Christos Posted May 8, 2017 Share Posted May 8, 2017 Hi, Creating a build for OPiPCPlus, mainline/dev/4.11, xenial,desktop. Need to enable the UDA1380 device in my local kernel build, yet I see some ..obstacles.. Tried initially to do a KERNEL_CONFIGURE="yes" in compile.sh but after started the compile and reached the point of menuconfig the UDA1380 option did not got presented (might be because there is no tristate string in mainline sound/soc/codecs/Kconfig..) so I reverted it back to normal. After the first attempt, I tried by modifying the lib/config/kernel/linux-sun8i-dev.config and added "CONFIG_SND_SOC_UDA1380=m", tried the compile again and waited to finish, yet at the end, although the other .o object files (bt, spdif) created correctly in the sources/linux-sun8i-mainline/orange-pi-4.11/sound/soc/codecs folder, the required UDA1380 did not. So, is there something that I miss here or doing it not right? Is there another 'proper' way to enable a mainline kernel device in Armbian? Christos Link to comment Share on other sites More sharing options...
martinayotte Posted May 8, 2017 Share Posted May 8, 2017 If you are building with Armbian scripts, you need to add the "CONFIG_SND_SOC_UDA1380=m" there : https://github.com/armbian/build/blob/master/config/kernel/linux-sun8i-dev.config Link to comment Share on other sites More sharing options...
Christos Posted May 8, 2017 Author Share Posted May 8, 2017 Hi, @martinayotte , yep, as I said, I did that (the actual file on filesystem is relative to armbian start, lib/config/kernel/linux-sun8i-dev.config ) but afterwards the required .o did not got presented in kernel's sound/soc/codecs folder.. Actually, I also got a message on screen stating scripts/kconfig/conf --oldconfig Kconfig .config:4034:warning: override: reassigning to symbol SND_SOC_UDA1380 # # configuration written to .config # Link to comment Share on other sites More sharing options...
zador.blood.stained Posted May 8, 2017 Share Posted May 8, 2017 20 minutes ago, Christos said: but after started the compile and reached the point of menuconfig the UDA1380 option did not got presented This indicates that dependencies for this option are not satisfied. You may have to use Kconfig search option to see the dependencies and their state Link to comment Share on other sites More sharing options...
Christos Posted May 8, 2017 Author Share Posted May 8, 2017 @zador.blood.stained , ok, thanks, as I see in sound/soc/codecs/Kconfig the uda1380 relies only on I2C and from what I know unless I'm mistaken, that is already there.. Link to comment Share on other sites More sharing options...
Christos Posted May 8, 2017 Author Share Posted May 8, 2017 @zador.blood.stained Did the Kconfig search and got Symbol: SND_SOC_UDA1380 [=n] Type : tristate Defined at sound/soc/codecs/Kconfig:901 Depends on: SOUND [=y] && !M68K && !UML && SND [=y] && SND_SOC [=m] && I2C [=y] Selected by: SND_PXA2XX_SOC_MAGICIAN [=n] && SOUND [=y] && !M68K && !UML && SND [=y] && SND_SOC [=m] && SND_PXA2XX_SOC [=n] && MACH_MAGICIAN [=n] && I2C [=y] || SND_SOC_SAMSUNG_H1940_UDA1380 [=.. Does it looks correct? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted May 8, 2017 Share Posted May 8, 2017 16 minutes ago, Christos said: Does it looks correct? It has no prompt value, so it is an invisible option that is selected by other Kconfig symbols According to a quick search, it is selected by SND_SOC_ALL_CODECS SND_SOC_SAMSUNG_H1940_UDA1380 SND_SOC_SAMSUNG_RX1950_UDA1380 SND_PXA2XX_SOC_MAGICIAN so it must be a SoC specific option Link to comment Share on other sites More sharing options...
