Overlays do not apply even when selected in armbian-config and then rebooting
find /boot/overlay-user -type f
/boot/overlay-user/pwm.dtbo
/boot/overlay-user/pwm.dts
So, using the included /boot/dtb/rockchip/overlay/ files like rk3308-b@1.3ghz.dtbo, rk3308-s0-ext-antenna.dtbo and rk3308-sdio@10mhz.dtbo
and my own overlay in /boot/overlay-user/ named pwm.dtbo
The ONLY way it works is this:
(important lines in /boot/armbianEnv.txt):
overlay_prefix=rk3308
user_overlays=pwm
overlays=b@1.3ghz s0-ext-antenna sdio@10mhz
Edited by Meestor_X
Hi all,
I'm new here, but I know armbian since years ago.
I have a Rock3A and I downloaded the latest Armbian 25.2.3 bookworm, at the first try armbian-config worked.
But after an update I had a problem with armbian-config, I reinstalled this tools that was corrupted.
Here are the problems with Invalid overlay_prefix, and after searching everywhere and doing some tests I found the solution, here it is:
mkdir /boot/dtb/overlay
cp -r /boot/dtb/rockchip/overlay/. /boot/dtb/overlay/.
cat /boot/armbianEnv.txt
verbosity=1
bootlogo=false
console=serial
extraargs=cma=256M
overlay_prefix=rockchip
overlays=rk3568-pwm8-m0-fan
fdtfile=rockchip/rk3568-rock-3a.dtb
rootdev=UUID=194f1dc9-d186-438e-b1fd-064e3e8b1304
rootfstype=ext4
my files start with overlay_prefix=rockchip, then armbian-config and now your overlays selection works. The folder basically needs to be moved, hopefully that will be done in the next image.
I hope it can be helpful for those who have the same problem.
In my case I have not yet solved the fan operation on pwm8, which works with S.O. Radxa.
I also tried to compile the dts downloaded from Armbian, but there must be some problem on the kernel that has not been solved.
If anyone has managed to get the fan to work on the Rock3A connector, I would be grateful for any help1
Thanks
Tony
That is wrong approach as we follow kernel source / standards:
and this (boot script) contains the mechanism for loading it:
https://github.com/armbian/build/blob/main/config/bootscripts/boot-rk35xx.cmd
It should work:
https://github.com/armbian/build/blob/main/config/bootscripts/boot-rk35xx.cmd#L51-L52
Is your image an upgrade from some old one? As we indeed have issues with this at some point.
Unfortunately all these solutions did not work.
But by installing the latest Armbian Noble Gnome installation, and changing the overlay_prefix=rockchip line in the armbianEnv.txt file
I can select the overlays.
Evidently my image was corrupted, or the upgrade failed.
Now, I have a bigger problem is to enable the fan on Rock-3A, and it does not work even loading the PWM8 overlay of radxa.
Then I did a bit of research and since the Armbian dts change a bit, and I spent hours rebuilding this driver, but it does not work.
I do not know if anyone has enabled the fan on the dedicated connector of the Rock-3A. Here is my dts:
/dts-v1/;
/plugin/;
metadata {
title = "Enable PWM8-M0";
compatible = "radxa,rock-3a", "radxa,rock-3b";
category = "misc";
exclusive = "GPIO3_B1";
description = "Enable PWM8-M0.
On Radxa ROCK 3A <= this is pin 16.
On Radxa ROCK 3A >= this is pin 16.
On Radxa ROCK 3B this is pin 16.";
&pwm8 {
status = "okay";
pinctrl-names = "active";
pinctrl-0 = <&pwm8m0_pins>;
This doesn't work, maybe because I read somewhere that Linux 6.xx has problems with PWM ?
For now I'm happy with setting GPIO3_B1 pin to 1, and the fan works, but if I run this:
#Fan controller
echo 0 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip0/export
echo 10000 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip0/pwm0/period
echo 5000 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip0/pwm0/duty_cycle
echo normal > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip0/pwm0/polarity
echo 1 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip0/pwm0/enable
The fan doesn't work, the pin is that one and radxa recommends PWM8.
For now I have to give up on the silent fan, then if there are updates I'll try.
Thank you very much for your help
Ok, this morning
apt-get upgrade tells me that there is armbian-config to update.
Done and now solved the overlay issue also on my old image
Thanks
armbianEnv.txt seem is not being loaded.  I am trying to get i2c-1 up and I have it checked in armbian-config but all I get is i2c-2 showing.  Loading the overlay manually gets the device to show up but not after a reboot.  What am I doing wrong?  ChatGPT sends me on a wild ride trying to fix.
rootfstype=ext4
overlays=i2c1 i2c-rtc ds3231 ds1307
What steps are you doing to get this working manually?  What is the overlay file you are loading (trying to load), and where does that file exist on the system?
OMG - I can confirm this issue is also happening on orange pi 5 with latest armbian  v25.5.1 + Linux 6.1.*-vendor-rk35xx
This is my armbianEnv.txt
verbosity=1
bootlogo=false
console=both
#extraargs=cma=256M
overlay_prefix=rockchip-rk3588
fdtfile=rockchip/rk3588s-orangepi-5.dtb
rootdev=UUID=5c3a1a5c-80df-4660-9b97-ccff04bfafe2
rootfstype=ext4
user_overlays=pwm1-m2
#overlays=rk3588-i2c1-m4 rk3588-pwm1-m2
The pwm only loads when I copy it into overlay-user. The really strange thing is that I have two of these boxes and the one that went through upgrades is working just fine but I'm trying a fresh install on another and no way to get the overlay to work except this hack
If you remove the "rk3588-" from each it should work as that is included in the overlay_prefix
I will try but I have this line working on exactly the same box with a older build that was upgraded
Coming back to this...
I'm not having any luck getting overlays to work, but I'll need to get out my serial logger to see what's wrong I guess.
I'm trying to get the USB-C into host mode on my RockPi-S. I can do it by editing the rk3308-rock-pi-s.dtb file directly, but not using an overlay file.
Here's the overlay file I've tried (usbc-host.dts):
/dts-v1/;
	fragment@0 {
		target-path = "/usb@ff400000";
		__overlay__ {
			dr_mode = "host";
and
/dts-v1/;
/plugin/;
	fragment@0 {
		__overlay__ {
			dr_mode = "host";
Tried using:
armbian-add-overlay usbc-host.dts
as well as compiling the overlay to a .dtbo and adding the line directly into armbianEnv.txt
No joy either way...
Also, does anyone know why some .dtbo files also have the line
/plugin/;
below
/dts-v1/;
Edited by Meestor_X
