s1cx Posted July 11, 2024 Posted July 11, 2024 Built latest image for a Rock 3c based device and am having an issue with ethernet connectivity. Boots fine. Wifi works well and it seems functional other than Eth connectivity. My old DTB (from 4.19) will not boot , using a rock3c DTB instead to get a 90% functional device Showing the following for ethernet dmesg | grep eth [ 0.000000] psci: probing for conduit method from DT. [ 3.199039] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 3.199576] rk_gmac-dwmac fe010000.ethernet: clock input or output? (output). [ 3.199601] rk_gmac-dwmac fe010000.ethernet: TX delay(0x30). [ 3.199614] rk_gmac-dwmac fe010000.ethernet: RX delay(0x10). [ 3.199635] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 3.204712] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 3.208587] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 3.208629] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 3.208645] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 3.208655] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 3.208665] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 3.208673] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 3.208826] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 3.208841] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 3.208855] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 3.208870] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 3.208881] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 19.363313] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.364568] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 19.495835] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.497405] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 19.534125] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.535151] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 19.559774] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.561300] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) [ 19.585340] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.586439] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) ifconfig -a eth0: flags=4098<BROADCAST,MULTICAST> mtu 1500 ether 5e:f6:2b:24:65:02 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 70 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 92 bytes 8013 (8.0 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 92 bytes 8013 (8.0 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.1.87 netmask 255.255.255.0 broadcast 192.168.1.255 inet6 fe80::1613:33ff:fe49:f6a9 prefixlen 64 scopeid 0x20<link> inet6 fd74:b7a7:661b:594c:1613:33ff:fe49:f6a9 prefixlen 64 scopeid 0x0<global> ether 14:13:33:49:f6:a9 txqueuelen 1000 (Ethernet) RX packets 554 bytes 43352 (43.3 KB) RX errors 0 dropped 30 overruns 0 frame 0 TX packets 153 bytes 13457 (13.4 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 4.19 kernel boots fine with Eth connectivity with latest u-boot, so this appears to be a kernel issue. Any idea where i should look in the dtb? I am basically blindly looking into it right now and could use some pointers. I've been looking around these forums for the last hour or so and really don't see anything related directly to my board/issue Attached the old (4.19) based dtb with working ethernet and current (no ethernet) rk3566-box-current.dts rk3566-box-4.19.dts 0 Quote
Werner Posted July 11, 2024 Posted July 11, 2024 On 7/11/2024 at 1:11 AM, s1cx said: Any idea where i should look in the dtb? Expand I'd start at ethernet@fe010000 0 Quote
s1cx Posted July 11, 2024 Author Posted July 11, 2024 (edited) Yeah. Messed with those options to match the original. Tried changing 1 line at a time, etc ,etc. Pretty much changed that node as many ways as I could, doesn't seem to be the case. I'm assuming it's somewhere else in the dts file Edited July 11, 2024 by s1cx 0 Quote
s1cx Posted July 16, 2024 Author Posted July 16, 2024 Update i created a patch to add +CONFIG_PHY_MOTORCOMM=y to the uboot defconfig since the chip is a Motorcomm YT8512C. Changed things up a little. [ 0.000000] psci: probing for conduit method from DT. [ 2.670967] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 2.671508] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 2.671532] rk_gmac-dwmac fe010000.ethernet: TX delay(0x30). [ 2.671546] rk_gmac-dwmac fe010000.ethernet: RX delay(0x10). [ 2.671566] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 2.671622] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 2.676655] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 