Neooostef Posted 10 hours ago Posted 10 hours ago Hello I encounter a problem when I run the TCPDUMP command Here is the error eth0: SIOCETHTOOL(ETHTOOL_GLINK) ioctl failed: Device or resource busy Work like a charm with Radxa Debian OS, but on two Armbian same problem. Someone knows why ? Thanks 0 Quote
Werner Posted 9 hours ago Posted 9 hours ago Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Neooostef Posted 8 hours ago Author Posted 8 hours ago (edited) Collecting info and sending to paste.armbian.com, wait... /usr/bin/armbianmonitor: line 976: iostat: command not found <!DOCTYPE html> <html lang="en"> <head> <meta charset="utf-8"> <title>Error</title> </head> <body> <pre>Cannot POST /log</pre> </body> </html> Edited 8 hours ago by Neooostef 0 Quote
Neooostef Posted 6 hours ago Author Posted 6 hours ago (edited) armbianmonitor don't return error When i'm use "tcpdump" or "arp-scan" same error neooo@radxa-zero3:~$ tcpdump host 192.168.1.1 tcpdump: end1: SIOCETHTOOL(ETHTOOL_GLINK) ioctl failed: Device or resource busy But when i specify interface, it's work neooo@radxa-zero3:~$ sudo tcpdump -i wlan0 host 192.168.1.1 tcpdump: verbose output suppressed, use -v[v]... for full protocol decode listening on wlan0, link-type EN10MB (Ethernet), snapshot length 262144 bytes 23:25:56.936639 IP radxa-zero3.47793 > _gateway.domain: 57863+ [1au] A? whatismyip.akamai.com. (50) 23:25:56.937550 IP radxa-zero3.52220 > _gateway.domain: 16210+ [1au] AAAA? whatismyip.akamai.com. (50) 23:25:56.942649 IP _gateway.domain > radxa-zero3.52220: 16210 2/1/1 CNAME whatismyip.akamai.com.edgesuite.net., CNAME a1524.g.akamai.net. (179) I have trying to disable end1 but not work neooo@radxa-zero3:~$ sudo ip link set end1 down neooo@radxa-zero3:~$ tcpdump host 192.168.1.1 tcpdump: end1: SIOCETHTOOL(ETHTOOL_GLINK) ioctl failed: Device or resource busy neooo@radxa-zero3:~$ sudo nmcli device disconnect end1 Device 'end1' successfully disconnected. neooo@radxa-zero3:~$ sudo nmcli device status DEVICE TYPE STATE CONNECTION wlan0 wifi connected netplan-wlan0-Neooostef6 br0 bridge connecting (getting IP configuration) netplan-br0 lo loopback connected (externally) lo end1 ethernet disconnected -- p2p-dev-wlan0 wifi-p2p disconnected -- neooo@radxa-zero3:~$ tcpdump tcpdump: end1: SIOCETHTOOL(ETHTOOL_GLINK) ioctl failed: Device or resource busy i'm trying to Identify the processes using the interface, but no process neooo@radxa-zero3:~$ sudo lsof | grep end1 neooo@radxa-zero3:~$ I am very destabilized, you have an idea? Edited 6 hours ago by Neooostef 0 Quote
