lnsider Posted November 26, 2015 Share Posted November 26, 2015 Hi Igor, I want to compile a new kernel on HB. I do following steps: export ARCH=arm export CROSS_COMPILE=/usr/bin/arm-linux-gnueabihf- make imx_v7_cbi_hb_defconfig make If make is in process, I become an error: /bin/sh: 1: /usr/bin/arm-linux-gnueabihf-ld: not found make[1]: *** [init/mounts.o] Error 127 make: *** [init] Error 2 how can I fix that? Link to comment Share on other sites More sharing options...
0 wildcat_paris Posted November 26, 2015 Share Posted November 26, 2015 humm. my guess your Armbian tool environment is not setup properly a recent install gives root@d1dfc6648c59:/# file /usr/bin/arm-linux-gnueabihf-ld /usr/bin/arm-linux-gnueabihf-ld: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=481a5f6210c1256f352b9751f669265f81f90885, stripped so /usr/bin/arm-linux-gnueabihf-ld file exists. try to start a fresh install http://www.armbian.com/using-armbian-tools/ Link to comment Share on other sites More sharing options...
0 lnsider Posted November 27, 2015 Author Share Posted November 27, 2015 wrong message Link to comment Share on other sites More sharing options...
0 Igor Posted November 27, 2015 Share Posted November 27, 2015 Huh, you want to compile natively, on Hummingboard? Than you leave CROSS_COMPILE out and only type: make ARCH=arm But that's just a start. Link to comment Share on other sites More sharing options...
0 wildcat_paris Posted November 27, 2015 Share Posted November 27, 2015 wrong message sorry, wrong reply, if you intend to compile natively as Igor suggests :-) Link to comment Share on other sites More sharing options...
0 lnsider Posted December 1, 2015 Author Share Posted December 1, 2015 Huh, you want to compile natively, on Hummingboard? Than you leave CROSS_COMPILE out and only type: make ARCH=arm But that's just a start. What are you meaning with "just a start"? Link to comment Share on other sites More sharing options...
0 Igor Posted December 1, 2015 Share Posted December 1, 2015 That means this is as start of the process. Usually you need to issue also: make modules and make modules_install make dtbs When done - if compilation succeeded - you need to copy zImage, modules and DTBS to proper location. Link to comment Share on other sites More sharing options...
0 lnsider Posted January 18, 2016 Author Share Posted January 18, 2016 Hi Igor, I made everything as you told, but further "Uncompressing Linux... done, booting the kernel" hummingboard will not load. U-Boot SPL 2013.10-rc4-sun7i (Oct 11 2015 - 20:45:45) Boot Device: SD1 spl: error reading image u-boot.img, err - -1 Load image from RAW... U-Boot 2013.10-rc4-sun7i (Oct 11 2015 - 20:45:45) CPU: Freescale i.MX6SOLO rev1.1 at 792 MHz Reset cause: POR Board: MX6-HummingBoard DRAM: 512 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 mmc0 is current device ** File not found /boot.scr ** ** File not found /uEnv.txt ** ** File not found /zImage ** ** File not found /uImage ** 437 bytes read in 136 ms (2.9 KiB/s) Running bootscript from mmc ... ## Executing script at 10800000 33295 bytes read in 332 ms (97.7 KiB/s) 6310896 bytes read in 469 ms (12.8 MiB/s) Kernel image @ 0x12000000 [ 0x000000 - 0x604bf0 ] ## Flattened Device Tree blob at 18000000 Booting using the fdt blob at 0x18000000 Using Device Tree in place at 18000000, end 1800b20e Starting kernel ... Uncompressing Linux... done, booting the kernel. Link to comment Share on other sites More sharing options...
0 Igor Posted January 18, 2016 Share Posted January 18, 2016 I don't see any problems ... there is no output to serial console, unless specified ... first boot takes little longer, so you need to wait 1-2min to get login prompt. One reboot is in the middle ... not any more in newer Jessie and Trusty builds. Next edit and change console=ttymxc0,115200 and change loglevel to 7 in boot.cmd, convert to boot.scr ... Than you should see much more. If you did not compile on X86 Ubuntu I can't say what went wrong Link to comment Share on other sites More sharing options...
