vhlemoine Posted November 26, 2015 Posted November 26, 2015 After downloading and installing (legacy ubuntu trusty) v 4.5 and doing apt-get update && apt-get upgrade (to v4.6) I ran nand-sata-install to boot and run from nand, my board won't boot because of script is invalid and unable to parser boot.ini. I still can boot from my SD-card the following information is displayed boot0 version : 1.5.0 dram size =1024 Succeed in opening nand flash. Succeed in reading Boot1 file head. The size of Boot1 is 0x00056000. The file stored in 0X00000000 of block 2 is perfect. Check is correct. Ready to disable icache. Succeed in loading Boot1. Jump to Boot1. [ 0.177] boot1 version : 1.5.0 [ 0.177] pmu type = 3 [ 0.178] bat vol = 0 [ 0.210] axi:ahb:apb=3:2:2 [ 0.210] set dcdc2=1400, clock=1008 successed [ 0.212] key [ 0.225] no key found [ 0.225] flash init start [ 0.259] flash init finish [ 0.261] fs init ok [ 0.263] fattype FAT16 [ 0.263] fs mount ok [ 0.269] script finish [ 0.270] power finish [ 0.270] storage_type=0 [ 0.280] BootMain start [ 0.280] 0 [ 0.311] script is invalid [ 0.312] unable to parser boot.ini [ 0.313] try to fel in 1 secend Any idea what might the problem
Igor Posted November 26, 2015 Posted November 26, 2015 Let's check first if your upgrade was successful ? The script is new, old one should be removed on upgrade since it's deprecated and probably won't work. What do you get: which nand-sata-install and ls -l /boot
vhlemoine Posted November 26, 2015 Author Posted November 26, 2015 which nand-sata-install /usr/sbin/nand-sata-install (the one with 3 options (1.boot from NAND, system on NAND, 2 boot from NAND system on SATA, 3 Boot from SD, system on SATA) ls -l /boot (sd card) total 13484 drwxr-xr-x 2 root root 4096 Nov 24 17:36 bin -rw-r--r-- 1 root root 6944 Oct 12 08:37 boot.bmp -rw-r--r-- 1 root root 1804 Oct 12 08:53 boot.cmd -rw-r--r-- 1 root root 1876 Oct 12 08:53 boot.scr -rw-r--r-- 1 root root 94895 Nov 23 17:36 config-3.4.110-sun4i -rw-r--r-- 1 root root 3130889 Oct 12 08:37 initrd.img-3.4.109-sun4i -rw-r--r-- 1 root root 3131868 Nov 24 17:39 initrd.img-3.4.110-sun4i lrwxrwxrwx 1 root root 24 Oct 12 08:38 script.bin -> /boot/bin/cubieboard.bin -rw-r--r-- 1 root root 1941812 Nov 23 17:36 System.map-3.4.110-sun4i -rwxr-xr-x 1 root root 5473704 Nov 23 17:36 vmlinuz-3.4.110-sun4i lrwxrwxrwx 1 root root 27 Nov 24 17:38 zImage -> /boot/vmlinuz-3.4.110-sun4i ls -l /boot (on nand1) total 5854 drwxr-xr-x 3 root root 16384 Jan 1 1970 . drwxr-xr-x 24 root root 4096 Nov 25 09:46 .. -rwxr-xr-x 1 root root 84132 Nov 23 18:50 boot.axf -rwxr-xr-x 1 root root 116 Nov 23 18:50 boot.ini drwxr-xr-x 2 root root 2048 Nov 24 17:36 linux -rwxr-xr-x 1 root root 43724 Nov 25 11:33 script.bin -rwxr-xr-x 1 root root 361212 Nov 23 18:50 u-boot.bin -rwxr-xr-x 1 root root 145 Nov 25 11:33 uEnv.txt -rwxr-xr-x 1 root root 5473768 Nov 25 11:33 uImage
technik007_cz Posted November 26, 2015 Posted November 26, 2015 I tested this new script on debian Jessie and it is working. Could you post output of this command? ls -la /usr/sbin/nand-sata-install
vhlemoine Posted November 26, 2015 Author Posted November 26, 2015 ls -la /usr/sbin/nand-sata-install -rwxr-xr-x 1 root root 10820 Nov 23 18:50 /usr/sbin/nand-sata-install
Igor Posted November 26, 2015 Posted November 26, 2015 Yes, it's a bug. It will be gone in next update ... if you overwrite files on nand boot with this: https://github.com/igorpecovnik/lib/tree/second/scripts/nand-sata-install/usr/lib/nand-sata-install/a10/bootloader it should boot. Please try.
