armbian-config updating daily
Go to solution Solved by Igor,
armbian-config seems to be updating every day on my system, which I suspect is unintentional.
sudo apt list --upgradable
Listing... Done
armbian-config/unknown 25.2.0-trunk.116.1202.192010 all [upgradable from: 25.2.0-trunk.107.1130.212127]
N: There are 12 additional versions. Please use the '-a' switch to see them.
It depends on which repository you are pointing to.  But in general if you are pointing to the stable repository (apt.armbian.com) then you would see releases as they flow out to the stable channel.  If you are pointing to the nightly rolling release repository (beta.armbian.com) then you get nightly rolling release builds. (look at what repository you are using in /etc/apt/sources.list.d/armbian.list)
The version you are reporting for armbian-config is a nightly version (25.2.-trunk is a rolling release).
Thanks @SteeMan
cat /etc/apt/sources.list.d/armbian.list
deb [signed-by=/usr/share/keyrings/armbian.gpg] http://apt.armbian.com bookworm main bookworm-utils bookworm-desktop
This problem started with the recent Armbian upgrade.
Edited by Gabriel White
  • Solution
2 hours ago, Gabriel White said:
This problem
Its a feature :) We decide to leave this utility on development branch (there is separate armbian-config.list in the source folder) for awhile to speed up with the integration. There is a lot of automation that is helping preventing shipping broken app. And the app itself is very simple compared to everything else.
