ripperhack Posted July 10, 2017 Posted July 10, 2017 Hi to all, my eth0 is configured to work 100Mb/s by default Linux orangepiplus2e 3.4.113-sun8i #18 SMP PREEMPT Thu Jun 15 02:16:06 CEST 2017 armv7l GNU/Linux ethtool eth0 | grep Speed Speed: 100Mb/s but support gigabit connection: ethtool eth0 Settings for eth0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Advertised link modes: 100baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Speed: 100Mb/s Duplex: Full Port: MII PHYAD: 0 Transceiver: external Auto-negotiation: on Link detected: yes Can I setting via terminal eth0 to work permanently in gigabit mode? (router port is setting in gigabit) thx a lot
Igor Posted July 10, 2017 Posted July 10, 2017 It should run in gigabit mode by default - check, double check other equipment.
ripperhack Posted July 11, 2017 Author Posted July 11, 2017 By default it does not work in gigabit, I can force it to 1000Mb ? If I connect to the same cable the NAS it works in gigabit, the router is configured correctly
Igor Posted July 11, 2017 Posted July 11, 2017 38 minutes ago, ripperhack said: If I connect to the same cable the NAS it works in gigabit, the router is configured correctly Weirdo problems requires weirdo tactics Cables and switches (and other dump devices) can act strange sometimes. I am not that deep familiar, but changing them for others might help. Of course those cables and switches can work perfectly fine (gigabit) with other hardware.
ripperhack Posted July 11, 2017 Author Posted July 11, 2017 The strange thing is that the router detects 1000mb during the orangi boot. When the boot is complete (ssh ready) it detects 100mb. I consider it an armbian configuration problem. It is probably the auto negotiation on in network setting?
Igor Posted July 11, 2017 Posted July 11, 2017 By default it should run at gigabit ... supply logs with armbianmonitor -u that we can see more. I am not sure we touch anything related.
adrb Posted July 11, 2017 Posted July 11, 2017 Connect other device with that cable and check if you will get 1000Mbit. If not, then you should know what to do next.
Igor Posted July 11, 2017 Posted July 11, 2017 It's some problem at your side and I can only guess - I also did test with latest Debian Jessie from download section - it goes strait on gigabit: http://sprunge.us/RbGC
ripperhack Posted July 12, 2017 Author Posted July 12, 2017 15 hours ago, adrb said: Connect other device with that cable and check if you will get 1000Mbit. If not, then you should know what to do next. I've already tried with the NAS and it works at 1000
ripperhack Posted July 12, 2017 Author Posted July 12, 2017 14 hours ago, Igor said: It's some problem at your side and I can only guess - I also did test with latest Debian Jessie from download section - it goes strait on gigabit: http://sprunge.us/RbGC Thanks for the test, I can not understand why it does not work. Can you tell me which configurable file I can force the autononeg OFF and 1000mb? Searching the Internet might be a compatibility issue with the router and the network driver and it is advisable to set the speed by config file but I do not know which file to edit thx a lot
