sailfish009 Posted August 14, 2017 Posted August 14, 2017 Hi, i am using orangepi PC (H3). i had tried follow link, test.mp4 file created successfully. (video fine). https://github.com/avafinger/ffmpeg_cedrus264_H3 now, i want to real time(20~30 fps) capture for /dev/video0 (gc2035). i tried mpv with gc2035, but it didn't worked. i want real time video capture using cedrus264. orangepi@OrangePI:~/tmp$ mpv tv:// Playing: tv:// [tv] Selected driver: v4l2 [tv] name: Video 4 Linux 2 input [tv] v4l2: your device driver does not support VIDIOC_G_STD ioctl, VIDIOC_G_PARM was used instead. [tv] Selected device: sunxi-vfe [tv] Capabilities: video capture read/write streaming [tv] supported norms: [tv] inputs: 0 = ; [tv] Current input: -1 [tv] Current format: unknown (0x2006) [tv] v4l2: ioctl set format failed: Operation not permitted [tv] v4l2: ioctl set mute failed: Inappropriate ioctl for device [tv] v4l2: 0 frames successfully processed, 0 frames dropped. Failed to recognize file format. Exiting... (No files played) orangepi@OrangePI:~/tmp$ lsmod Module Size Used by vfe_v4l2 1016266 0 videobuf_dma_contig 4221 1 vfe_v4l2 videobuf_core 16561 2 vfe_v4l2,videobuf_dma_contig gc2035 19239 0 vfe_subdev 4495 2 vfe_v4l2,gc2035 vfe_os 4137 2 vfe_v4l2,vfe_subdev cci 22904 2 vfe_v4l2,gc2035 gpio_sunxi 8265 0 8189es 1069830 0 mali_drm 6634 1 drm 180475 2 mali_drm mali 215601 0 ump 41913 3 mali
sailfish009 Posted August 15, 2017 Author Posted August 15, 2017 i followed to build mpv to support vdpau, https://forum.armbian.com/index.php?/topic/1129-h265/ test.mp4 file works fine with my custom mpv, but still failed to open /dev/video0. orangepi@OrangePI:~/tmp$ sudo mpv av://v4l2:/dev/video0 --vo=vdpau --hwdec=vdpau --hwdec-codecs=all --fs Playing: av://v4l2:/dev/video0 [ffmpeg/demuxer] video4linux2,v4l2: ioctl(VIDIOC_ENUMINPUT): Invalid argument [lavf] avformat_open_input() failed Failed to recognize file format. Exiting... (Errors when loading file)
sailfish009 Posted August 16, 2017 Author Posted August 16, 2017 Yes, i read the post, but i think it is not related topic. gc2035 works fine itself, i think this is not hw problem. because, currently below command works fine with my OPI (real time but latency). i built ffmpeg to enable ffplay. sudo ffmpeg -f v4l2 -channel 0 -video_size 640x480 -i /dev/video0 -pix_fmt nv12 -r 30 -b:v 64k -c:v cedrus264 -f matroska - | ffplay -
sailfish009 Posted August 16, 2017 Author Posted August 16, 2017 guvcview with gc2035 works fine, 1280x720p (12~20fps), but this is not hw accelerated rendering. https://github.com/avafinger/guvcview and i couldn't set camera format orangepi@OrangePI:~/tmp/v4l2tools$ sudo v4l2-ctl --device /dev/video0 --set-fmt-video=width=1280,height=720,pixelformat=NV12 VIDIOC_S_FMT: failed: Operation not permitted orangepi@OrangePI:~/tmp$ ls -l /dev/disp crw-rw-rw- 1 root video 253, 0 Jan 1 1970 /dev/disp orangepi@OrangePI:~/tmp$ ls -l /dev/video0 crw-rw-rw-+ 1 root video 81, 0 Jan 1 1970 /dev/video0 orangepi@OrangePI:~/tmp$
Igor Posted August 16, 2017 Posted August 16, 2017 OK I am not much familiar with camera details - I know there have been changes to the driver - can you provide logs to see if your basic requirements are o.k.? armbianmonitor -u Perhaps author of this can tell more @@lex https://github.com/avafinger/guvcview
sailfish009 Posted August 16, 2017 Author Posted August 16, 2017 Hi, Ah, my bsp is not armbian-based! orangepi@OrangePI:~/tmp$ uname -a Linux OrangePI 3.4.112 #4 SMP PREEMPT Wed Dec 7 09:46:40 CST 2016 armv7l GNU/Linux i will test my previous attempt on armbian 5.25(/dev/video0 not found on 5.25) 5.20.
