deskwizard Posted November 25, 2015 Share Posted November 25, 2015 Good morning, I am trying to compile the lastest sources for the olinuxino-a20-micro and it fails on building libvdpau. VM guest is Ubuntu Mate 14.04 Here is what the actual error is (I left out the rest of the console log since it was fine): Cloning into '/home/deskwizard/A20-armbian/output/cache/sdcard/tmp/libvdpau-sunxi'... remote: Counting objects: 609, done. remote: Compressing objects: 100% (26/26), done. remote: Total 609 (delta 15), reused 1 (delta 1), pack-reused 582 Receiving objects: 100% (609/609), 299.91 KiB | 0 bytes/s, done. Resolving deltas: 100% (407/407), done. Checking connectivity... done. cc -MD -MP -MQ device.o -fpic -fvisibility=hidden -Wall -O3 -c device.c -o device.o cc -MD -MP -MQ presentation_queue.o -fpic -fvisibility=hidden -Wall -O3 -c presentation_queue.c -o presentation_queue.o cc -MD -MP -MQ surface_output.o -fpic -fvisibility=hidden -Wall -O3 -c surface_output.c -o surface_output.o cc -MD -MP -MQ surface_video.o -fpic -fvisibility=hidden -Wall -O3 -c surface_video.c -o surface_video.o cc -MD -MP -MQ surface_bitmap.o -fpic -fvisibility=hidden -Wall -O3 -c surface_bitmap.c -o surface_bitmap.o cc -MD -MP -MQ video_mixer.o -fpic -fvisibility=hidden -Wall -O3 -c video_mixer.c -o video_mixer.o cc -MD -MP -MQ decoder.o -fpic -fvisibility=hidden -Wall -O3 -c decoder.c -o decoder.o decoder.c: In function 'vdp_decoder_create': decoder.c:63:7: error: 'VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE' undeclared (first use in this function) case VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE: ^ decoder.c:63:7: note: each undeclared identifier is reported only once for each function it appears in decoder.c:64:7: error: 'VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH' undeclared (first use in this function) case VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH: ^ decoder.c: In function 'vdp_decoder_query_capabilities': decoder.c:188:7: error: 'VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE' undeclared (first use in this function) case VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE: ^ decoder.c:189:7: error: 'VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH' undeclared (first use in this function) case VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH: ^ make: *** [decoder.o] Error 1 cp: cannot stat ‘/home/deskwizard/A20-armbian/output/cache/sdcard/tmp/libvdpau-sunxi/libvdpau_sunxi.so.1’: No such file or directory Any pointers on what the issue might be or ways to figure it out ? Thanks, Deskwizard Link to comment Share on other sites More sharing options...
Igor Posted November 25, 2015 Share Posted November 25, 2015 I noticed few days ago ... no clue at the moment but you can try with alternative kernel: https://github.com/igorpecovnik/lib/blob/def90eb1997a267627882c186cb603bbc1dde92c/configuration.sh Comment line: 67,68 and 70 Link to comment Share on other sites More sharing options...
deskwizard Posted November 26, 2015 Author Share Posted November 26, 2015 Hi Igor, Thanks for the quick reply. Unfortunately that did not work. I'm going to try mainstream instead of legacy but I think I will get the same result as the kernel compiles ok, but libvdpau fails... missing headers maybe? I'll look into that when I have more free time I'll have a look at what repository it clones and have a look in case I could fix. Charles Link to comment Share on other sites More sharing options...
Igor Posted November 26, 2015 Share Posted November 26, 2015 OK, will check later today. I must have done something ... It's not possible to compile video acceleration within mainline kernel. There is nothing you can do. Link to comment Share on other sites More sharing options...
