Mentaluproar Posted August 8, 2017 Posted August 8, 2017 I am trying to get my nanopi m1 to show up as an ethernet device and I can't make it work in mainline or legacy. Since I'm aiming for mainline anyway, could someone help me figure out what I'm doing wrong?
Igor Posted August 8, 2017 Posted August 8, 2017 IIRC it should be working on legacy while on mainline it is not implemented yet or buggy. I hope someone else could provide more info on the issue.
malvcr Posted October 6, 2017 Posted October 6, 2017 I am having a problem and I really don't know if this is my fault or if could be a problem with mainline. My current version is: Linux orangepizero 4.11.5-sun8i #11 SMP Fri Jun 23 20:03:23 CEST 2017 armv7l armv7l armv7l GNU/Linux I have been fighting with g_ether on an OPIZero as slave (OTG mode) connected with another machine HOST USB port, but no matter what I do, it is not possible to make it to work well. Several months ago I was able to connect two OPIZero machines with legacy kernel in both of them. But now, I need to use another machine (OPIZ+2 H5 or BPI-R2) having 4.4 kernel and it doesn't work. For this I decompiled the dtb file and replaced the "peripheral" with "otg". Original: usb@01c19000 { compatible = "allwinner,sun8i-h3-musb"; reg = <0x1c19000 0x400>; clocks = <0x2 0x20>; resets = <0x2 0x11>; interrupts = <0x0 0x47 0x4>; interrupt-names = "mc"; phys = <0x11 0x0>; phy-names = "usb"; extcon = <0x11 0x0>; status = "okay"; dr_mode = "peripheral"; linux,phandle = <0x31>; phandle = <0x31>; }; New one: usb@01c19000 { compatible = "allwinner,sun8i-h3-musb"; reg = <0x1c19000 0x400>; clocks = <0x2 0x20>; resets = <0x2 0x11>; interrupts = <0x0 0x47 0x4>; interrupt-names = "mc"; phys = <0x11 0x0>; phy-names = "usb"; extcon = <0x11 0x0>; status = "okay"; dr_mode = "otg"; linux,phandle = <0x31>; phandle = <0x31>; }; Commented g_serial and added g_ether in the /etc/modules file. Disabled Network-Manager, installed Avahi in both machines. Added the following in /etc/network/interfaces file. iface usb0 inet manual up /usr/sbin/avahi-autoipd --force-bind -D $IFACE down /usr/sbin/avahi-autoipd --kill $IFACE And bring usb0 to life with ifup usb0. When I try to ping from the OPIZero to the other machine the ping fails, but tcpdump receives "something" in the destination side (the HOST one): 12:11:42.826864 ff:ff:46:7b:0e:f2 (oui Unknown) > 2e:00:ff:ff:ff:ff (oui Unknown), ethertype Unknown (0x8718), length 48: 0x0000: 0806 0001 0800 0604 0001 467b 0ef2 8718 ..........F{.... 0x0010: a9fe 0702 0000 0000 0000 a9fe 04cb dead ................ 0x0020: beef The OPIZero usb0 port configuration is this one: usb0 Link encap:Ethernet HWaddr 46:7b:0e:f2:87:18 inet6 addr: fe80::447b:eff:fef2:8718/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:525 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:28094 (28.0 KB) usb0:avahi Link encap:Ethernet HWaddr 46:7b:0e:f2:87:18 inet addr:169.254.7.2 Bcast:169.254.255.255 Mask:255.255.0.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 As can be seen, the source address is shifted 16 bits (the 0x8718 type it is really part of the source hardware address). To check if the destination was the problem, I connected a Raspberry Pi Zero machine with Raspbian configured as OTG and worked without any issue, and tested the HOST side with Armbian on OPIZ+2H5 and Ubuntu on RPI-R2 with the same result in both, so "I think" that the problem is with the Armbian in the OPIZero.
Igor Posted October 6, 2017 Posted October 6, 2017 13 minutes ago, malvcr said: I think" that the problem is with the Armbian in the OPIZero. The problem is you not reading the warning text. Mainline kernel for Opi zero is under development and features that you want to use does not exist at all.
malvcr Posted October 6, 2017 Posted October 6, 2017 No no, I understand it. I was trying with the Mainline because the last Legacy version has the same behavior (my mistake for not to say it, I'm sorry). I made this to work several months ago with complex scenarios involving several Zero machines, and let it at one side for a while because I was making other things. When I returned to this part using a recent Legacy update this didn't work. I thought that was my mistake, but these days I have been returning to work on this and really it doesn't work with Mainline neither with Legacy. At least you are giving me a confirmation. I can't use the OPIZ+2H5 in this moment for any serious task ... I will wait, and if I can help some way let me know. Thanks
Igor Posted October 6, 2017 Posted October 6, 2017 28 minutes ago, malvcr said: I can't use the OPIZ+2H5 in this moment for any serious task ... You can check latest 4.13 kernel if there is any progress in this area. It's accessible from a beta repository.
malvcr Posted October 6, 2017 Posted October 6, 2017 I added the beta repository and updated there ... not yet on 4.13 but 4.11.12 ... and with just this change, several packages didn't arrive "officially" to the HOST machine arrived corrupted but with the OTG machine name an other data ... still doesn't work, but it is different than previous versions. This shows that it is different inside (it is evolving). Then I went to check 4.14 rc3 repository on the Kernel.org original place for all distributions and found this notice there: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/usb/musb/musb_core.c Quote * This consists of a Host Controller Driver (HCD) and a peripheral * controller driver implementing the "Gadget" API; OTG support is * in the works. These are normal Linux-USB controller drivers which * use IRQs and have no dedicated thread. I think this is not ready, and this is why g_ether is still there although marked as "legacy". Could be possible that "musb" and "g_ether" are working one against the other? The problem with the dtb file is that everything is very interleaved. I will try to disable musb to see if this makes any difference. Although I also will try to find another solution "without" the gadget part until this to be officially ready.
Igor Posted October 6, 2017 Posted October 6, 2017 To get current 4.13 you need to switch to NEXT branch. Check "alternative kernels" in armbian-config or download it manually from beta.armbian.com together with dtb package.Wrote on mobile
malvcr Posted October 7, 2017 Posted October 7, 2017 Same behavior. I decided to follow a different path for my current need (no OTG-HOST) ... but as a side project I will continue checking what is the reason this happens. When I have it working I will return with my findings. What worries me is the lack of parameters; where is defined how to work the packages structure? However, this is not Armbian decision but Linux one (the people that are creating that infrastructure part in the kernel core). Let me see if I can design a different way to do that type of connection, without musb neither g_ether.