0 lnsider Posted January 19, 2016 Author Share Posted January 19, 2016 Hi Igor, new message: U-Boot 2013.10-rc4-sun7i (Oct 11 2015 - 20:45:45) CPU: Freescale i.MX6SOLO rev1.1 at 792 MHz Reset cause: POR Board: MX6-HummingBoard DRAM: 512 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: FEC [PRIME] (Re)start USB... USB0: USB EHCI 1.00 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found scanning usb for ethernet devices... 0 Ethernet Device(s) found Hit any key to stop autoboot: 0 mmc0 is current device 64 bytes read in 111 ms (0 Bytes/s) Running bootscript from mmc ... ## Executing script at 10800000 Wrong image format for "source" command 466 bytes read in 139 ms (2.9 KiB/s) Running bootscript from mmc ... ## Executing script at 10800000 setenv - set environment variables Usage: setenv [-f] name value ... - [forcibly] set environment variable 'name' to 'value ...' setenv [-f] name - [forcibly] delete environment variable 'name' ** File not found /boot/dtb/ ** 6310896 bytes read in 469 ms (12.8 MiB/s) Kernel image @ 0x12000000 [ 0x000000 - 0x604bf0 ] ## Flattened Device Tree blob at 18000000 Booting using the fdt blob at 0x18000000 reserving fdt memory region: addr=18000000 size=9000 Using Device Tree in place at 18000000, end 1800bfff Starting kernel ... Uncompressing Linux... done, booting the kernel. I think the problem is ** File not found /boot/dtb/ ** but why, I´ve copied all dtb´s to SD card Compiled on Ubuntu x64 Link to comment Share on other sites More sharing options...
0 Igor Posted January 19, 2016 Share Posted January 19, 2016 If this parameter is not defined than it's usually not on the lowest number ... try to boot without or just add it after console parameter ... console=ttymxc0,115200 loglevel=7 Link to comment Share on other sites More sharing options...
0 lnsider Posted January 19, 2016 Author Share Posted January 19, 2016 If this parameter is not defined than it's usually not on the lowest number ... try to boot without or just add it after console parameter ... console=ttymxc0,115200 loglevel=7 setenv bootargs root=/dev/mmcblk0p1 rootfstype=ext4 rootwait console=console=ttymxc0,115200 loglevel=7 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 rd.dm=0 rd.luks=0 rd.lvm=0 raid=noautodetect pci=nomsi ahci_imx.hotplug=1 con$ ext2load mmc 0 0x18000000 /boot/dtb//boot/dtb/${fdt_file} ext2load mmc 0 0x12000000 /boot/zImage bootz 0x12000000 - 0x18000000 defined, but the message is the same Link to comment Share on other sites More sharing options...
0 Igor Posted January 19, 2016 Share Posted January 19, 2016 CPU: Freescale i.MX6SOLO rev1.1 at 792 MHz If you have a single core Hummingboard than this could be a problem. Those builds are designed and tested for dual and quad ... Ask Solidrun what to do in such case. The kernel which we use is more or less stock. I never study differences between single and dual/quad. Link to comment Share on other sites More sharing options...
0 lnsider Posted January 19, 2016 Author Share Posted January 19, 2016 Your compiled linux build is working on single core HummingBoard Link to comment Share on other sites More sharing options...
0 zador.blood.stained Posted January 19, 2016 Share Posted January 19, 2016 setenv - set environment variables Usage: setenv [-f] name value ... - [forcibly] set environment variable 'name' to 'value ...' setenv [-f] name - [forcibly] delete environment variable 'name' This in u-boot output is actually an error message, most likely due to missing quotes around setenv second argument - kernel argument list is too long to leave it unquoted. You should quote kernel argument list in your boot script. Also you shoud change double slash to single and fix path in dtb file path (there is a warning or error message about it too). Also setenv line in your post doesn't look right with 'con$' argument at the end, please check if this is intended or copy-paste error. Also serial console argument was wrong (console=console=...) setenv bootargs "root=/dev/mmcblk0p1 rootfstype=ext4 rootwait console=ttymxc0,115200 loglevel=7 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 rd.dm=0 rd.luks=0 rd.lvm=0 raid=noautodetect pci=nomsi ahci_imx.hotplug=1" ext2load mmc 0 0x18000000 /boot/dtb/${fdt_file} ext2load mmc 0 0x12000000 /boot/zImage bootz 0x12000000 - 0x18000000 Edit: Fixed path and serial console arguments. @Igor Serial console device name should be case-sensitive, are you sure that "ttymxc0" is all lowercase (just to be sure)? Link to comment Share on other sites More sharing options...
0 Igor Posted January 19, 2016 Share Posted January 19, 2016 Oh, true ... quotes. I completely overlooked that problem ttymxc0 yes, lower case. Link to comment Share on other sites More sharing options...
