Jean-Francois Lessard Posted Thursday at 04:28 PM Author Posted Thursday at 04:28 PM Hi @KrzyPacu I can only provide basic instructions without any support regarding loading overlays. It's not supported on every device (and I personally don't own a device which supports this). You can always search for other posts on device tree overlay for your device if you absolutely want to use overlays. Though, you can easily embed the device tree overlay into your dtb instead. This is what I do personally. You can check instructions of Option 2: Create an updated dtb at : https://github.com/jefflessard/tm16xx-display/blob/main/README.md#configure-the-device-tree 0 Quote
KrzyPacu Posted Thursday at 04:48 PM Posted Thursday at 04:48 PM (edited) $ make meson-sm1-x96-air-gbit_mod.dtb ORIGINAL_DTB=meson-sm1-x96-air-gbit.dtb make: *** No rules for object execution 'meson-sm1-x96-air-gbit_mod.dtb'. Stop. https://github.com/jefflessard/tm16xx-display/blob/main/README.md#configure-the-device-tree I can't do option 1 because I don't have the "/boot/armbianEnv.txt" file . Where do I add the entry "user_overlays=tm16xx" Edited Thursday at 04:53 PM by KrzyPacu 0 Quote
Jean-Francois Lessard Posted Thursday at 05:17 PM Author Posted Thursday at 05:17 PM @KrzyPacu Start by copying your original dtb into tm16xx-display folder: cd tm16xx-display cp meson-sm1-x96-air-gbit.dtb original.dtb # or alternatively run: make extract-dtb Then, assuming the corresponding device tree source overlay in the "devices" subfolder is "x96-max-1gbit.dtso", build the updated dtb: make x96-max-1gbit.dtb # <-- same name as the dtso file in devices subfolder but with dtb extension Finally, replace the original dtb of your boot path with the updated one (first keep a copy of your original dtb somewhere else, just in case) and reboot: cp release/x96-max-1gbit.dtb /boot/dtb/{YOUR_DTB_PATH}.dtb reboot 0 Quote
SteeMan Posted Thursday at 08:14 PM Posted Thursday at 08:14 PM @KrzyPacu The Amlogic TV Box builds use extlinux.conf. So you should add your overlay info in that file (/boot/extlinux/extlinux.conf). I believe the syntax for extlinux is: OVERLAYS /dtb/amlogic/overlay/... (I'd recommend placing it just below the FDT line) (Note: I've never tried to load an overlay through extlinux, but have been intending to try it some day. Let us know how it goes) 0 Quote
KrzyPacu Posted Thursday at 09:45 PM Posted Thursday at 09:45 PM I managed to build "meson-sm1-x96-air-gbit.dtb" using the method described by @Jean-Francois Lessard but I haven't added anything to the "extlinux.conf" file yet. Then I issued the command "$ make module" and it seems to me that the compilation went correctly. Then I did "$ sudo make module-install" and here are the errors: $ sudo make module-install make -C /lib/modules/6.12.33-current-meson64/build M= modules_install INSTALL_MOD_PATH=/ make[1]: Enter the directory '/usr/src/linux-headers-6.12.33-current-meson64' SYMLINK //lib/modules/6.12.33/build make[3]: *** No rules to make an object 'modules.order', required by '//lib/modules/6.12.33/modules.order'. Stop. make[2]: *** [/usr/src/linux-headers-6.12.33-current-meson64/Makefile:1853: modules_install] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving the directory '/usr/src/linux-headers-6.12.33-current-meson64' make: *** [Makefile:35: module-install] Error 2 0 Quote
Jean-Francois Lessard Posted Thursday at 09:59 PM Author Posted Thursday at 09:59 PM @KrzyPacu it seems there is an issue with your kernel source code (or minimal headers). Ensure to install kernel headers for your distribution/version first If it still doesn't point to your headers/source path, you can pass it as a variable when executing make. Something like: sudo make module-install KDIR=/path/to/your/headers/build 0 Quote