Christos Posted May 8, 2017 Author Share Posted May 8, 2017 @zador.blood.stained , ok, did now something quite drastic, added "CONFIG_SND_SOC_ALL_CODECS=m" in lib/config/kernel/linux-sun8i-dev.config. While compilation did not got this time the warning mentioned above but.. [ o.k. ] Using kernel config file [ lib/config/kernel/linux-sun8i-dev.config ] HOSTCC scripts/basic/fixdep HOSTCC scripts/basic/bin2c HOSTCC scripts/kconfig/conf.o HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf scripts/kconfig/conf --olddefconfig Kconfig # # configuration written to .config # Armbian building script, http://www.armbian.com | Author: Igor Pecovnik ────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────── ┌────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ Compiling kernel... │ │────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────│ │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/reset@080014b0 simple-bus unit address format error, expected "80014b0" │ │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/interrupt-controller@080015a0 simple-bus unit address format error, expected "80015a0" │ │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/ir@08002000 simple-bus unit address format error, expected "8002000" │ │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/serial@08002800 simple-bus unit address format error, expected "8002800" │ │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/pinctrl@08002c00 simple-bus unit address format error, expected "8002c00" │ │ arch/arm/boot/dts/sun9i-a80-optimus.dtb: Warning (simple_bus_reg): Node /soc/i2c@08003400 simple-bus unit address format error, expected "8003400" │ │ DTC arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/usb@00a00000 simple-bus unit address format error, expected "a00000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/usb@00a00400 simple-bus unit address format error, expected "a00400" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/phy@00a00800 simple-bus unit address format error, expected "a00800" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/usb@00a01000 simple-bus unit address format error, expected "a01000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/phy@00a01800 simple-bus unit address format error, expected "a01800" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/usb@00a02000 simple-bus unit address format error, expected "a02000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/usb@00a02400 simple-bus unit address format error, expected "a02400" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/phy@00a02800 simple-bus unit address format error, expected "a02800" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/clock@00a08000 simple-bus unit address format error, expected "a08000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/mmc@01c0f000 simple-bus unit address format error, expected "1c0f000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/mmc@01c10000 simple-bus unit address format error, expected "1c10000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/mmc@01c11000 simple-bus unit address format error, expected "1c11000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/mmc@01c12000 simple-bus unit address format error, expected "1c12000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/clk@01c13000 simple-bus unit address format error, expected "1c13000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/interrupt-controller@01c41000 simple-bus unit address format error, expected "1c41000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/clock@03000000 simple-bus unit address format error, expected "3000000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/clock@06000000 simple-bus unit address format error, expected "6000000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/timer@06000c00 simple-bus unit address format error, expected "6000c00" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/watchdog@06000ca0 simple-bus unit address format error, expected "6000ca0" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/pinctrl@06000800 simple-bus unit address format error, expected "6000800" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07000000 simple-bus unit address format error, expected "7000000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07000400 simple-bus unit address format error, expected "7000400" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07000800 simple-bus unit address format error, expected "7000800" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07000c00 simple-bus unit address format error, expected "7000c00" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07001000 simple-bus unit address format error, expected "7001000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@07001400 simple-bus unit address format error, expected "7001400" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@07002800 simple-bus unit address format error, expected "7002800" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@07002c00 simple-bus unit address format error, expected "7002c00" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@07003000 simple-bus unit address format error, expected "7003000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@07003400 simple-bus unit address format error, expected "7003400" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@07003800 simple-bus unit address format error, expected "7003800" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/watchdog@08001000 simple-bus unit address format error, expected "8001000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/reset@080014b0 simple-bus unit address format error, expected "80014b0" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/interrupt-controller@080015a0 simple-bus unit address format error, expected "80015a0" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/ir@08002000 simple-bus unit address format error, expected "8002000" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/serial@08002800 simple-bus unit address format error, expected "8002800" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/pinctrl@08002c00 simple-bus unit address format error, expected "8002c00" │ │ arch/arm/boot/dts/sun9i-a80-cubieboard4.dtb: Warning (simple_bus_reg): Node /soc/i2c@08003400 simple-bus unit address format error, expected "8003400" │ └────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ A really large number of ..cubieboard errors! The compile finished [ o.k. ] Free space: [ SD card ] /dev/loop0p1 2,8G 2,0G 739M 74% /home/christos/armbian/output/cache/mount-dev-orangepipcplus-xenial-yes [ o.k. ] Writing U-boot bootloader [ /dev/loop0 ] [ o.k. ] Done building [ /home/christos/armbian/output/images/Armbian_5.27_Orangepipcplus_Ubuntu_xenial_dev_4.11.0_desktop.img ] [ o.k. ] Runtime [ 12 min ] but again in sound/soc/codecs only bt and spdif drivers got build.. I'm lost.. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted May 8, 2017 Share Posted May 8, 2017 1 minute ago, Christos said: @zador.blood.stained , ok, did now something quite drastic, added "CONFIG_SND_SOC_ALL_CODECS=m" in lib/config/kernel/linux-sun8i-dev.config. You should never edit the config file directly - use the menuconfig to change it. 1 minute ago, Christos said: While compilation did not got this time the warning mentioned above but.. These warnings can be ignored Link to comment Share on other sites More sharing options...
Christos Posted May 8, 2017 Author Share Posted May 8, 2017 13 minutes ago, zador.blood.stained said: You should never edit the config file directly - use the menuconfig to change it. Got it, since menuconfig takes care of prerequisites and presents only valid options. It looks though that I need to be educated about the asoc scheme in mainline, simple device stuff that are easy in legacy do pose significant obstacles in mainline at least as I see it. Thanks to both of you guys, @zador.blood.stained @martinayotte . Christos Link to comment Share on other sites More sharing options...
