Mike R9FT Posted May 21, 2017 Share Posted May 21, 2017 Is it possible to use uart rts gpio on mainline? May be like discribed here https://kernel.googlesource.com/pub/scm/linux/kernel/git/next/linux-next/+/refs/heads/akpm-base/Documentation/devicetree/bindings/serial/serial.txt Link to comment Share on other sites More sharing options...
zador.blood.stained Posted May 21, 2017 Share Posted May 21, 2017 AFAIK for the mainline kernel if UART controller that you selected has RTS and CTS GPIOs wired to the pin header, it's enough to just set up the pinmux. For recent enough mainline Armbian images it's enough to add something like param_uart2_rtscts=1 to /boot/armbianEnv.txt (assuming uart2 overlay was activated already) Link to comment Share on other sites More sharing options...
Mike R9FT Posted May 21, 2017 Author Share Posted May 21, 2017 It's ok, but what about software RTS on another gpio pin using "rts-gpios" statement? Link to comment Share on other sites More sharing options...
Mike R9FT Posted May 21, 2017 Author Share Posted May 21, 2017 I guess it needs modification in drivers/tty/serial/8250/ For example it is done in the omap-serial.c, here is some chunk of code: static void serial_omap_start_tx(struct uart_port *port) { struct uart_omap_port *up = to_uart_omap_port(port); int res; pm_runtime_get_sync(up->dev); /* Handle RS-485 */ if (port->rs485.flags & SER_RS485_ENABLED) { /* Fire THR interrupts when FIFO is below trigger level */ up->scr &= ~OMAP_UART_SCR_TX_EMPTY; serial_out(up, UART_OMAP_SCR, up->scr); /* if rts not already enabled */ res = (port->rs485.flags & SER_RS485_RTS_ON_SEND) ? 1 : 0; if (gpio_get_value(up->rts_gpio) != res) { gpio_set_value(up->rts_gpio, res); if (port->rs485.delay_rts_before_send > 0) mdelay(port->rs485.delay_rts_before_send); } } if ((port->rs485.flags & SER_RS485_ENABLED) && !(port->rs485.flags & SER_RS485_RX_DURING_TX)) serial_omap_stop_rx(port); serial_omap_enable_ier_thri(up); pm_runtime_mark_last_busy(up->dev); pm_runtime_put_autosuspend(up->dev); } Link to comment Share on other sites More sharing options...
zador.blood.stained Posted May 21, 2017 Share Posted May 21, 2017 According to the generic serial bindings using GPIO RTS/CTS should be possible, but right now I don't see exactly why it would be needed since HW supports those signals/pins too. Link to comment Share on other sites More sharing options...
Mike R9FT Posted May 22, 2017 Author Share Posted May 22, 2017 I need it because of hardware 40pin connector compatibility with another board. Tried the following overlay, but no luck /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target-path = "/aliases"; __overlay__ { serial3 = "/soc/serial@01c28c00"; }; }; fragment@1 { target = <&uart3>; __overlay__ { pinctrl-names = "default"; pinctrl-0 = <&uart3_pins>; uart-has-rtscts; rts-gpios = <&pio 3 14 0>; /* PD14 */ status = "okay"; }; }; }; Overlay applied: ls -l /sys/devices/platform/serial8250/subsystem/devices/1c28c00.serial/of_node/ total 0 -r--r--r-- 1 root root 8 May 22 04:57 clocks -r--r--r-- 1 root root 17 May 22 04:57 compatible -r--r--r-- 1 root root 6 May 22 04:57 dma-names -r--r--r-- 1 root root 16 May 22 04:57 dmas -r--r--r-- 1 root root 12 May 22 04:57 interrupts -r--r--r-- 1 root root 4 May 22 04:57 linux,phandle -r--r--r-- 1 root root 7 May 22 04:57 name -r--r--r-- 1 root root 4 May 22 04:57 phandle -r--r--r-- 1 root root 4 May 22 04:57 pinctrl-0 -r--r--r-- 1 root root 8 May 22 04:57 pinctrl-names -r--r--r-- 1 root root 8 May 22 04:57 reg -r--r--r-- 1 root root 4 May 22 04:57 reg-io-width -r--r--r-- 1 root root 4 May 22 04:57 reg-shift -r--r--r-- 1 root root 8 May 22 04:57 resets -r--r--r-- 1 root root 16 May 22 04:57 rts-gpios -r--r--r-- 1 root root 5 May 22 04:57 status -r--r--r-- 1 root root 0 May 22 04:57 uart-has-rtscts May be it needs pin mux setup Link to comment Share on other sites More sharing options...
zador.blood.stained Posted May 22, 2017 Share Posted May 22, 2017 Quote - uart-has-rtscts: The presence of this property indicates that the UART has dedicated lines for RTS/CTS hardware flow control, and that they are available for use (wired and enabled by pinmux configuration). This depends on both the UART hardware and the board wiring. Note that this property is mutually-exclusive with "cts-gpios" and "rts-gpios" above, unless support is provided to switch between modes dynamically. Link to comment Share on other sites More sharing options...
ZupoLlask Posted July 7, 2017 Share Posted July 7, 2017 Does anyone know if @Mike R9FT hack is still required with mainline Kernel 4.9 and later versions to enable RTS using GPIO for half-duplex RS485 adapters connected to UART ports without hardware RTS/CTS? Link to comment Share on other sites More sharing options...
Mike R9FT Posted July 22, 2017 Author Share Posted July 22, 2017 I am not get it working. Now I am switching gpio from user-space side. Link to comment Share on other sites More sharing options...
Mike R9FT Posted October 10, 2018 Author Share Posted October 10, 2018 Hi I am using ADM2483 RS-485 Transceiver. Now I am control RX/TX switch with GPIO pin from userspace. Can anyone tell, what is the best way to control RX/TX switch from mainline ? Thanks. Link to comment Share on other sites More sharing options...
martinayotte Posted October 10, 2018 Share Posted October 10, 2018 Unless you wish to get you feet wet into kernel code, current kernel, even Mainline, doesn't have the code yet for kernel side HalfDuplex control for AllWinner UARTs (compatible = "snps,dw-apb-uart"). Some other type of UARTs have this functionality such Texas Instrument OMAP, STM32or EXAR. Personally, I've created a patch for DW-APB-UART, it seems working, but it is not well tested yet ... In the mean time, you still need to control it via GPIO ... Link to comment Share on other sites More sharing options...
Pistoletov Posted June 19, 2019 Share Posted June 19, 2019 (edited) @martinayotte I have the same problem with allwinner A10 uart and 485 mode. Can I test yours patch for this board? Where I can find it Edited June 20, 2019 by Pistoletov Link to comment Share on other sites More sharing options...