matteobp Posted December 2, 2015 Share Posted December 2, 2015 Hi. I'm having the same problem on Banana Pi M1+. I have a custom build Debian Jessie with kernel 3.4.109 and desktop XFCE, and when I run this command mpv --vo=vdpau --hwdec=vdpau --hwdec-codecs=all big_buck_bunny_1080p_H264_AAC_25fps_7200K.MP4 I have this error Failed to open VDPAU backend libvdpau_sunxi.so: cannot open shared object file: No such file or directory I tried to compile the libvdpau_sunxi.so by myself with git clone https://github.com/linux-sunxi/libvdpau-sunxi.git make and this is the output root@bananapipro:~/libvdpau-sunxi# make cc -MD -MP -MQ device.o -fpic -fvisibility=hidden -Wall -O3 -c device.c -o device.o cc -MD -MP -MQ presentation_queue.o -fpic -fvisibility=hidden -Wall -O3 -c presentation_queue.c -o presentation_queue.o cc -MD -MP -MQ surface_output.o -fpic -fvisibility=hidden -Wall -O3 -c surface_output.c -o surface_output.o cc -MD -MP -MQ surface_video.o -fpic -fvisibility=hidden -Wall -O3 -c surface_video.c -o surface_video.o cc -MD -MP -MQ surface_bitmap.o -fpic -fvisibility=hidden -Wall -O3 -c surface_bitmap.c -o surface_bitmap.o cc -MD -MP -MQ video_mixer.o -fpic -fvisibility=hidden -Wall -O3 -c video_mixer.c -o video_mixer.o cc -MD -MP -MQ decoder.o -fpic -fvisibility=hidden -Wall -O3 -c decoder.c -o decoder.o decoder.c: In function ‘vdp_decoder_create’: decoder.c:63:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE’ undeclared (first use in this function) case VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE: ^ decoder.c:63:7: note: each undeclared identifier is reported only once for each function it appears in decoder.c:64:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH’ undeclared (first use in this function) case VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH: ^ decoder.c: In function ‘vdp_decoder_query_capabilities’: decoder.c:188:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE’ undeclared (first use in this function) case VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE: ^ decoder.c:189:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH’ undeclared (first use in this function) case VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH: ^ Makefile:43: recipe for target 'decoder.o' failed make: *** [decoder.o] Error 1 Thanks Link to comment Share on other sites More sharing options...
Igor Posted December 2, 2015 Share Posted December 2, 2015 Sources are broken. I could compile the driver with going little back. Issue this before make git checkout 906c36ed45ceb53fecd5fc72e821c11849eeb1a3 1 Link to comment Share on other sites More sharing options...
matteobp Posted December 2, 2015 Share Posted December 2, 2015 Perfect, it works. Thanks Link to comment Share on other sites More sharing options...
pongo2g Posted December 21, 2015 Share Posted December 21, 2015 Hi, I'm running into the same issue using the automatic build script. How/where do I have to apply this "git checkout" so the compilation will run successfully? BTW, I noticed shortly before the error message mentioned in the 1st post the following message in between: fatal: Not a git repository (or any of the parent directories): .git This happens in general when not in the correct directory - may be these problems are related? Unfortunately I cannot show the position during compiling process, because the installer.log does not contain this output and the script breaks my desktop somehow (Ubuntu 14.04 LTS standard installation): After I have run it, most standard commands like "cat" make the terminal window close itself, so I need to work from console where I have no scroll buffer... Link to comment Share on other sites More sharing options...
Igor Posted December 21, 2015 Share Posted December 21, 2015 If you don't know how to fix rather start from clean source. Link to comment Share on other sites More sharing options...
pongo2g Posted December 21, 2015 Share Posted December 21, 2015 hmmm, I followed the steps mentioned here: http://www.armbian.com/using-armbian-tools/ ...so I assume this is the "cleanest" source I can get. I haven't digged too deep into how the scripts interact, so I didn't find where and how libvdbau is cloned and compiled yet - I hoped there would be an easy fix. BTW, I really like this tool! Link to comment Share on other sites More sharing options...
