Now I got 3 different sata -> USB Brigdes but none of them are recognized by any of the USB Ports.
I was just wondering which sata is build onto a orangepi 2 plus so that it works. Is it even connected internally via USB?
Anything is helpful, since I would like to install mediavault and it does not really make sense. :->
all the best
I have ICYBOX 2.5" external Storagebox, I tried an old IDE->USB and a western Digital USB3.0 External Drive which has already the Bridge on board. If you want to know the USB ID's please let me know.
lsusb views all other usb devices like RTL8192CU from edimax and a Serial port...etc
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 7392:7822 Edimax Technology Co., Ltd
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
It is plugged in at the moment....and it does not matter where to plug it in... I tried it all and dmesg does not recognize it at all, it is like invisible.
USB works as I can guess, but how to enable SATA at all, because maybe it is disabled.
On my Laptop I get for ICYBOX that:
Bus 001 Device 006: ID 152d:2509 JMicron Technology Corp. / JMicron USA Technology Corp. JMS539 SuperSpeed SATA II 3.0G Bridge (be aware that this is sold as USB2.0 and has the plug)
For WD External I get
Bus 001 Device 007: ID 1058:25a2 Western Digital Technologies, Inc. (USB3.0 or higher plug)
In order to get USB and the Camera to work I had to install 5.2, then update, upgrade and then to change the script.bin to the latest in found in /boot/bin/, then camera worked and I was happy.
Actually It would be enough if somebody could tell me which bridge is supported, respectively where to look for it?
[SOLUTION]
As you can see my setup with hooked up "things", only my lte stick is not attached.
LOT (list of things)
SDD Samsung in the (ICY)box.
Camera attached
Serial for my terminal
Network LAN
Network USB Edimax 300 GB or MB (who cares, hehehe)
3G Modem working
Bus 004 Device 032: ID 0e8d:00a5 MediaTek Inc.
Bus 003 Device 032: ID 152d:2509 JMicron Technology Corp. / JMicron USA Technology Corp. JMS539 SuperSpeed SATA II 3.0G Bridge
Bus 002 Device 002: ID 7392:7822 Edimax Technology Co., Ltd
I have this precision power supply and had it set to 5.00, where any (but only) external SATA->USB Bridge failed. All of a sudden I had this crazy idea to crank up the voltage a little and voila -> approx at 5.2 I had a crazy dmesg output that the drive had read errors and  cache issues. Then later I got it running at 5.25 and further perform without errors at 5.3. So I set the perfect safe level of no failure to 5.35. So what do you say about that? OPI -> into the bin?
Now this setup, where it is fully headless (no HDMI/DVI, etc. -> all powered off, the DRAM set to lowest 480, but all cores powered up) we can definitly say on peak performance it uses 5W.
Peak performance is Modem SMS and internet up/down from and to harddrive and surfing through hotspot.
all the best and I hope to solve a lot of SATA problems here and gave a real view of performance/consumption.