2.677175] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 2.677214] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 2.677230] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 2.677240] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 2.677249] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 2.677258] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 2.677395] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 2.677410] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 2.677424] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 2.677439] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 2.677450] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 13.145407] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 13.147665] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet] (irq=POLL) [ 14.151864] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma [ 14.151894] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed [ 14.151904] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Hw setup failed Here is current dts ethernet@fe010000 { compatible = "rockchip,rk3568-gmac\0snps,dwmac-4.20a"; reg = <0x00 0xfe010000 0x00 0x10000>; interrupts = <0x00 0x20 0x04 0x00 0x1d 0x04>; interrupt-names = "macirq\0eth_wake_irq"; clocks = <0x0e 0x186 0x0e 0x189 0x0e 0x189 0x0e 0xc7 0x0e 0xc3 0x0e 0xc4 0x0e 0x189 0x0e 0xc8>; clock-names = "stmmaceth\0mac_clk_rx\0mac_clk_tx\0clk_mac_refout\0aclk_mac\0pclk_mac\0clk_mac_speed\0ptp_ref"; resets = <0x0e 0xec>; reset-names = "stmmaceth"; rockchip,grf = <0x1d>; snps,axi-config = <0x43>; snps,mixed-burst; snps,mtl-rx-config = <0x44>; snps,mtl-tx-config = <0x45>; snps,tso; status = "okay"; assigned-clocks = <0x0e 0x189 0x0e 0x187 0x0e 0x186>; assigned-clock-parents = <0x0e 0x187 0x0e 0x186 0x46>; clock_in_out = "input"; phy-supply = <0x18>; phy-mode = "rgmii"; pinctrl-names = "default"; pinctrl-0 = <0x47 0x48 0x49 0x4a 0x4b 0x4c>; snps,reset-gpio = <0x4d 0x01 0x01>; snps,reset-active-low; snps,reset-delays-us = <0x00 0x4e20 0x186a0>; tx_delay = <0x30>; rx_delay = <0x10>; phy-handle = <0x4e>; phandle = <0xe5>; mdio { compatible = "snps,dwmac-mdio"; #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0xe6>; ethernet-phy@0 { compatible = "ethernet-phy-id001c.c915\0ethernet-phy-ieee802.3-c22"; reg = <0x00>; status = "okay"; phandle = <0x4e>; }; }; Will continue to work on, although any insight would be great. could use a nudge 0 Quote
Celona Posted August 19, 2024 Posted August 19, 2024 (edited) I've now resigned myself to the fact that using Raxda's SBCs requires external adapters, they are not able to provide even a minimal working system, as their latest Debian image demonstrates: https://github.com/radxa-build/rock-3c/releases/tag/b43. So yours don't work either, or am I doing something wrong? ____ _ _____ ____ | _ \ ___ ___| | __ |___ / / ___| | |_) / _ \ / __| |/ / |_ \| | | _ < (_) | (__| < ___) | |___ |_| \_\___/ \___|_|\_\ |____/ \____| Welcome to Armbian_community 24.11.0-trunk.4 Bookworm with Linux 6.6.47-current-rockchip64 No end-user support: untested automated build System load: 21% Up time: 0 min Memory usage: 5% of 1.93G IP: 192.168.1.163 CPU temp: 63°C Usage of /: 6% of 29G uname -a Linux rock2g 6.6.47-current-rockchip64 #1 SMP PREEMPT Mon Aug 19 04:04:32 UTC 2024 aarch64 GNU/Linux sudo dmesg -l 0,1,2,3 [ 11.942338] of_dma_request_slave_channel: dma-names property of node '/serial@fe650000' missing or empty [ 14.090200] Bluetooth: hci0: command 0x0c03 tx timeout [ 14.090306] Bluetooth: hci0: BCM: Reset failed (-110) ip a | grep "inet " inet 127.0.0.1/8 scope host lo inet 192.168.1.163/24 metric 100 brd 192.168.1.255 scope global dynamic enxb88d1254cda3 ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether a6:a2:b0:36:4d:8f brd ff:ff:ff:ff:ff:ff inet6 2a01:e11:1400:5d0:6bf9:d83d:a987:dc3f/64 scope global temporary dynamic valid_lft 86027sec preferred_lft 85098sec inet6 2a01:e11:1400:5d0:a4a2:b0ff:fe36:4d8f/64 scope global dynamic mngtmpaddr noprefixroute valid_lft 86027sec preferred_lft 86027sec inet6 fe80::a4a2:b0ff:fe36:4d8f/64 scope link valid_lft forever preferred_lft forever 3: enxb88d1254cda3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000 link/ether b8:8d:12:54:cd:a3 brd ff:ff:ff:ff:ff:ff inet 192.168.1.163/24 metric 100 brd 192.168.1.255 scope global dynamic enxb88d1254cda3 valid_lft 41689sec preferred_lft 41689sec inet6 fd8c:df22:1b60:a94b:8d64:46a6:bfb8:62b8/64 scope global temporary deprecated dynamic valid_lft 475sec preferred_lft 0sec inet6 fd8c:df22:1b60:a94b:ba8d:12ff:fe54:cda3/64 scope global deprecated dynamic