0 lnsider Posted January 19, 2016 Author Share Posted January 19, 2016 setenv - set environment variables Usage: setenv [-f] name value ... - [forcibly] set environment variable 'name' to 'value ...' setenv [-f] name - [forcibly] delete environment variable 'name' This in u-boot output is actually an error message, most likely due to missing quotes around setenv second argument - kernel argument list is too long to leave it unquoted. You should quote kernel argument list in your boot script. Also you shoud change double slash to single and fix path in dtb file path (there is a warning or error message about it too). Also setenv line in your post doesn't look right with 'con$' argument at the end, please check if this is intended or copy-paste error. Also serial console argument was wrong (console=console=...) setenv bootargs "root=/dev/mmcblk0p1 rootfstype=ext4 rootwait console=ttymxc0,115200 loglevel=7 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 rd.dm=0 rd.luks=0 rd.lvm=0 raid=noautodetect pci=nomsi ahci_imx.hotplug=1" ext2load mmc 0 0x18000000 /boot/dtb/${fdt_file} ext2load mmc 0 0x12000000 /boot/zImage bootz 0x12000000 - 0x18000000 Edit: Fixed path and serial console arguments. @Igor Serial console device name should be case-sensitive, are you sure that "ttymxc0" is all lowercase (just to be sure)? Copy-pasted your code and now hummingboard show me this: File imx6dl-hummingboard.dtb is included. U-Boot SPL 2013.10-rc4-sun7i (Oct 11 2015 - 20:45:45) Boot Device: SD1 spl: error reading image u-boot.img, err - -1 Load image from RAW... U-Boot 2013.10-rc4-sun7i (Oct 11 2015 - 20:45:45) CPU: Freescale i.MX6SOLO rev1.1 at 792 MHz Reset cause: POR Board: MX6-HummingBoard DRAM: 512 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: FEC [PRIME] (Re)start USB... USB0: USB EHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found scanning usb for ethernet devices... 0 Ethernet Device(s) found Hit any key to stop autoboot: 0 mmc0 is current device ** File not found /boot.scr ** ** File not found /uEnv.txt ** ** File not found /zImage ** ** File not found /uImage ** 412 bytes read in 141 ms (2 KiB/s) Running bootscript from mmc ... ## Executing script at 10800000 invalid extent block ext4fs_devread read outside partition 4294967120 ** File not found /boot/dtb/imx6dl-hummingboard.dtb ** 6310896 bytes read in 470 ms (12.8 MiB/s) Kernel image @ 0x12000000 [ 0x000000 - 0x604bf0 ] ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree Booting from net ... FEC Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY FEC FEC Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY FEC Booting uImage ## Booting kernel from Legacy Image at 10800000 ... Image Name: Image Type: ARM Linux Script (uncompressed) Data Size: 348 Bytes = 348 Bytes Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 340 Bytes = 340 Bytes Verifying Checksum ... OK Wrong Image Type for bootm command ERROR: can't get kernel image! HummingBoard U-Boot > Link to comment Share on other sites More sharing options...
0 zador.blood.stained Posted January 19, 2016 Share Posted January 19, 2016 invalid extent block ext4fs_devread read outside partition 4294967120 Filesystem or partition table error? ** File not found /boot/dtb/imx6dl-hummingboard.dtb ** ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree Booting from net ... Is file "/boot/dtb/imx6dl-hummingboard.dtb" present? Link to comment Share on other sites More sharing options...
0 lnsider Posted January 19, 2016 Author Share Posted January 19, 2016 File imx6dl-hummingboard.dtb is included. ** File not found /boot/dtb/imx6dl-hummingboard.dtb ** ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree Booting from net ... Is file "/boot/dtb/imx6dl-hummingboard.dtb" present? Yes boot/dtb$ ls *hummingboard* imx6dl-hummingboard2.dts imx6dl-hummingboard.dtb imx6dl-hummingboard.dts imx6qdl-hummingboard2.dtsi imx6qdl-hummingboard.dtsi imx6q-hummingboard2.dts imx6q-hummingboard.dtb imx6q-hummingboard.dts Filesystem or partition table error? Good question.... Link to comment Share on other sites More sharing options...
0 zador.blood.stained Posted January 19, 2016 Share Posted January 19, 2016 As far as quick google search results indicate, ext4 related code in some older u-boot versions is not 100% reliable in some circumstances. @Igor Is this the latest u-boot version for this device? If so, it maybe better to use fat boot partition with this u-boot version. Here even separate ext4 /boot partition will help avoiding this kind of issues. @Insider >Filesystem or partition table error? Good question.... This was rhetorical question that usually summons @tkaiser in any thread related to possible sdcard errors . While it doesn't hurt to check your sdcard with f3 or some other tool, it's possible just a coincidence related to u-boot version and compiling kernel on the device itself. Link to comment Share on other sites More sharing options...
