Bas Posted November 20, 2024 Posted November 20, 2024 Hello OPI5 users. Running Joshua Riek's Ubuntu distro, I keep getting stability issues. Perhaps because I keep using Xorg. Perhaps because hardware acceleration is buggy. In the past I used super stable Armbian OPI5 distro's without hardware acceleration. Infact I still use Armbian on another RK3588 box, I don't think it has EVER crashed, running docker, Mosquito, HomeAssistant, and a buch of other things. Now that my Orange Pi 5 gets a slightly more serious use as webserver, I really like to get rid of the unpredictable Xorg crashes, and gladly would sacrifice HW acceleration for stability. My situation is this: Using JR Ubuntu Because I want to use headless RealVNC (runs only under Xorg) for several devices I switched off Wayland Using a slightly hacked RealVNC server originating from Raspberry Pi Want to use OPI5 as a NodeJS + Nginx webserver serving Node apps now Any suggestions for a super stable uncrashable distro for the Opi5, for server use but with gui? I kind of hate to set everything up again, especially with the internal M.2 sata quirks, but I gotta have stability now. Hopefully I can ask a second question: is there an easy way to totally turn off HW acceleration in JR Ubuntu? Maybe I should try that first... Kind regards, Bas 0 Quote
Werner Posted November 20, 2024 Posted November 20, 2024 On 11/20/2024 at 1:43 PM, Bas said: Using JR Ubuntu Expand We cannot support 3rd party OS. State your questions here: https://github.com/Joshua-Riek/ubuntu-rockchip/issues On 11/20/2024 at 1:43 PM, Bas said: Any suggestions for a super stable uncrashable distro for the Opi5 Expand Armbian Though it is not uncrashable. Because no distro could every be, especially for this soc. Basically all distros available using the same vendor bsp, some are even built around Armbians modified sources (just like Joshuas images). 0 Quote
Bas Posted November 20, 2024 Author Posted November 20, 2024 Totally understand your reply. My experience with Armbian has been very positive, especially WITHOUT hardware accel. In HW accelerated JR I regularly see segmentation faults in Xorg, which make me think whacky chinese mali code is the cause though I'm not sure. Shouldn't segmentation faults be a thing of the past anyway? It should not even be possible except for broken hardware... Bas 0 Quote
royk Posted November 20, 2024 Posted November 20, 2024 - Using the panthor driver might help, the 6.1.75 kernel with the panthor overlay enabled. - If Xorg is the trouble maker, try wayland with Sunshine server and moonlight-qt as client. - Disable hw acceleration in de xorg config file, although here it never crashed for months 0 Quote
Bas Posted November 25, 2024 Author Posted November 25, 2024 Thanks Roy, will take a look at that Xorg config file. As a webserver the OPI5 is pretty brilliant! As long as I leave de server running and don't log in with VNC and start doing heavy graphical Xorg stuff (or heavy JAVA stuff in VSC) it keeps working fine and stable. OPI5 with Ubuntu NodeJS server serves my iqthink.nl domain Site changes uploadable via FTP, very convenient Nginx reverse proxy server handles SSL and https It works extremely FAST, wow! I have an aluminium passively cooled OPI5 case, the thing is the size of a pack of cigarettes. See www.iqthink.nl 🙂 Bas 0 Quote