Igor Posted August 16, 2017 Posted August 16, 2017 1 hour ago, sailfish009 said: Ah, my bsp is not armbian-based! 2 Armbian support starts with this. Get latest and use hack mentioned in a link which I paste in my previous post. There are exactly zero chances to help you with outdated 3rd party build. Even for our latest, I can't promise that we will solve the problem, but we will at least try.
@lex Posted August 16, 2017 Posted August 16, 2017 (edited) 4 hours ago, sailfish009 said: but this is not hw accelerated rendering. https://github.com/avafinger/guvcview I think you mean HW encoding? If you mean Encoding , yes guvcview uses SW encoder and i think HW encoder will take some time to be implemented unless someone else do it, or you can use ffmpeg to encode and render it with vdpau. Edit: guvcview uses SDL 1.2 for rendering it on screen, you can check if the SDL is set to use HW, if i recall correctly i tried to use SDL 2.x and got worse rendering speed. Regarding v4l2-ctl there is a user who got this working and also got higher FPS (for OV5640). Please ask him if he can share the code: Edited August 16, 2017 by @lex OV5640 (not gc2035)
sailfish009 Posted August 17, 2017 Author Posted August 17, 2017 i had installed fresh armbian 5.20, and tested below command, the result was same: orange@orangepipc:~$ sudo mpv av://v4l2:/dev/video0 --vo=vdpau --hwdec=vdpau --hwdec-codecs=all --fs LIBGL: Initialising glshim Playing: av://v4l2:/dev/video0 [ffmpeg/demuxer] video4linux2,v4l2: ioctl(VIDIOC_ENUMINPUT): Invalid argument [lavf] avformat_open_input() failed Failed to recognize file format. Exiting... (Errors when loading file) orange@orangepipc:~$ lsmod Module Size Used by rfcomm 32863 4 bnep 9617 2 bluetooth 174065 8 bnep,rfcomm mali_drm 2732 1 drm 178255 2 mali_drm sunxi_cir 1601 0 mali 123208 0 ump 29379 3 mali vfe_v4l2 1013995 0 videobuf_dma_contig 3509 1 vfe_v4l2 videobuf_core 14682 2 vfe_v4l2,videobuf_dma_contig gc2035 19119 0 vfe_subdev 4471 2 vfe_v4l2,gc2035 vfe_os 4141 2 vfe_v4l2,vfe_subdev cci 22816 2 vfe_v4l2,gc2035 8189es 1076034 0 so, i uploaded armbianmonitor log(armhwinfo.log) to pastebin: https://pastebin.com/b1WJiS8M to @lex, i wonder that is possible to use 720P(1280x720) 30fps on orangepi pc. vdpau(cedrus) capable of this?
sailfish009 Posted August 17, 2017 Author Posted August 17, 2017 problem solved! thank you armbian build : https://github.com/armbian/build 1. first installed armbian 5.20 2. remove libreoffice (consumes too much upgrade time) 3. sudo apt-get update && sudo apt-get upgrade (5.20 -> 5.31 armbian) 4. git clone https://github.com/armbian/build ( build u-boot kernel only in Ubuntu 14.04.5 LTS 64bit x86_64 computer) 5. ls -l /build/output/debs/ total 247832 drwxrwxr-x 2 root root 4096 Aug 17 13:35 extra -rw-r--r-- 1 root root 112510 Aug 17 13:54 linux-firmware-image-sun8i_5.32_armhf.deb -rw-r--r-- 1 root root 5803062 Aug 17 13:54 linux-headers-sun8i_5.32_armhf.deb -rw-r--r-- 1 root root 12912060 Aug 17 13:55 linux-image-sun8i_5.32_armhf.deb -rw-r--r-- 1 root root 234757442 Aug 17 13:56 linux-source-default-sun8i_5.32_all.deb -rw-r--r-- 1 root root 177222 Aug 17 13:49 linux-u-boot-orangepipc_5.32_armhf.deb 6. copy *.deb files to orangepi PC ( i used ftp) $ sudo apt-get install ftp ftp get: https://gist.github.com/sailfish009/bc0ef640a2f15cef5f60ab460714cb67 