mngtmpaddr noprefixroute valid_lft 475sec preferred_lft 0sec inet6 2a01:e11:1400:5d0:f759:2829:fa0b:ad4e/64 scope global temporary dynamic valid_lft 86027sec preferred_lft 84745sec inet6 2a01:e11:1400:5d0:ba8d:12ff:fe54:cda3/64 scope global dynamic mngtmpaddr noprefixroute valid_lft 86027sec preferred_lft 86027sec inet6 fe80::ba8d:12ff:fe54:cda3/64 scope link valid_lft forever preferred_lft forever sudo dmesg | grep eth [ 0.000000] psci: probing for conduit method from DT. [ 4.039090] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 4.042387] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 4.042420] rk_gmac-dwmac fe010000.ethernet: TX delay(0x47). [ 4.042435] rk_gmac-dwmac fe010000.ethernet: RX delay(0x27). [ 4.042461] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 4.042527] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 4.050680] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 4.055059] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.055098] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 4.055113] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 4.055123] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 4.055133] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 4.055142] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 4.055276] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 4.055291] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.055305] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 4.055319] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 4.055331] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 4.302372] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 [ 4.656403] asix 6-1:1.0 eth0: register 'asix' at usb-fd880000.usb-1, ASIX AX88772 USB 2.0 Ethernet, b8:8d:12:54:cd:a3 [ 4.664025] asix 6-1:1.0 enxb88d1254cda3: renamed from eth0 [ 11.660738] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 11.758203] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL) [ 11.768291] rk_gmac-dwmac fe010000.ethernet end0: No Safety Features support found [ 11.768322] rk_gmac-dwmac fe010000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported [ 11.768670] rk_gmac-dwmac fe010000.ethernet end0: registered PTP clock [ 11.769109] rk_gmac-dwmac fe010000.ethernet end0: configuring for phy/rgmii link mode [ 673.250279] rk_gmac-dwmac fe010000.ethernet end0: Link is Up - 100Mbps/Full - flow control rx/tx Module Size Used by lz4hc 12288 0 lz4 12288 0 zram 32768 3 binfmt_misc 20480 1 nls_iso8859_1 12288 1 hci_uart 135168 0 hantro_vpu 249856 0 v4l2_vp9 20480 1 hantro_vpu rockchip_rga 20480 0 btqca 20480 1 hci_uart videobuf2_dma_contig 20480 1 hantro_vpu btrtl 28672 1 hci_uart snd_soc_simple_card 20480 0 snd_soc_rk817 40960 1 snd_soc_hdmi_codec 20480 1 v4l2_h264 16384 1 hantro_vpu snd_soc_rockchip_i2s_tdm 20480 4 v4l2_mem2mem 24576 2 hantro_vpu,rockchip_rga videobuf2_dma_sg 16384 1 rockchip_rga btintel 40960 1 hci_uart snd_soc_simple_card_utils 24576 1 snd_soc_simple_card snd_soc_core 208896 5 snd_soc_rockchip_i2s_tdm,snd_soc_hdmi_codec,snd_soc_rk817,snd_soc_simple_card_utils,snd_soc_simple_card videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_dma_sg btbcm 20480 1 hci_uart videobuf2_v4l2 20480 3 hantro_vpu,rockchip_rga,v4l2_mem2mem pwm_fan 20480 0 snd_compress 24576 1 snd_soc_core bluetooth 663552 6 btrtl,btqca,btintel,hci_uart,btbcm videodev 229376 4 videobuf2_v4l2,hantro_vpu,rockchip_rga,v4l2_mem2mem panfrost 69632 0 snd_pcm_dmaengine 12288 1 snd_soc_core display_connector 16384 0 rk_crypto2 36864 0 snd_pcm 106496 5 snd_soc_hdmi_codec,snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_pcm_dmaengine videobuf2_common 49152 7 videobuf2_dma_contig,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_dma_sg,v4l2_mem2mem,videobuf2_memops gpu_sched 36864 1 panfrost snd_timer 36864 1 snd_pcm dw_hdmi_i2s_audio 12288 0 dw_hdmi_cec 12288 0 mc 53248 5 videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem drm_shmem_helper 16384 1 panfrost sm3_generic 12288 1 rk_crypto2 snd 77824 5 snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm sm3 20480 1 sm3_generic at24 20480 0 rk817_charger 20480 0 soundcore 12288 1 snd apple_mfi_fastcharge 16384 0 cpufreq_dt 16384 0 cfg80211 802816 0 rfkill 24576 3 bluetooth,cfg80211 dm_mod 126976 0 ip_tables 28672 0 x_tables 36864 1 ip_tables autofs4 40960 2 ax88796b 12288 1 realtek 32768 1 spi_rockchip_sfc 16384 0 dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 233472 3 stmmac_platform,dwmac_rk pcs_xpcs 20480 1 stmmac asix 49152 0 usbnet 40960 1 asix Edited August 19, 2024 by Celona 0 Quote
