it should be noted that all this is very very early bringup work not really useable for anything - iirc. no display, no cpu frequency scaling, no emmc etc. - all is still very much hacked together etc. ... it is good for people interested and having the skills to help in bringing this platform up but nothing yet for people wanting to really use this hardware ... this should be kept in mind when playing around with those patches ...
if anyone has a Radxa cubie A5E and wants to test the lastest bringup work here you go. I don't own the other h728/a523/t527 boards so I can't test them. I willl not provide images because this is experimental.
git clone https://github.com/NickAlilovic/build.git  --branch warpme-6.12 --single-branch
Edited by Nick A
Hi Juan, I'm having the same issue. I believe it's due to this scp.bin file that's needed by a523 u-boot. Trying to figure out how to modify the build scripts to add scp.bin before u-boot compiles. I tried to add a patch to include this binary but I would get an error about patching binary files not supported.
https://github.com/warpme/minimyth2/tree/master/script/bootloaders/board-a527.cubie_a5e/files
I also need to add extlinux.conf or boot.cmd/boot.scr.
nano /home/juanesf91/build/config/bootscripts/extlinux
label ARMBIAN
    kernel /vmlinuz-6.12.12-edge-sunxi
    fdt /dtbs/allwinner/sun55i-a527-radxa-a5e.dtb
    append earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p2 rw rootwait
nano config/boards/radxa-cubie-a5e.csc
BOOT_FDT_FILE="dtb/allwinner/sun55i-a527-radxa-a5e.dtb"
BOOTFS_TYPE="fat"
BOOTSCRIPT="extlinux"
IMAGE_PARTITION_TABLE="msdos"
BOOTSTART="1"
BOOTSIZE="512"
ROOTSTART="513"
UBOOT_EXTLINUX=yes"
UBOOT_EXTLINUX_ROOT=root=UUID=%%ROOT_PARTUUID%%"
UBOOT_EXTLINUX_FDT="sun55i-a527-radxa-a5e.dtb"
fdisk -l output/images/Armbian-unofficial_25.02.0-trunk_Radxa-cubie-a5e_bookworm_edge_6.12.12_minimal.img
Disk output/images/Armbian-unofficial_25.02.0-trunk_Radxa-cubie-a5e_bookworm_edge_6.12.12_minimal.img: 1.81 GiB, 1946157056 bytes, 3801088 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xd91fa24c
Device        Boot   Start     End Sectors  Size Id Type
output/images/Armbian-unofficial_25.02.0-trunk_Radxa-cubie-a5e_bookworm_edge_6.12.12_minimal.img1         8192 1056767 1048576  512M ea Linux extended boot
output/images/Armbian-unofficial_25.02.0-trunk_Radxa-cubie-a5e_bookworm_edge_6.12.12_minimal.img2      1056768 3801087 2744320  1.3G 83 Linux
Thanks Juan, I was able to boot the kernel with some changes.
I used this extlinux.conf file. Changed the kernel to /Image and fdt to /dtb. I manually created a directory called extlinux in the boot directory. I then moved the extlinux.conf there.
/extlinux/extlinux.conf
label ARMBIAN
    kernel /Image
    fdt /dtb/allwinner/sun55i-a527-radxa-a5e.dtb
radxa-cubie-a5e.csc
I changed one line BOOTSCRIPT="extlinux.conf"
# Allwinner Cortex-A55 octa core 2/4GB RAM SoC USB3 USB-C 2x GbE
BOARD_NAME="radxa cubie a5e"
BOARDFAMILY="sun55iw3"
BOARD_MAINTAINER="Nick A"
BOOTCONFIG="radxa-a5e_defconfig"
OVERLAY_PREFIX="sun55i-a527"
BOOT_LOGO="desktop"
KERNEL_TARGET="edge"
FORCE_BOOTSCRIPT_UPDATE="yes"
BOOTFS_TYPE="fat"
BOOTSTART="1"
BOOTSIZE="512"
ROOTSTART="513"
UBOOT_EXTLINUX=yes"
Most Armbian boards use the boot.cmd for their bootscript. I found the line I missed in build/config/sources/families/sun55iw3.conf. I cloned a clean build and changed one line in sun55iw3.conf.
declare -g BOOTSCRIPT='boot-sun50i-next.cmd:boot.cmd'
declare -g ATF_TARGET_MAP="PLAT=sun55i_a523 DEBUG=1 bl31;;build/sun55i_a523/debug/bl31.bin"
declare -g ATFBRANCH="branch:a523"
declare -g BOOTDELAY=1
declare -g BOOTSOURCE='https://github.com/apritzel/u-boot'
    _             _    _                             __  __ _    _      _
   /_\  _ _ _ __ | |__(_)__ _ _ _ ___ _  _ _ _  ___ / _|/ _(_)__(_)__ _| |
  / _ \| '_| '  \| '_ \ / _` | ' \___| || | ' \/ _ \  _|  _| / _| / _` | |
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|   \_,_|_||_\___/_| |_| |_\__|_\__,_|_|
 v25.02 rolling for radxa cubie a5e running Armbian Linux 6.12.12-edge-sun55iw3
 Packages:     Debian stable (bookworm)
 Updates:      Kernel upgrade enabled and 6 packages available for upgrade
 Support:      DIY (custom image)
 IP addresses: (LAN) IPv4:  IPv6:
 Performance:
 Load:         5%           	Up time:       4 min
 Memory usage: 4% of 3.83G
Usage of /:    3% of 58G
 Commands:
 Configuration : armbian-config
 Upgrade       : armbian-upgrade
 Monitoring    : htop
nick@radxa-cubie-a5e:~$
Edited by Nick A
Great, last night was too late and did not finish playing with the boot partition to achieve it. Arriving home in a while I will compile and try
My build uses warpme-6.12 patches so people with other boards can make a board config to compile their own images.
