Hey, I also wanted to use the Rockchip VPU inside my Jeyllfin docker-container. But on my machine (RK3389, 6.6.47-current-rockchip64,   Armbian v24.8.4 bullseye), I only can only see "dri":
ls -l /dev | grep -E "mpp|rga|dri|dma_heap"
drwxr-xr-x 3 root root         120 Oct 18 11:18 dri
How can I install the missing parts? All I found when googling was finding installing for ubuntu and not debian.
For the required OpenCL (libmali) I used this:
mkdir -p ~/tmp/libmali && cd ~/tmp/libmali
wget 'https://github.com/tsukumijima/libmali-rockchip/releases/download/v1.9-1-55611b0/libmali-valhall-g610-g13p0-gbm_1.9-1_arm64.deb'
sudo dpkg -i ./libmali-valhall-g610-g13p0-gbm_1.9-1_arm64.deb
and verified with:
sudo apt update && sudo apt install -y clinfo && clinfo
I also installed the "jellyfin-ffmpeg7" on host machine (didn't helped):
wget https://github.com/jellyfin/jellyfin-ffmpeg/releases/download/v7.0.2-3/jellyfin-ffmpeg7_7.0.2-3-bullseye_arm64.deb
sudo dpkg -i jellyfin-ffmpeg7_7.0.2-3-bullseye_arm64.deb
I also installed the debian version of "panfork-mesa" (didn't helped):
wget https://build.opensuse.org/projects/home:amazingfate:panfork-mesa/signing_keys/download?kind=gpg -O public_key.asc
sudo gpg --dearmor -o /etc/apt/keyrings/obs-home-amazingfate.gpg public_key.asc
nano /etc/apt/sources.list
> deb [signed-by=/etc/apt/keyrings/obs-home-amazingfate.gpg] https://download.opensuse.org/repositories/home:/amazingfate:/panfork-mesa/Debian_12/ ./
sudo apt update
sudo apt install mali-g610-firmware
How can I install the missing parts for debian? Or how did you installed it @Rdlop
Greeting
Posted (edited)
Quote
@Dyfcom
Simply by
I copied the firmware (also changed the docker-compose). But the same error from your initial post.
I noticed that my RK3399 is using the Mali-T860 GPU and not the G610 from the newer chip on the orangepi 5. I deinstalled "panfork-mesa" and "libmali". Installed packages:
sudo apt install -y mesa-utils libglx-mesa0 libgl1-mesa-dri
copied the firmware again and hit:
dmesg|grep mali
[    3.350996] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
dpkg -l | grep -i mesa
ii  libgl1-mesa-dri:arm64              20.3.5-1                           arm64        free implementation of the OpenGL API -- DRI modules
ii  libglapi-mesa:arm64                20.3.5-1                           arm64        free implementation of the GL API -- shared library
ii  libglu1-mesa:arm64                 9.0.1-1                            arm64        Mesa OpenGL utility library (GLU)
ii  libglx-mesa0:arm64                 20.3.5-1                           arm64        free implementation of the OpenGL API -- GLX vendor library
ii  mesa-utils                         8.4.0-1+b1                         arm64        Miscellaneous Mesa GL utilities
find /lib/firmware -name mali*.bin -ls
     3907    268 -rw-r--r--   1 root     root       274432 Oct 18 14:44 /lib/firmware/mali_csffw.bin
   141532    268 -rw-rw-r--   1 root     root       274432 Sep 16 18:07 /lib/firmware/arm/mali/arch10.8/mali_csffw.bin
still the missing the other modules:
drwxr-xr-x 3 root root         120 Oct 18 14:24 dri
I think my RK3399 is not ready to use for Hardware acceleration? And it's looks like I would need a desktop environment to use ist under debian?
Edited by Dyfcom
Posted (edited)
I don't have any packages installed
I'm using
 v24.8.4 for Orange Pi 5 Plus running Armbian Linux 6.1.75-vendor-rk35xx
Can you check if the firmware is loaded by the kernel ?
 dmesg|grep Mali
[  367.986293] mali fb000000.gpu: Loading Mali firmware 0x1010000
[  367.988606] mali fb000000.gpu: Mali firmware git_sha: 814b47b551159067b67a37c4e9adda458ad9d852
Edited by Rdlop
I am using:
 v24.8.4 for NanoPi M4V2 running Armbian Linux 6.6.47-current-rockchip64
 Packages:     Debian rolling (bullseye), possible distro upgrade (bookworm)
With:
 dmesg|grep Mali
I am getting no results. With:
dmesg|grep mali
That is wierd..
