Hello!
I have installed on Armbian 24.8.1 noble (ubuntu 24.04) .
Also I have enabled "UARTa" , "UARTc" in armbian-config utility.
In /boot/armbianEnv.txt file:
overlays=uartA uartC
for enable UART port.
There are many files /dev/ttyS[0-7] exists.
After this I try connected to this ports, but no success (minicom -D /dev/ttySx).
Python sripts with pyserial module
output: "i/o error".
The same problem I have noticed with previous versions of Armbian.
I have checked on other distributive (Khadas version of ubuntu server) the uart port is worked fine.
Does Armbian supports Khadas VIM3 UART?
It is a good idea, thank you, but
unfortunately, there is only one file /dev/ttyAML0 (console, imho) in /dev/ catalog.
In dmesg I see:
[    0.740076] ffd24000.serial: ttyAML6 at MMIO 0xffd24000 (irq = 15, base_baud = 1500000) is a meson_uart
[    0.740274] serial serial0: tty port ttyAML6 registered
but ttyAML6 is absent.
Edited by Sergetsp
