Hi, I'm trying to build an image for the Orangepi Zero Plus 2 (H3) using the following instructions: https://docs.armbian.com/Developer-Guide_Build-Preparation/. After putting the produced image onto a microSD card using dd, I put the card into the board, connect the serial and power, and then seems to fail and drops me to the u-boot prompt. Here is the output of the terminal.
U-Boot 2017.07-armbian (Jul 18 2017 - 16:01:02 +0100) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Zero Plus
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
38518 bytes read in 152 ms (247.1 KiB/s)
Unknown command 'bmp' - try 'help'
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3565 bytes read in 188 ms (17.6 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
115 bytes read in 150 ms (0 Bytes/s)
** File not found /boot/uInitrd **
4833760 bytes read in 509 ms (9.1 MiB/s)
Found legacy kernel configuration
35692 bytes read in 491 ms (70.3 KiB/s)
Wrong Ramdisk Image Format
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
mmc1(part 0) is current device
Scanning mmc 1:1...
3565 bytes read in 179 ms (18.6 KiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 4 for devices... 1 USB Device(s) found
USB device 0: unknown device
No ethernet found.
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
I built this on a completely clean install of ubuntu 16.04 in a VirtualBox VM. I did an update an an upgrade before starting the instructions. The only bit I didn't do was the bit behind the vagrant link, because it was broken.
According to de getting started guide:
Images shall only be written with Etcher on all platforms since unlike other tools Etcher validates burning results saving you from corrupted SD card contents.
just to remove one possible problem.
cyclic redundancy check
I've never built my own kernel (I let Igor do that for me) but I know a bad 'hard drive' when I see one, from my computer repair days.
BAD CRC =
cyclic redundancy check error
Make sure your SD card image writing software is 'approved' to work with armbian. ie: Etcher
This is (as far as I know) the only Armbian 'approved' method. Likely because Etcher verifies the image after writing, by default. Whereas dd and Win32Disk Imager (uses dd) don't require verification, of what it just wrote.
So..... bad SD card? Prove it is/isn't then come back asking for help.
Otherwise, I've received bad CRC errors due to power cables going bad at pain points. I think. Might of been that I was writing using Win32 at the time xD IDK for sure because I immediately tried fixing both birds with one stone as opposed to troubleshooting individually.
So double check that Power Supply if you haven't already. If you haven't already, see 0, 1 and 2 links in my signature. ;D
On 7/18/2017 at 11:57 PM, tkaiser said:
MERP. My bad. Just going off what I've experienced and trying to insulate the devs from all the newbie mistakes I hear them complain about every time I turn around. Sorry I didn't catch that abscure https://www.denx.de post.
Just doin my best. You're more than welcome to offer anything constructive and as a dev, you knoe you don't need my permission.
All fine, just wanted to note that this specific message is as expected. The problems start later in the serial output.
Yep that fixed it. Thanks for that.
Now onto figuring out why this camera module does not work
