Odroid m1 Won't boot on recent images in armbian download section
Go to solution Solved by Mickynuts,
Hello, sorry for the tag (no odroid m1 tag) and if I'm in the wrong place.
I downloaded the image Armbian_24.8.3_ordoidm1_jammy_current_6.6.51_kde-neon-kisak-desktop
The image does not start without pressing rcy, so far normal. After flashing the mtd with armbian-installer and copying to SSD. The image still does not start. No display.
After trying several things and without success, I decided to try an old image:
Armbian_24.2.1_ordoidm1_jammy_current_6.6.16_xfce_desktop.
I here rcy boot, install, copy to SSD, flash mtd and reboot. And it works. So I tried image 6.6.51 kde Again. But without flashing the mtd. And there it boots without problems and no need for rcy.
So it seems that the last image and also the 24.2. 4 that I tried. We have a probably corrupted uboot.
I have the odroid m1 8gb.
hope this will allow others not to waste hours trying because of a corrupted uboot. (This was my first attempt with armbian on this card. Before I had petitboot.)
Sorry for my bad English. I used Google translate.
PS: I tried to make a bug report form. But you have to provide an armbianmonitor -u output or something like that. And that doesn't match the fact. The card doesn't even boot.
Edited by Mickynuts
To get help, you have to provide proper logs. In case of boot problems, these are serial console logs. https://debug.armbian.de
  • Solution
I don't need help anymore. As said. I used the uboot present in an earlier version. I didn't try the serial, because there weren't even any screens (I thought there wouldn't be a serial either). The card seemed to just do a reboot Every 5 seconds (depending on the LEDs on the network card and the LEDs on the SSD which flash 1x. I'm not going to try again now that I have a working installation. I just wanted to share with you Other beginners who are not used to this kind of tools and not have the serial cable.
Ok, then no further action needs to be taken and your solution can be used by others in the future.
I also don't need any other firmware because my current one works according to my needs.
And for an update, I know how to build and debug it if necessary.
In the meantime, I've moved to 2025.01 with HDMI support enabled, so I no longer need the serial console to interact with the firmware.
And boot menus easily allow the free choice of which option should currently be booted.
Edited by usual user
I did kind of manual bisect by commits to config/boards/odroidm1.conf
U-Boot 2024.04-armbian (Jan 29 2025 - 02:13:41 +0000)
commit 3215bf9f3699c2ee4bc741efe82065315e4ff46f
linux-u-boot-odroidm1-edge_24.8.0-trunk_arm64__2024.04-S2504-P3b44-Haddb-V73be-B4f92-R448a.deb is GOOD,
U-Boot 2024.07-armbian-2024.07-S3f77-P7e9c-Hfb3e-V8f4f-Bb66d-R448a (Jan 29 2025 - 02:30:21 +0000)
commit 268c2e85960978c90025bc18cf7d5f8e5cfbdab6
linux-u-boot-odroidm1-edge_24.8.0-trunk_arm64__2024.07-S3f77-P7e9c-Hfb3e-V8f4f-Bb66d-R448a.deb
is BAD
then I fix my Odroid M1 by doing
sudo apt install ./linux-u-boot-odroidm1-edge_24.8.0-trunk_arm64__2024.04-S2504-P3b44-Haddb-V73be-B4f92-R448a.deb
then
armbian-install → Install/Update the bootloader on MTD Flash
Ok, judging by your information, the regression takes place during the transition from U-Boot 2024.04 to 2024.07.
Since mainline U-Boot works perfect for me up to until 2025.01, it must be because of how it's built or what additional patches are applied.
Since it cannot be ruled out that it is due to a incompatible bootflow, it may be interesting to try it with my build.
If this also fails, it is possible to get more information from the HDMI output, even if access to the serial console is not available.
For the test it is perfectly sufficient to start the firmware from a prepared microSD card via RCY button.
The existing setup can stay completely unchanged.
I installed v2025.2.2 on sdcard and then performed armbian-install boot from spi + system on nvme. Without any error-messages system could afterwards not be booted without sdcard inserted. I assume I could remedy the situation with the
mentioned above and wonder, if anybody could provide that.
I searched without finding. Did you try to do as I did. By flashing a uboot of a previous version via an old image?
Hmm..
after Werner's hint I used
Armbian_24.2.1_Odroidm1_jammy_current_6.6.16.img.xz from oldarchive
but after armbian-install → Install/Update the bootloader on MTD Flash
no change of behavior, i.e. system does not boot without sd-card inserted.
I did not perform Boot from MTD flash - system on Sata ...
again, since the desired system is already on nvme.
Just for clarification: is my expectation correct, that system should boot without sd-card inserted (since bootloader is in MTD-flash), or is the effect of flashing MTD merely, that the system can use the bootloader of the sd-card without pressing RCY button?
Although I ordered a usb-serial adapter in order to be able to debug the situation, I would very much appreciate if the bootmenu could appear on hdmi Console - I wonder how this could be achieved - what build does Usual User refer to with "my build"?
Edited by antatarmbian
58 minutes ago, antatarmbian said:
clarification
Yes no need to rcy normally.
