greg798 Posted 22 hours ago Share Posted 22 hours ago Hi. I'm having network problems at last armbian (Armbian_community_24.11.0-trunk.130_Orangepi3_bookworm_current_6.6.44_minimal). Link drops ethernet RTL8211E all the time and sometimes board won't come out of reboot. Any ideas? [ 2.392800] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found [ 2.392834] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found [ 2.393489] dwmac-sun8i 5020000.ethernet: PTP uses main clock [ 2.393545] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000) [ 2.405541] usb 2-1: USB disconnect, device number 2 [ 2.501691] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported [ 2.501720] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported [ 2.501728] dwmac-sun8i 5020000.ethernet: COE Type 2 [ 2.501738] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported [ 2.501747] dwmac-sun8i 5020000.ethernet: Normal descriptors [ 2.501755] dwmac-sun8i 5020000.ethernet: Chain mode enabled [ 2.677402] dwmac-sun8i 5020000.ethernet end0: renamed from eth0 [ 7.374514] dwmac-sun8i 5020000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 7.380876] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status. [ 7.422454] dwmac-sun8i 5020000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL) [ 7.422504] dwmac-sun8i 5020000.ethernet end0: No Safety Features support found [ 7.422518] dwmac-sun8i 5020000.ethernet end0: No MAC Management Counters available [ 7.422530] dwmac-sun8i 5020000.ethernet end0: PTP not supported by HW [ 7.423042] dwmac-sun8i 5020000.ethernet end0: configuring for phy/rgmii-id link mode [ 11.518341] dwmac-sun8i 5020000.ethernet end0: Link is Up - 1Gbps/Full - flow control off [ 16.296572] dwmac-sun8i 5020000.ethernet end0: Too many address, switching to promiscuous 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted 27 minutes ago Share Posted 27 minutes ago Do you have an old OPi3 or the LTS variant? They differ in network chip on the pcb. Please verify you are using the correct image for your board. 0 Quote Link to comment Share on other sites More sharing options...
