After setting up my static IP address, I can't SSH or Ping to the board anymore. The board shows up on my router list of connected devices, and the Pi Hole works normally. I flashed a new SD card and went step by step to see what was causing the problem. I resize the filesystem, update and upgrade the system, then I set up the static IP, so this happens. I tried both by /etc/netwkork/interfaces and by nmtui. This is what my /etc/network/interfaces file looks like:
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.25.160
netmask 255.255.255.0
gateway 192.168.25.1
auto lo
auto eth0
This way is correct.
