Hi
first of all Please excuse my poor English !
I install ubuntu lagecy server on my orange pi pc + and then install it on nand using : $nand-sata-install
now when i power on my board with sd card (sd card without any image file) my root file system will mount on mmcb1k0p1 and if I insert my sd card after power on root will mount on mmcb1k1p1 (I now both mmcb1k1p1 & mmcb1k0p1 are my emmc)
Now i need to automount my sd card and in my case I insert sd card before power on and as a result I add this line in fstab file
#/dev/mmcb1k0p1                                 /mnt            ext4           0  1
but it doesn't work !
how can i mount my sd card automatically ?
You seems to confuse between "1" and "l" ...
Also, make sure there is no more u-boot sectors in the inserted sdcard, otherwise it will boot from it.
I correct my fstab file but still i can't automount sd card (there in no any u-boot sectors in sdcard)
/dev/mmcblk0p1                                 /mnt            ext4        0       1