Igor Posted December 21, 2015 Share Posted December 21, 2015 How/where do I have to apply this "git checkout" so the compilation will run successfully? Now I see ... You don't need to apply this fix anymore ... I already add it to the script so it should be possible to compile. Thanks! Link to comment Share on other sites More sharing options...
pongo2g Posted December 21, 2015 Share Posted December 21, 2015 unfortunately not: Checking connectivity... done. fatal: Not a git repository (or any of the parent directories): .git cc —MD -MP —M0 device.o —fpic -fvisibility=hidden —Hall -03 —c device.c -o device.o cc -MD -MP -M0 presentation_queue.o -fpic —fvisibility:hidden -Hall -03 —c presentation_queue.c -o presentation_queue.o cc -MD -MP -H0 surface_output.o -fpic -fvisibility=hidden -Hall -03 —c surface_output.c —o surface_output.o cc —MD -MP -M0 surface_video.o —fpic —fvisibility=hidden -Hall -03 —c surface_video.c —o surface_video.o cc —MD -MP —M0 surface_bitmap.o —fpic -fvisibility=hidden —Hall -03 —c surface_bitmap.c —o surface_bitmap.o cc —MD -MP —M0 uideo_mixer.o —fpic —fvisibility=hidden —Hall -03 —c video_mixer.c —o video_mixer.o cc -MD -MP -H0 decoder.o -fpic -fvisibility=hidden -Hall -03 —c decoder.c —o decoder.o decoder.c: In function ‘vdp_decoder_create’: decoder.c:63:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE’ undeclared (first use in this function) decoder.c:63:7: note: each undeclared identifier is reported only once for each function it appears in decoder.c:64:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH’ undeclared (first use in this function) decoder.c:73:7: error: ‘VDP_DECODER_PROFILE_HEVO_MAIN’ undeclared (first use in this function) decoder.c: In function ‘vdp_decoder_query_capabilities’: decoder.c:19S:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE’ undeclared (first use in this function) decoder.c:196:?: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH’ undeclared (first use in this function) decoder.c:20S:?: error: ‘VDP_DECODER_PROFILE_HEVO_MAIN’ undeclared (first use in this function) decoder.c:206:16: error: ‘VDP_DECODER_LEVEL_HEVC_5’ undeclared (first use in this function) make: *** [decoder.o] Error 1 cp: cannot stat ‘/home/tom/output/cache/sdcard/tmp/libvdpau—sunxi/libvdpau_sunxi.so.1’: No such file or directory [ o.K. ] Installing external applications [ USB redirector ] [ o.K. ] Installing external applications [ RT8192 driver ] (Screenshot taken during the important part and converted by OCR, so there may be typos) The same errors still occur - also you can see the git error on top I mentioned before. Oh - I forgot to mention, trying to compile for Cubieboard2, Debian Wheezy (3.4 kernel version), with Desktop. Link to comment Share on other sites More sharing options...
Igor Posted December 22, 2015 Share Posted December 22, 2015 I can confirm that compilation is broken. Checking why ... Link to comment Share on other sites More sharing options...
zador.blood.stained Posted December 22, 2015 Share Posted December 22, 2015 - git clone https://github.com/linux-sunxi/libvdpau-sunxi.git $DEST/cache/sdcard/tmp/libvdpau-sunxi + git clone https://github.com/linux-sunxi/libvdpau-sunxi.git $DEST/cache/sdcard/tmp/libvdpau-sunxi + # temporaly fix + chroot $DEST/cache/sdcard /bin/bash -c "git checkout 906c36ed45ceb53fecd5fc72e821c11849eeb1a3" chroot $DEST/cache/sdcard /bin/bash -c "cd /tmp/libvdpau-sunxi && make" Igor, you need to execute "git checkout" in sdcard's /tmp/libvdpau-sunxi directory, not in sdcard's root. Something like this: chroot $DEST/cache/sdcard /bin/bash -c "cd /tmp/libvdpau-sunxi; git checkout 906c36ed45ceb53fecd5fc72e821c11849eeb1a3" Link to comment Share on other sites More sharing options...