0 Igor Posted January 19, 2016 Share Posted January 19, 2016 @zador I would say the file system is corrupted due too many hard resets. There are zero reports that this particular u-boot had troubles reading ext FS. @Insider Second problem here is, that you are not using the same kernel source, not same configuration, not same after patches. I know it should be possible to boot but this raises new questions. Link to comment Share on other sites More sharing options...
0 lnsider Posted January 19, 2016 Author Share Posted January 19, 2016 @zador I'm using the original u-boot, what is included also in Igor´s debian system @Igor Is this too difficult? Is there a simple solution like, using the right configuration, using right kernel source and else? Link to comment Share on other sites More sharing options...
0 zador.blood.stained Posted January 19, 2016 Share Posted January 19, 2016 I would say that filesystem is in unusual state for u-boot due to a large number of extents. Another link. While this patch is for older u-boot, @Insider's error message says "Invalid extent block". Compiling kernel on a device creates enormous amount of small files, which can lead to filesystem fragmentation and creating more extents for files than usual. Since it cannot be observed in any other "normal" use case scenario, there were no reports of this issue before. @Igor Problem here is with u-boot, not with kernel. @Insider If this is related to fs fragmentation, you may be even able to boot after you: Delete kernel sources directory from your rootfs Back up contents of /boot directory and delete all files from it on sdcard Run ext4defrag on your rootfs to get rid of any fragmentation issues Restore backed up files to /boot Link to comment Share on other sites More sharing options...
0 lnsider Posted January 19, 2016 Author Share Posted January 19, 2016 @zador I compiling kernel on my native PC on Ubuntu x64, so "creates enormous amount of small files" should not be the problem. Maybe I should just update the u-boot? Link to comment Share on other sites More sharing options...
0 Igor Posted January 19, 2016 Share Posted January 19, 2016 I have no idea what else but I did a recompile from sources and my Hummingboard normally boots (with a fresh SD card). Link to comment Share on other sites More sharing options...
0 zador.blood.stained Posted January 19, 2016 Share Posted January 19, 2016 @Igor U-boot doesn't start this kernel due to "missing" dtb file, recompiling kernel doesn't matter here. My guess is that DTB file is "missing" from u-boot perspective due to ext4 extents, and this is very random and will be hard to reproduce, especially on new images where chances to get fs tragmentation are almost zero. @Insider Do you have another (unused) sdcard? If you do, try creating single ext4 partition on it, rsyncing existing filesystem from old card to new and writing u-boot to it. BTW, what's the reason you want to compile kernel yourself? Link to comment Share on other sites More sharing options...
0 zador.blood.stained Posted January 19, 2016 Share Posted January 19, 2016 @Igor I don't know if it actually matters... but why ext2load is used when this u-boot has ext4load? Extents is primarily an ext4 feature. ext4load is not an alias to ext2load, it's completely different code. @Insider Can you try replacing ext2load with ext4load and see if u-boot messages change? Link to comment Share on other sites More sharing options...
0 lnsider Posted January 20, 2016 Author Share Posted January 20, 2016 @zador Sorry but at the moment, I have no unused sdcards. I will try to do it. @Igor Do you compiled the linux-fslc kernel from solid run? Link to comment Share on other sites More sharing options...
0 Igor Posted January 20, 2016 Share Posted January 20, 2016 Do you compiled the linux-fslc kernel from solid run? I tried once, a while ago, but as I remember there were some problems or it was even not booting at all. This one is ok: https://github.com/linux4kix/linux-linaro-stable-mx6 Link to comment Share on other sites More sharing options...
0 lnsider Posted January 25, 2016 Author Share Posted January 25, 2016 Hi Igor and zador, I found now an official working image from SolidRun for HummingBoard. https://images.solid-build.xyz/IMX6/Debian/ Thank you for help, but mine tries are Miss-successful. Link to comment Share on other sites More sharing options...
0 Igor Posted January 25, 2016 Share Posted January 25, 2016 I found now an official working image from SolidRun for HummingBoard. And now what? http://www.armbian.com/hummingboard/ Our images are also working. Link to comment Share on other sites More sharing options...
Question
lnsider
Hi Igor,
how can I fix that?
33 answers to this question
