BOFFBOY Posted January 9, 2025 Posted January 9, 2025 Hi all, Testing this OP5, got a standard M2 NVMe SSD (this works on my OP5Plus) I have formatted to exFAT with windows, inserted on the OP5, loaded ArmbianOS on MicroSD, it boots fine but I cant get it to show the nvme drive using fdisk -l or lsblk It seem like its not detecting the m2 nvme ssd at all.. little help please ? 0 Quote
eselarm Posted January 9, 2025 Posted January 9, 2025 13 minutes ago, BOFFBOY said: loaded ArmbianOS on MicroSD which image did you write to the SD-card ? 0 Quote
BOFFBOY Posted January 9, 2025 Author Posted January 9, 2025 (edited) Armbian_24.5.2_Orangepi5_noble_vendor_6.1.43_gnome-oibaf_desktop.img and tested a few older legacy jammys... same result. Edited January 9, 2025 by BOFFBOY 0 Quote
Werner Posted January 9, 2025 Posted January 9, 2025 Try this one which has updated rockchip sdk kernel and check if nvme is visible: https://github.com/armbian/os/releases/download/25.2.0-trunk.299/Armbian_25.2.0-trunk.299_Orangepi5_trixie_vendor_6.1.84_minimal.img.xz 0 Quote
BOFFBOY Posted January 9, 2025 Author Posted January 9, 2025 tried it still unable to see NVMe SSD.... I did notice these two lines when i did armbian-upgrade .......................... W: Possible missing firmware /lib/firmware/regulatory.db for built-in driver cfg80211 W: Possible missing firmware /lib/firmware/regulatory.db.p7s for built-in driver cfg80211 update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.1.84-vendor-rk35xx Image Name: uInitrd Created: Fri Jan 10 00:17:25 2025 Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 10490152 Bytes = 10244.29 KiB = 10.00 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.1.84-vendor-rk35xx to /boot/uInitrd '/boot/uInitrd' -> 'uInitrd-6.1.84-vendor-rk35xx' update-initramfs: Armbian: done. Summary: Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0 0 Quote
Werner Posted January 9, 2025 Posted January 9, 2025 Would you mind sharing logs as described below? Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
BOFFBOY Posted January 10, 2025 Author Posted January 10, 2025 Hi Werner, Here you go, that is very smart way of collecting logs. https://paste.armbian.de/upuyozujik Btw, the NVMe SSD was tested with windows formatted with GPT NTFS and exFAT, both same result.. OP5 unable to detect it. its Gen3 SSD, pretty sure OP5 is Gen2 but its not the issue here right ? 0 Quote
ArmBoy1988 Posted January 14, 2025 Posted January 14, 2025 I just installed an NVME and transferred image using armbian-install and all is working/detected fine. I purchased this: https://www.amazon.ca/dp/B0BVQXGS3D I was using image the default from the download page: Armbian_24.11.2_Orangepi5_noble_vendor_6.1.75_gnome-kisak_desktop.img.xz I've found with several threads about NVME issues that the one being tried can be the cause of the issue. Don't know why. Which NVME are you using? 0 Quote
thanh_tan Posted February 12, 2025 Posted February 12, 2025 I don't know why it is working but you can edit the armbianEnv.txt and add overlays=ssd-sata then reboot. The OS will recognize the NVME disk 0 Quote
eselarm Posted February 12, 2025 Posted February 12, 2025 (edited) 19 hours ago, thanh_tan said: overlays=ssd-sata That is weird; 'ssd-sata' is not nvme. And it is a rk3588s, so which multiPHY is then put in SATA mode? Not the one operating (connected to) the NVMe device one would assume. I do not know HW architecture of OPi5, maybe you lost USB3 function now? And where did you get that overlay from? I don't see it: /usr/lib/linux-image-6.1.99-vendor-rk35xx# find . -name "*sata*" ./rockchip/overlay/mixtile-blade3-sata2.dtbo ./rockchip/overlay/orangepi-5-plus-sata2.dtbo ./rockchip/overlay/orangepi-5-sata.dtbo ./rockchip/overlay/radxa-cm5-io-sata.dtbo ./rockchip/overlay/rk3566-roc-pc-sata2.dtbo ./rockchip/overlay/rk3588s-roc-pc-sata0.dtbo ./rockchip/overlay/rock-3a-sata.dtbo ./rockchip/overlay/rock-5a-sata.dtbo ./rockchip/overlay/rock-5b-sata.dtbo ./rockchip/overlay/turing-rk1-sata2.dtbo ./rockchip/overlay/yy3568-sata2.dtbo Or is it renamed 'orangepi-5-sata' ? Are you sure it is actually loaded? Edited February 12, 2025 by eselarm 0 Quote
vitaly z Posted April 4 Posted April 4 Hi @BOFFBOY, have you managed to make it work? Having similar issue : tried with two different orange pi 5 , two different nvme SSDs, three different Power supplies up to 5V/5A and three armbian kernels: 5.10 | 6.1 and 6.18 0 Quote
eselarm Posted April 7 Posted April 7 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
zjd Posted May 9 Posted May 9 I started to have similar issue with recent rolling release (after 26.2.1) mainline kernels: 6.18.2x, 7.0.x, 7.1.0-rc. https://paste.armbian.com/yobewudugo The log seems having all previous boot logs of this board and 6.18.10, 6.18.8 and 6.1.115 can enumerate NVMe SSD but others can't. I did a PCI rescan with 7.1.0-rc2 after booting the board and NVMe SSD was found and corresponding kernel log can be found in the 1st kernel log. I have Armbian image on SD card, btw. sudo bash -c "echo 1 > /sys/bus/pci/rescan" 0 Quote
MAXIM ALEKSEEV Posted 54 minutes ago Posted 54 minutes ago The same problem on the Pi 5 Ultra, has anyone managed to solve this problem? Or is this a global bug for all Orange devices? 0 Quote