KrzyPacu Posted Friday at 11:15 AM Posted Friday at 11:15 AM Nothing helped so I reinstalled the system. Can you tell me now how and what I should install. Up until now I installed the kernel headers via armbian-config. But maybe there is a better way? 0 Quote
Jean-Francois Lessard Posted Friday at 11:38 AM Author Posted Friday at 11:38 AM Looking back at your previous output, I've just noticed something wrong. I've should have seen it first instead of pointing you to kernel headers issue. 13 hours ago, KrzyPacu said: make -C /lib/modules/6.12.33-current-meson64/build M= modules_install Here M should be pointing to your path to the tm16xx-display folder. I think the PWD environment variable is affected by sudo. You can specify the PWD variable explicitly when calling make: sudo make PWD=$(pwd) module-install That should make it. 0 Quote
KrzyPacu Posted Friday at 03:06 PM Posted Friday at 03:06 PM I managed to install it but the display doesn't work. # display-utils -c cat: /sys/class/leds/display/num_digits: There is no such file or directory # display-utils -a cat: /sys/class/leds/display/num_digits: There is no such file or directory 0 Quote
Jean-Francois Lessard Posted Friday at 04:20 PM Author Posted Friday at 04:20 PM Have you looked for dmesg output about tm16xx after probing the driver? dmesg -c # clear kernel messages modprobe -r tm16xx # unload driver modprobe tm16xx # load driver dmesg # check for new kernel messages 0 Quote
KrzyPacu Posted Friday at 04:33 PM Posted Friday at 04:33 PM (edited) # modprobe -r tm16xx modprobe: ERROR: ../libkmod/libkmod-module.c:856 kmod_module_remove_module() could not remove 'tm16xx': Device or resource busy # dmesg # modprobe tm16xx # modprobe -r tm16xx modprobe: ERROR: ../libkmod/libkmod-module.c:856 kmod_module_remove_module() could not remove 'tm16xx': Device or resource busy Edited Friday at 04:35 PM by KrzyPacu 0 Quote
Jean-Francois Lessard Posted Friday at 04:45 PM Author Posted Friday at 04:45 PM There should have been an exception on first load that now prevent removing the module. You can force removal of the module but that can create unstable kernel side effects. You are better to reboot the device (you may need to unplug power if kernel refuses to reboot). Then after boot, check dmesg kernel messages (do not clear them first!) something like dmesg | grep tm16xx 0 Quote
KrzyPacu Posted Friday at 05:06 PM Posted Friday at 05:06 PM # dmesg | grep tm16xx [ 21.189046] tm16xx: loading out-of-tree module taints kernel. [ 21.190997] tm16xx 1-0024: Failed to set brightness: -6 [ 21.194407] tm16xx 1-0024: Failed to initialize display: -6 0 Quote
Jean-Francois Lessard Posted Friday at 05:19 PM Author Posted Friday at 05:19 PM What is your Android TV device model? What is the led controller model? Then what is your DTS configuration for the display client? 0 Quote
KrzyPacu Posted Friday at 05:53 PM Posted Friday at 05:53 PM Vontar X3 is the same as hk1-x3 and I used the one from hk1-x3. Here are the pictures because I didn't open mine: https://github.com/ophub/amlogic-s9xxx-armbian/issues/1006 0 Quote
KrzyPacu Posted Friday at 06:38 PM Posted Friday at 06:38 PM (edited) hk1-x3.conf I haven't opened my TV box but I saw a picture and it seems to me that the controller is "FD6551" Edited Friday at 09:20 PM by KrzyPacu 0 Quote
KrzyPacu Posted Saturday at 08:51 AM Posted Saturday at 08:51 AM Will disassembling the TV box help get this display working? The TV box looks like it's glued together, but if that helps, I can open it. 0 Quote