vhlemoine Posted November 27, 2015 Author Posted November 27, 2015 Copied those files to /dev/nand1 and reboot. Now a new error shows up. HELLO! BOOT0 is starting! boot0 version : 1.5.0 dram size =1024 Succeed in opening nand flash. Succeed in reading Boot1 file head. The size of Boot1 is 0x00056000. The file stored in 0X00000000 of block 2 is perfect. Check is correct. Ready to disable icache. Succeed in loading Boot1. Jump to Boot1. [ 0.178] boot1 version : 1.5.0 [ 0.178] pmu type = 3 [ 0.179] bat vol = 0 [ 0.211] axi:ahb:apb=3:2:2 [ 0.211] set dcdc2=1400, clock=1008 successed [ 0.213] key [ 0.226] no key found [ 0.226] flash init start [ 0.260] flash init finish [ 0.262] fs init ok [ 0.264] fattype FAT16 [ 0.264] fs mount ok [ 0.270] script finish [ 0.271] power finish [ 0.271] storage_type=0 [ 0.277] elf file header magic not match [ 0.277] elf file c:\boot.axf load fail ls /mnt/bootfs/ -la (mount /dev/nand1 /mnt/bootfs) total 5506 drwxr-xr-x 3 root root 16384 Jan 1 1970 . drwxr-xr-x 4 root root 4096 Nov 25 10:49 .. -rwxr-xr-x 1 root root 30593 Nov 27 07:59 boot.axf -rwxr-xr-x 1 root root 32479 Nov 27 07:59 boot.ini drwxr-xr-x 2 root root 2048 Nov 24 17:36 linux -rwxr-xr-x 1 root root 43724 Nov 25 11:33 script.bin -rwxr-xr-x 1 root root 30614 Nov 27 07:59 u-boot.bin -rwxr-xr-x 1 root root 145 Nov 25 11:33 uEnv.txt -rwxr-xr-x 1 root root 5473768 Nov 25 11:33 uImage
Igor Posted November 27, 2015 Posted November 27, 2015 There is something wrong with a file - they are wrong size. Check if you download files properly (RAW). I had the same error and I only copy those files over and it's booting fine.
vhlemoine Posted November 27, 2015 Author Posted November 27, 2015 How did you copy the files? I used wget https//.../boot.axf etc
Igor Posted November 27, 2015 Posted November 27, 2015 1. git clone https://github.com/igorpecovnik/lib cd lib/scripts/nand-sata-install/usr/lib/nand-sata-install/a10/bootloader rsync -aqc * /XXXXXXXXXXXXXXXXXX # directory where is your /dev/nand1 mounted or file by file, this way: 2. RAW github dl wget https://github.com/igorpecovnik/lib/raw/second/scripts/nand-sata-install/usr/lib/nand-sata-install/a10/bootloader/boot.axf
vhlemoine Posted November 27, 2015 Author Posted November 27, 2015 Nope. No cheese! Ran this: git clone https://github.com/igorpecovnik/libcd lib/scripts/nand-sata-install/usr/lib/nand-sata-install/a10/bootloaderrsync -aqc * /mnt/bootfs Reboot and (old) error is back again HELLO! BOOT0 is starting! boot0 version : 1.5.0 dram size =1024 Succeed in opening nand flash. Succeed in reading Boot1 file head. The size of Boot1 is 0x00056000. The file stored in 0X00000000 of block 2 is perfect. Check is correct. Ready to disable icache. Succeed in loading Boot1. Jump to Boot1. [ 0.178] boot1 version : 1.5.0 [ 0.178] pmu type = 3 [ 0.179] bat vol = 0 [ 0.211] axi:ahb:apb=3:2:2 [ 0.211] set dcdc2=1400, clock=1008 successed [ 0.213] key [ 0.226] no key found [ 0.226] flash init start [ 0.260] flash init finish [ 0.262] fs init ok [ 0.264] fattype FAT16 [ 0.264] fs mount ok [ 0.270] script finish [ 0.271] power finish [ 0.271] storage_type=0 [ 0.281] BootMain start [ 0.281] 0 [ 0.314] script is invalid [ 0.314] unable to parser boot.ini [ 0.315] try to fel in 1 secend ls /mnt/bootfs/ -la total 5854 drwxr-xr-x 3 root root 16384 Jan 1 1970 . drwxr-xr-x 4 root root 4096 Nov 25 10:49 .. -rwxr-xr-x 1 root root 84132 Nov 27 08:45 boot.axf -rwxr-xr-x 1 root root 116 Nov 27 08:45 boot.ini drwxr-xr-x 2 root root 2048 Nov 27 08:45 linux -rwxr-xr-x 1 root root 43724 Nov 25 11:33 script.bin -rwxr-xr-x 1 root root 361212 Nov 27 08:45 u-boot.bin -rwxr-xr-x 1 root root 145 Nov 25 11:33 uEnv.txt -rwxr-xr-x 1 root root 5473768 Nov 25 11:33 uImage
Igor Posted November 27, 2015 Posted November 27, 2015 Now I am a bit consed. I just build a new image for A10 from clean sources and install it to NAND with root on SATA drive. Zero problems. What's clean image different from upgrade? I'll upload a complete pack later and try that first. There is one common issues .. sometimes, when NANDs boot part gets corrupted it's necessary to install stock Android / Ubuntu to NAND with factory tools (Phoenix suite) and do the install part again. It doean't look that you need to do this but it's an option to try.
