TCB13 Posted July 12, 2017 Posted July 12, 2017 Hello, I've been running the Ubuntu experimental version in my NanoPi NEO2 for months now without any issues, it has been running just fine. However today I tried to run apt-get update and got: N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'http://beta.armbian.com xenial InRelease' doesn't support architecture 'arm64' N: Skipping acquire of configured file 'utils/binary-arm64/Packages' as repository 'http://beta.armbian.com xenial InRelease' doesn't support architecture 'arm64' N: Skipping acquire of configured file 'xenial-desktop/binary-arm64/Packages' as repository 'http://beta.armbian.com xenial InRelease' doesn't support architecture 'arm64' This wasn't showing up before, does this actually means I don't get updates anymore? Why? What's changed / how should I fix this? Board: NanoPi NEO2 Distributor ID: Ubuntu Description: Ubuntu 16.04.2 LTS Release: 16.04 Codename: xenial Thank you.
Igor Posted July 13, 2017 Posted July 13, 2017 12 hours ago, TCB13 said: This wasn't showing up before, does this actually means I don't get updates anymore? Why? What's changed / how should I fix this? You are using something what was designed for developers and for testing. Neo2 does not have stable builds with mainline kernel yet. This particular error shows that daily automated system is broken and it doesn't provide consistent updates. I am working on fixing it for last two days ... try once again in a week, but beware that you are using unstable kernel, which update might break your system completely. Rather don't upgrade until stable builds are out ... 1
TCB13 Posted July 17, 2017 Author Posted July 17, 2017 On 13/07/2017 at 0:05 PM, Igor said: You are using something what was designed for developers and for testing. Neo2 does not have stable builds with mainline kernel yet. This particular error shows that daily automated system is broken and it doesn't provide consistent updates. I am working on fixing it for last two days ... try once again in a week, but beware that you are using unstable kernel, which update might break your system completely. Rather don't upgrade until stable builds are out ... @Igor thanks for the feedback and your hard work. Indeed it is working fine now! Although this is an experimental build I've been running it flawless for a few months now. Thank you all for your great work.
Igor Posted July 18, 2017 Posted July 18, 2017 8 hours ago, TCB13 said: Although this is an experimental build I've been running it flawless for a few months now. Thank you all for your great work. Yes, it's more or less stable. We are waiting for few things and soon planning to declare/change DEV to NEXT, most likely within next major update.
