igor Pecovnik
  │ Compiling kernel...        │
  │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/reset@080014b0 simple-bus unit address format error, expected "80014b0"                                               │
  │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/interrupt-controller@080015a0 simple-bus unit address format error, expected "80015a0"                                │
  │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/ir@08002000 simple-bus unit address format error, expected "8002000"                                                  │
  │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/serial@08002800 simple-bus unit address format error, expected "8002800"                                              │
  │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/pinctrl@08002c00 simple-bus unit address format error, expected "8002c00"                                             │
  │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/i2c@08003400 simple-bus unit address format error, expected "8003400"                                                 │
  │   DTC     arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb        │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/usb@00a00000 simple-bus unit address format error, expected "a00000"                                              │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/usb@00a00400 simple-bus unit address format error, expected "a00400"                                              │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/phy@00a00800 simple-bus unit address format error, expected "a00800"                                              │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/usb@00a01000 simple-bus unit address format error, expected "a01000"                                              │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/phy@00a01800 simple-bus unit address format error, expected "a01800"                                              │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/usb@00a02000 simple-bus unit address format error, expected "a02000"                                              │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/usb@00a02400 simple-bus unit address format error, expected "a02400"                                              │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/phy@00a02800 simple-bus unit address format error, expected "a02800"                                              │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/clock@00a08000 simple-bus unit address format error, expected "a08000"                                            │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/mmc@01c0f000 simple-bus unit address format error, expected "1c0f000"                                             │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/mmc@01c10000 simple-bus unit address format error, expected "1c10000"                                             │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/mmc@01c11000 simple-bus unit address format error, expected "1c11000"                                             │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/mmc@01c12000 simple-bus unit address format error, expected "1c12000"                                             │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/clk@01c13000 simple-bus unit address format error, expected "1c13000"                                             │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/interrupt-controller@01c41000 simple-bus unit address format error, expected "1c41000"                            │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/clock@03000000 simple-bus unit address format error, expected "3000000"                                           │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/clock@06000000 simple-bus unit address format error, expected "6000000"                                           │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/timer@06000c00 simple-bus unit address format error, expected "6000c00"                                           │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/watchdog@06000ca0 simple-bus unit address format error, expected "6000ca0"                                        │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/pinctrl@06000800 simple-bus unit address format error, expected "6000800"                                         │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07000000 simple-bus unit address format error, expected "7000000"                                          │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07000400 simple-bus unit address format error, expected "7000400"                                          │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07000800 simple-bus unit address format error, expected "7000800"                                          │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07000c00 simple-bus unit address format error, expected "7000c00"                                          │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07001000 simple-bus unit address format error, expected "7001000"                                          │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07001400 simple-bus unit address format error, expected "7001400"                                          │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@07002800 simple-bus unit address format error, expected "7002800"                                             │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@07002c00 simple-bus unit address format error, expected "7002c00"                                             │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@07003000 simple-bus unit address format error, expected "7003000"                                             │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@07003400 simple-bus unit address format error, expected "7003400"                                             │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@07003800 simple-bus unit address format error, expected "7003800"                                             │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/watchdog@08001000 simple-bus unit address format error, expected "8001000"                                        │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/reset@080014b0 simple-bus unit address format error, expected "80014b0"                                           │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/interrupt-controller@080015a0 simple-bus unit address format error, expected "80015a0"                            │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/ir@08002000 simple-bus unit address format error, expected "8002000"                                              │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@08002800 simple-bus unit address format error, expected "8002800"                                          │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/pinctrl@08002c00 simple-bus unit address format error, expected "8002c00"                                         │
  │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@08003400 simple-bus unit address format error, expected "8003400"                                             │
A really large number of ..cubieboard errors!
The compile finished
[ o.k. ] Free space: [ SD card ]
/dev/loop0p1    2,8G  2,0G  739M  74% /home/christos/armbian/output/cache/mount-dev-orangepipcplus-xenial-yes
[ o.k. ] Writing U-boot bootloader [ /dev/loop0 ]
[ o.k. ] Done building [ /home/christos/armbian/output/images/Armbian_5.27_Orangepipcplus_Ubuntu_xenial_dev_4.11.0_desktop.img ]
[ o.k. ] Runtime [ 12 min ]
but again in sound/soc/codecs only bt and spdif drivers got build..
I'm lost..
You should never edit the config file directly - use the menuconfig to change it.
These warnings can be ignored
Got it, since menuconfig takes care of prerequisites and presents only valid options.
It looks though that I need to be educated about the asoc scheme in mainline, simple device stuff that are easy in legacy do pose significant obstacles in mainline at least as I see it.
Thanks to both of you guys, @zador.blood.stained @martinayotte .
Christos
