A9 Posted July 15, 2024 Posted July 15, 2024 On Tinkerboard S, I installed Armbian 24.5.1 Noble XFCE to mmc and tried again with an SD card after having trouble. The desktop does not respond to 2 different keyboards I have tried. If I use a mouse to open Terminal, the keyboards do work in the Terminal. If I try to open Web Browser in the applications menu, I get a window saying "Failed to execute Web Browser. Input/output error." apt update and apt upgrade do not fix the problem. Here is a log: https://paste.armbian.com/onikesixam 0 Quote
A9 Posted July 15, 2024 Author Posted July 15, 2024 re: Web Browser: "snap install chromium" fixed the issue. re: Desktop not responding to keyboard: I thought we used to be able to open the Applications menu by pressing the Windows key, and I thought we could open a terminal by pressing ctrl+alt+t. Can anyone confirm if those should work? 0 Quote
SteeMan Posted July 16, 2024 Posted July 16, 2024 5 hours ago, A9 said: Desktop not responding to keyboard: I thought we used to be able to open the Applications menu by pressing the Windows key, and I thought we could open a terminal by pressing ctrl+alt+t. What you are describing sounds like standard gnome desktop behavior. I don't think all desktops have that same default behavior. You said above you installed xfce desktop not gnome. 0 Quote
Igor Posted July 16, 2024 Posted July 16, 2024 12 hours ago, A9 said: re: Web Browser: "snap install chromium" fixed the issue. No need to use snap version as sudo apt install chromium also works. 0 Quote
