After installing armbian bookworm the fans are always at maximum. Here is how I solved.
Trying to figure out what is not working I try to run the related service
systemctl start fancontrol.service
but it does not start. So I check the latest errors:
systemctl status fancontrol.service
I obtain
Failed ...fancontrol.service: Failed to locate executable /usr/sbin/fancontrol
so, fancontrol is simply not there and apt can't find it for installation.
I took the old sd card and copied the fancontrol to /usr/sbin/
Than make it executable with:
chmod +x /usr/sbin/fancontrol
than
systemctl enable fancontrol.service
As soon as I started the service, voilà, the fan started to... blowing only when needed: problem solved!
Attached you find the fancontrol file.
fancontrol
In K6.1 fan should still work,
https://github.com/armbian/build/pull/5392
while for 6.6
https://github.com/armbian/build/pull/5939
and 6.10, support was removed as it was too much work and no time:
https://github.com/armbian/build/blob/main/patch/kernel/archive/mvebu-6.10/92-mvebu-gpio-remove-hardcoded-timer-assignment.patch.disabled
For me the problem was only the lack of the fancontrol executable, everything else seems to work (although I can't tell if pwm or not).
So I thought I'd share this that might help keep still working hardware from being perceived as non-functional or obsolete: for the moment Armbian (Debian 12 Bookworm, Minimal / IOT) + Omv are working perfectly!
Thank you Igor!
Riccardo
I recently decided to reinstall an OS on my helios4, and I went with Ubuntu 24.04. I had a similar issue, but for me the only fix needed was to install fancontrol from apt
apt install fancontrol
The fans slowed down immediately after it finished installing.
