Rickyx Posted August 27 Posted August 27 After installing armbian bookworm the fans are always at maximum. Here is how I solved. Trying to figure out what is not working I try to run the related service systemctl start fancontrol.service but it does not start. So I check the latest errors: systemctl status fancontrol.service I obtain Failed ...fancontrol.service: Failed to locate executable /usr/sbin/fancontrol so, fancontrol is simply not there and apt can't find it for installation. I took the old sd card and copied the fancontrol to /usr/sbin/ Than make it executable with: chmod +x /usr/sbin/fancontrol than systemctl start fancontrol.service systemctl enable fancontrol.service As soon as I started the service, voilà, the fan started to... blowing only when needed: problem solved! Attached you find the fancontrol file. fancontrol 0 Quote
Igor Posted August 27 Posted August 27 4 hours ago, Rickyx said: After installing armbian bookworm the fans are always at maximum. In K6.1 fan should still work, https://github.com/armbian/build/pull/5392 while for 6.6 https://github.com/armbian/build/pull/5939 and 6.10, support was removed as it was too much work and no time: https://github.com/armbian/build/blob/main/patch/kernel/archive/mvebu-6.10/92-mvebu-gpio-remove-hardcoded-timer-assignment.patch.disabled 0 Quote
Rickyx Posted August 28 Author Posted August 28 For me the problem was only the lack of the fancontrol executable, everything else seems to work (although I can't tell if pwm or not). So I thought I'd share this that might help keep still working hardware from being perceived as non-functional or obsolete: for the moment Armbian (Debian 12 Bookworm, Minimal / IOT) + Omv are working perfectly! Thank you Igor! Riccardo 0 Quote