ftp put: https://gist.github.com/sailfish009/6d188f7f0bd8e5cd699eb0359a3f4e52 7. dpkg -i *.deb 8. reboot orange@orangepipc:~$ uname -a Linux orangepipc 3.4.113-sun8i #2 SMP PREEMPT Thu Aug 17 13:54:05 KST 2017 armv7l GNU/Linux 9. video capture $ sudo mpv av://v4l2:/dev/video0 --vo=vdpau --hwdec=vdpau --hwdec-codecs=all --fs $ top [resolution: 320x240][software decoding] cat /etc/profile.d/90-vdpau.sh export VDPAU_OSD=1 PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1051 root 20 0 188924 15276 9148 S 20.7 1.5 3:41.35 mpv cat /etc/profile.d/90-vdpau.sh export VDPAU_OSD=0 PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1091 root 20 0 145532 15492 9192 S 5.3 1.5 0:07.44 mpv
sailfish009 Posted August 21, 2017 Author Posted August 21, 2017 i found that mpv (from armbian) still software decoding. [cpu occupation: ~20%] orange@orangepipc:~/tmp$ sudo v4l2-ctl --device /dev/video0 --set-fmt-video=width=1280,height=720,pixelformat=NV12 [sudo] password for orange: orange@orangepipc:~/tmp$ sudo v4l2-ctl --all Driver Info (not using libv4l2): Driver name : sunxi-vfe Card type : sunxi-vfe Bus info : sunxi_vfe sunxi_vfe.0 Driver version: 1.0.0 Capabilities : 0x05000001 Video Capture Read/Write Streaming Video input : 0 (: ok) Format Video Capture: Width/Height : 1280/720 Pixel Format : ' ' Field : None Bytes per Line: 0 Size Image : 0 Colorspace : Unknown (00000000) Streaming Parameters Video Capture: Capabilities : timeperframe Frames per second: 8.000 (8/1) Read buffers : 0 error 25 getting ctrl Brightness error 25 getting ctrl Contrast error 25 getting ctrl Saturation error 25 getting ctrl Hue error 25 getting ctrl White Balance, Automatic error 25 getting ctrl Exposure error 25 getting ctrl Gain, Automatic error 25 getting ctrl Gain error 25 getting ctrl Horizontal Flip error 25 getting ctrl Vertical Flip error 25 getting ctrl Color Effects orange@orangepipc:~/tmp$ orange@orangepipc:~/tmp$ sudo mpv av://v4l2:/dev/video0 --vo=vdpau --hwdec=vdpau --hwdec-codecs=all --fs LIBGL: Initialising glshim Playing: av://v4l2:/dev/video0 (+) Video --vid=1 (rawvideo) [VDPAU SUNXI] VE version 0x1680 opened [VDPAU SUNXI] OSD disabled! Using hardware decoding (vdpau). Image formats incompatible or invalid. Video filter chain: [in] 1280x720 yuv420p[nv12] bt.709/limited CL=unknown <--- [out] ??? Falling back to software decoding. VO: [vdpau] 1280x720 yuv420p EDIT: but manual built mpv works fine. [cpu occupation: ~20%] orange@orangepipc:~/tmp/mpv-build/mpv/build$ sudo ./mpv av://v4l2:/dev/video0 --vo=vdpau --hwdec=vdpau --hwdec-codecs=all --fs LIBGL: Initialising glshim Playing: av://v4l2:/dev/video0 (+) Video --vid=1 (rawvideo 1280x720 8.000fps) [VDPAU SUNXI] VE version 0x1680 opened [VDPAU SUNXI] OSD disabled! Using hardware decoding (vdpau). VO: [vdpau] 1280x720 yuv420p [VDPAU SUNXI] Presentation time not supported V: 00:00:25 / 00:00:00
sailfish009 Posted August 23, 2017 Author Posted August 23, 2017 i think there is some bug for rootfs(or bootloader?) in armbian 5.30, because, if i install armbian 5.20 and upgrade(apt-get update and upgrade and ftp.de.debian.org) to 5.31 and install manual built kernel and uboot, then gc2035 works fine. but, if i install armbian 5.30(another SD-card) and install manual built kernel and uboot, then gc2035 doesn't worked.
