Eugenio Eugenio Posted December 10, 2024 Posted December 10, 2024 Hello everyone, I’ve been working with 25-30 USB 3G/4G dongles successfully on Debian and Ubuntu, where all connections work without issues. However, on Armbian, I can only establish around 10 PPPoE connections. Here are the details of my setup: OS: Armbian based on Debian 10 (I also tried updating to Debian 11) - IMG: Sunvell rkship and Kernel Version: linux-image-current-sunxi 24.11.1 Packages Used: ppp, eject, and usb-modeswitch (tested with the latest versions) Logs: /var/log/ppp.log doesn’t show any errors. Isos: Armbian 21.05.1 stable, kernel 4.4 (SoC Rockchip rk322x) Armbian 20 - Debian 10 ARM (SoC Alllwinner H3) - Sunvell R69 https://mega.nz/file/4ugAhKjb#NIt6KIv2tsPFzVVGwLcykFSdQp0MgCXgdCzxcj0PUxA https://mega.nz/file/V3QQyBaY#Y332sD2oa36L5BZa0xtANx1O6QrS_903Qj1RHg1vuy8 I’ve read that some kernel parameters may limit handling multiple PPP sessions or high network traffic. For example, I came across the parameter net.core.max_skb_frags, which seems relevant but I haven’t made adjustments yet. Has anyone encountered this issue or know what configurations I can tweak to improve Armbian's capability to handle more PPPoE connections? Any advice on kernel parameters, USB handling, or PPP configurations would be greatly appreciated. Thank you! 0 Quote
Igor Posted December 10, 2024 Posted December 10, 2024 9 hours ago, Eugenio Eugenio said: I’ve been working with 25-30 USB 3G/4G dongles successfully on Debian and Ubuntu I assume you achieved this performance on cca. 20 x more expensive Intel based hardware? First lets rule out user space. Try Armbian x86 https://www.armbian.com/uefi-x86/ on that. 9 hours ago, Eugenio Eugenio said: Armbian 21.05.1 stable, kernel 4.4 (SoC Rockchip rk322x) Armbian 20 - Debian 10 ARM (SoC Alllwinner H3) - Sunvell R69 None of this was ever officially supported. And those are 3-4 years builds from 3rd party repository. Armbian makes tools for making custom OS and this was made by "someone" from a vendor kernel that is deprecated in years. 9 hours ago, Eugenio Eugenio said: Any advice on kernel parameters I can only give you general advice. - develop image around modern kernel ( config exists but it might not work https://github.com/armbian/build/blob/main/config/boards/sunvell-r69.tvb and https://github.com/armbian/build/blob/main/config/boards/rk322x-box.tvb) - use hardware that is capable of achieving this Good luck. 0 Quote