Jean-Francois Lessard Posted Saturday at 05:37 PM Author Posted Saturday at 05:37 PM No need to disassemble anything. Given your device has the same configuration as hk1-x3, you should rather use the corresponding device tree definition: make hk1-x3.dtb cp release/hk1-x3.dtb /boot/dtb/{YOUR_DTB_PATH}.dtb reboot 0 Quote
KrzyPacu Posted Saturday at 06:56 PM Posted Saturday at 06:56 PM 1 hour ago, Jean-Francois Lessard said: make hk1-x3.dtb cp release/hk1-x3.dtb /boot/dtb/{YOUR_DTB_PATH}.dtb reboot # dmesg | grep tm16xx [ 11.231194] tm16xx: loading out-of-tree module taints kernel. [ 11.233242] tm16xx 1-0024: Failed to set brightness: -6 [ 11.236531] tm16xx 1-0024: Failed to initialize display: -6 0 Quote
KrzyPacu Posted Sunday at 09:20 AM Posted Sunday at 09:20 AM I did everything again, as you wrote and it still doesn't work. So it looks like my TVbox has a different LED controller? 0 Quote
Jean-Francois Lessard Posted Sunday at 08:36 PM Author Posted Sunday at 08:36 PM @KrzyPacu Can you look at your full dmesg output (no filter on tm16xx)? I guess there are some other error messages prior to there filtered output. I don't think that you have a different controller. Maybe rather the pinout: which pins of the SoC of your TV box are wired to the controller and how they are declared in the device tree. Was your display working properly with the OpenVFD driver and the hk1-x3.conf VFD configuration file you posted? If so, the controller is good and it's probably the pin numbers described in the device tree that needs to be adjusted. My hk1-x3.dtso was converted from the OpenVFD configuration file, but the device hasn't been tested yet to my knowledge. So it might need some corrections. 0 Quote
Jean-Francois Lessard Posted 21 hours ago Author Posted 21 hours ago @KrzyPacu try with hk1-box.dtso instead: make hk1-box.dtb cp release/hk1-box.dtb /boot/dtb/{YOUR_DTB_PATH}.dtb reboot hk1-box.dtso has the same configuration as hk1-x3.dtso but with pins 63/64 instead 64/65. Original OpenVFD specify "Vontar X3" in hk1-box, not hk1-x3. If that still doesn't work, you need to start from a known working configuration, either OpenVFD or original Android firmware dtb. Then you can work backwards to understand your configuration and create the proper dtso. 0 Quote
KrzyPacu Posted 15 hours ago Posted 15 hours ago 23 hours ago, Jean-Francois Lessard said: Was your display working properly with the OpenVFD driver and the hk1-x3.conf VFD configuration file you posted? Yes it worked fine on the other Armbian OS. 5 hours ago, Jean-Francois Lessard said: try with hk1-box.dtso instead: Unfortunately it still doesn't work. 5 hours ago, Jean-Francois Lessard said: or original Android firmware dtb. android-vontar-x3.dts 0 Quote
Jean-Francois Lessard Posted 11 hours ago Author Posted 11 hours ago @KrzyPacu your Android DTS confirms the pinout of hk1-x3 fd628_dev { compatible = "amlogic,fd628_dev"; fd628_gpio_clk = <0x12 0x41 0x00>; fd628_gpio_dat = <0x12 0x40 0x00>; status = "okay"; }; 0x40 is data pin 64 0x41 is clock pin 65 So there must be something wrong with how you are copying the dtb to boot. Maybe to the wrong location. Ensure you have the proper dtb loaded at runtime by inspecting /proc/device-tree 0 Quote
Jean-Francois Lessard Posted 11 hours ago Author Posted 11 hours ago On 6/22/2025 at 4:36 PM, Jean-Francois Lessard said: Can you look at your full dmesg output (no filter on tm16xx)? I guess there are some other error messages prior to there filtered output. You have checked that neither 0 Quote
