Posted (edited)
Please advise on how to fix this, thanks:
Setting up rockchip-multimedia-config (1.0.2+jammy) ...
dpkg-query: error: --listfiles needs at least one package name argument
Use --help for help about querying packages.
dpkg: error processing package rockchip-multimedia-config (--configure):
 installed rockchip-multimedia-config package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Edited by OP5_PLUS
ipdate
Posted (edited)
@Werner thanks for the solution. upgraded to 6.1.y vendor kernel and now left with this apt upgrade error:
FYI: https://paste.armbian.com/alemunokuk
Edited by OP5_PLUS
update
Looks a bit odd ... perhaps try to repair something that has gone wrong by re-installing:
sudo apt remove rockchip-multimedia-config
# check that /etc/apt/sources.list.d/* has the correct ubuntu version ie. 'jammy' in your case not 'noble' or 'focal'
sudo apt install rockchip-multimedia-config