Igor Posted December 22, 2015 Share Posted December 22, 2015 Finding your own mistakes is sometimes hard. Thank you! Edit: It's working now @branch master Link to comment Share on other sites More sharing options...
pongo2g Posted December 22, 2015 Share Posted December 22, 2015 I have removed lib, output and source directories to start from scratch, but I still see the error? (This time I started "sudo ./compile.sh 2>compile.log" - below the last lines) autoreconf: Leaving directory `.' fbdev.c: In function 'FBDevPciProbe': fbdev.c:289:9: warning: assignment discards 'const' qualifier from pointer target type [enabled by default] fbdev.c: In function 'FBDevProbe': fbdev.c:348:10: warning: assignment discards 'const' qualifier from pointer target type [enabled by default] fbdev.c: In function 'FBDevPreInit': fbdev.c:467:2: warning: passing argument 3 of 'fbdevHWInit' discards 'const' qualifier from pointer target type [enabled by default] /usr/include/xorg/fbdevhw.h:21:23: note: expected 'char *' but argument is of type 'const char *' Cloning into '/home/tom/output/cache/sdcard/tmp/libvdpau-sunxi'... fatal: Not a git repository (or any of the parent directories): .git decoder.c: In function ‘vdp_decoder_create’: decoder.c:63:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE’ undeclared (first use in this function) decoder.c:63:7: note: each undeclared identifier is reported only once for each function it appears in decoder.c:64:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH’ undeclared (first use in this function) decoder.c:73:7: error: ‘VDP_DECODER_PROFILE_HEVC_MAIN’ undeclared (first use in this function) decoder.c: In function ‘vdp_decoder_query_capabilities’: decoder.c:195:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_BASELINE’ undeclared (first use in this function) decoder.c:196:7: error: ‘VDP_DECODER_PROFILE_H264_CONSTRAINED_HIGH’ undeclared (first use in this function) decoder.c:205:7: error: ‘VDP_DECODER_PROFILE_HEVC_MAIN’ undeclared (first use in this function) decoder.c:206:16: error: ‘VDP_DECODER_LEVEL_HEVC_5’ undeclared (first use in this function) make: *** [decoder.o] Error 1 cp: cannot stat ‘/home/tom/output/cache/sdcard/tmp/libvdpau-sunxi/libvdpau_sunxi.so.1’: No such file or directory What am I doing wrong? Link to comment Share on other sites More sharing options...
Igor Posted December 22, 2015 Share Posted December 22, 2015 Are you using branch master? You need to alter compile.sh to get proper script.Poslano z mojega MI 2S z uporabo Tapatalk Link to comment Share on other sites More sharing options...
pongo2g Posted December 22, 2015 Share Posted December 22, 2015 yes: tom@ubuntu:~$ cd lib tom@ubuntu:~/lib$ git branch * master second Link to comment Share on other sites More sharing options...
Igor Posted December 23, 2015 Share Posted December 23, 2015 Hmm. The only change is this: https://github.com/igorpecovnik/lib/blob/master/desktop.sh#L100 If you changed anything to lib it's not updating. No ideas at this time of the day Link to comment Share on other sites More sharing options...
pongo2g Posted December 23, 2015 Share Posted December 23, 2015 I have only added "git checkout master" above the last "if" block to compile.sh because I want to have a stable "starting point" before I try any experiments. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted December 23, 2015 Share Posted December 23, 2015 Did you check if you have the latest version of repository in lib directory and if there are changes that can prevent checkout? (Output of "git status" and "git log -n 1") Link to comment Share on other sites More sharing options...
pongo2g Posted December 23, 2015 Share Posted December 23, 2015 I have deleted all folders, only the compile.sh was left, so everything was reloaded. Currently I'm not near that machine, I will provide the output later. Anyway thanks to both of you for your assistance! €dit: "git status" shows I was on branch "second"! I have overlooked that in case of a fresh download I need to descend to lib first. Will give it another try now. 2nd €dit: "git clone --depth 1" does only contain the "second" branch, my previous assumption was wrong. I couldn't switch to the master branch, git always told me it doesn't know this. Now I changed the line to "git clone -b master -- depth 1 [...]". Next try. Link to comment Share on other sites More sharing options...
pongo2g Posted December 23, 2015 Share Posted December 23, 2015 ok, this worked, yay! One error remained but looks not critical: ln: failed to create symbolic link '/home/tom/output/cache/sdcard/usr/lib/vdpau/libvdpau_sunxi.so.1': File exists Now I'll have to do some tests with the image, but that probably won't happen this year... Thanks for your quick support! 1 Link to comment Share on other sites More sharing options...