I took out the info from my m1 and a copy with cat of the mtd partitions. Maybe it will be useful to you (at your own risk)
Maybe wait for a confirmation if the command I made is functional. I made a backup of the partitions with cat /dev/mtd*  > name.bin (once for each partition)
In info you will find what I have as version and kernel. If it can help you.
Moderator, the 16mb overall is too heavy to insert directly (error uploading). I hope the cloud link is not a problem here. (valid for 48 hours)
https://quickshare.samsungcloud.com/cu9Cj7XDCZwy
Edited by Mickynuts
Having HDMI or video output work in U-Boot is more an exception rather than standard. While I don't know the reason I guess it is just too much effort to port such drivers into U-Boot while using the debug serial console is dirt cheap and always works.
Thanks - now I get the booloader menu from SPI on hdmi Console.
I wanted to experiment with efi-grub boot and installed the following image on sd
https://dl.armbian.com/uefi-arm64/Bookworm_current_cinnamon-backported-mesa
and it boots without problem, showing the grub-menu. I then did armbian-install -> nvme01 Install UEFI system with grub
to transfer system + /boot/efi to nvme. But still I cannot boot the system after removing the sd-card. the bootloader says sth like
nvme 0 no img found. So as workaround I performed an update-grub, so that at least the option to boot the system on nvme appears (and works) in sdcard grub-menu.
Any hint how I can render the nvme directly bootable from spi bootloader menu without the sdcard?
EXIT to the U-Boot console and report the output of the following command:
bootflow scan -l nvme
I don't know what the armbian-install does, but does it make a difference if you dd the same unmodified image to the NVME as you do to the microSD?
via dd img->nvme did the trick. One slight problem is the identical uuids of sdcard and nvme but it  does not make much sense anyway to use identical images on 2 devices plugged in at the same time.
Next step now will be populating the nvme with additional images
so thanks a lot for your helping hands
# cat /boot/armbianEnv.txt
verbosity=1
bootlogo=true
console=both
extraargs=cma=256M
overlay_prefix=rockchip-rk3568-hk
fdtfile=rockchip/rk3568-odroid-m1.dtb
rootdev=UUID=0a9f09a7-bbb5-493f-a7af-b0e62f4aff8e
rootfstype=ext4
It seems the UUID can be changed in `/boot/armbianEnv.txt`.
Current way of installing is as written on the download pages. It was verified with latest v24.11.2 image.
I can confirm that booting Odroid M1 from SD card does not work with U-Boot versions newer than 2024.04. Many thanks to IAV for providing a workaround. Perhaps most people are booting from NVMe now, so this issue has flown under the radar?
# Install U-Boot 24.5.1 (maps to upstream v2024.04)
apt-get install -y linux-u-boot-odroidm1-edge=24.5.1
# Freeze the package at that version
"printf 'linux-u-boot-odroidm1-edge hold\n' | sudo dpkg --set-selections"
# Flash SPI directly from the package artifacts (or via armbian-install)
flashcp -v /usr/lib/linux-u-boot-edge-odroidm1/idbloader.img /dev/mtd0
flashcp -v /usr/lib/linux-u-boot-edge-odroidm1/u-boot.itb /dev/mtd2
# Confirm
strings /dev/mtd0 | grep -m1 "U-Boot" # U-Boot SPL 2024.04 (Jan 10 2026 - 10:54:44 +0100)
strings /dev/mtd2 | grep -m1 "U-Boot" # FIT image for U-Boot with bl31 (TF-A)
Now I can boot from sdcard again w/o RCY button.
To use only ZFS on my system I compiled zfs into U-Boot. That worked but the problem was still with U-Boot's handling of the mmc1 somehow. Even though zfsls/zfsload were present in the SPI-flashed U-Boot, that build immediately reinitialized mmc1 in HS200 (1.8 V) mode and hit the “Card did not respond to voltage select! : -110” failure before the boot script could run. So the inability to boot the ZFS v28 pool was due to the SPI U-Boot’s bad MMC tuning, not the ZFS commands themselves.
For future reference I’ll leave here on how to built U-Boot with ZFS support from the upstream sources:
# Workspace & Dependencies
apt install git gcc-aarch64-linux-gnu bison flex device-tree-compiler libssl-dev make python3 ninja-build build-essential
mkdir -p ~/work/u-boot && cd ~/work/u-boot
# Upstream U-Boot
git clone --depth=1 --branch v2024.04 https://source.denx.de/u-boot/u-boot.git
# Firmare blobs
git clone --depth=1 https://github.com/rockchip-linux/rkbin.git
# Prepare .config
cd u-boot
cp configs/odroid-m1-rk3568_defconfig .config
scripts/config --file .config --enable CONFIG_CMD_ZFS
yes "" | olddefconfig
# Compile
make -j$(nproc) \
     BL31=../rkbin/bin/rk35/rk3568_bl31_v1.45.elf \
     ROCKCHIP_TPL=../rkbin/bin/rk35/rk3568_ddr_1560MHz_v1.23.bin
cp spl/u-boot-spl.bin /usr/lib/linux-u-boot-edge-odroidm1/idbloader.img
cp u-boot.itb        /usr/lib/linux-u-boot-edge-odroidm1/u-boot.itb
Edited by m1zfs