https://github.com/NickAlilovic/build/blob/warpme-6.12/config/boards/radxa-cubie-a5e.csc
https://github.com/NickAlilovic/build/tree/warpme-6.12/patch/kernel/archive/warpme-6.12
1170-arm64-dts-allwinner-h728-add-x96q-pro-tvbox-plus.patch
1172-arm64-dts-allwinner-t527-add-orangepi-4a-dts.patch
1173-arm64-dts-allwinner-a527-add-Radxa-A5E-support.patch
Orangepi 4a uses the same radxa-a5e_defconfig.
https://github.com/warpme/minimyth2/blob/master/script/bootloaders/board-t527.orangepi_4a/Makefile
x96q_pro_plus_defconfig
 https://github.com/warpme/minimyth2/blob/master/script/bootloaders/board-h728.x96q_pro_plus/Makefile
Edited by Nick A
    _             _    _                             __  __ _    _      _
 IP addresses: (LAN) IPv4: *.*.*.* IPv6: *::*:*:*:* (WAN) *.*.*.*
 Performance:
 Load:         1%               Up time:       10 min
 Memory usage: 3% of 3.83G
Usage of /:    4% of 29G
 Commands:
 Monitoring    : htop
Thank you for the hard work! I was also able to run the image with your latest changes.
Things that didn't work for me yet (but of course expected at this time):
- WLAN/bluetooth
- NVME SSD
Thank you, I can confirm I got wifi working.
It seems it's not using its full capabilities yet, I believe M8800DS2 can reach 600Mbps?
root@radxa-cubie-a5e:~# speedtest -I wlan0 (5Ghz)
   Speedtest by Ookla
      Server: Odido - Amsterdam (id: -)
         ISP: Odido Netherlands
Idle Latency:     4.23 ms   (jitter: 17.23ms, low: 4.14ms, high: 38.60ms)
    Download:    98.09 Mbps (data used: 74.8 MB)
                 21.69 ms   (jitter: 3.98ms, low: 4.55ms, high: 30.03ms)
      Upload:    95.48 Mbps (data used: 43.1 MB)
                 39.30 ms   (jitter: 2.27ms, low: 10.70ms, high: 43.91ms)
 Packet Loss:     0.0%
  Result URL: -
root@radxa-cubie-a5e:~# speedtest -I wlan0 (2.4Ghz)
   Speedtest by Ookla
Idle Latency:     6.20 ms   (jitter: 1.25ms, low: 5.49ms, high: 8.00ms)
    Download:     8.57 Mbps (data used: 13.6 MB)
                244.00 ms   (jitter: 64.45ms, low: 11.59ms, high: 793.78ms)
      Upload:     2.13 Mbps (data used: 3.9 MB)
                343.91 ms   (jitter: 74.53ms, low: 20.12ms, high: 2764.11ms)
 Packet Loss:     0.0%
  Result URL: -
root@radxa-cubie-a5e:~# speedtest -I end0
   Speedtest by Ookla
Idle Latency:     3.23 ms   (jitter: 0.29ms, low: 2.83ms, high: 3.36ms)
    Download:   745.43 Mbps (data used: 741.8 MB)
                 31.46 ms   (jitter: 38.90ms, low: 3.39ms, high: 397.61ms)
      Upload:   834.05 Mbps (data used: 397.4 MB)
                 41.68 ms   (jitter: 44.13ms, low: 2.73ms, high: 459.89ms)
 Packet Loss:     0.0%
  Result URL: -
Hello everyone!
I apologize for using a neural translation, but I'm as not strong in English as I am in assembling Linux. I have purchased an OrangePI 4A to use as a host for Klipper on my 3D printer, but I encountered a problem: none of the official images include CAN bus support modules, which are absolutely essential for me.
Unfortunately, I was unable to build an image myself using WSL. Could someone here share a compiled image for this board with CAN modules included?
@Nick A Thanks for all your work! I have been trying to compile the image to test using your code, but I keep receiving the following error:
 make[2]: *** [scripts/kconfig/Makefile:75: syncconfig] Error 1
[🐳|🔨]   make[1]: *** [Makefile:586: syncconfig] Error 2
[🐳|🔨]   make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'.  Stop.
I'm sorry for the neuro translation.
Thank you for the work done, thanks to you, I began to understand this new wonderful world more)
Target device: orange pi 4A
I tried to collect it from a branch yesterday https://github.com/NickAlilovic/build/tree/warpme-6.12 an image for armbian. But the image does not start after I uploaded it to the SD card with the indication radxa-cubie-a5e.
There is currently no way to check through FTDI.
I did the launch via ./compile.sh docker-shell
Could you give me a hint?:
1. Tell me with what parameters you run the image build.
2. Whether it is necessary to make changes to the instructions for the importer specified above.
Tonight, I finally managed to build an image on the OPI4a itself. However, after writing it to the eMMC using Balena Etcher, the board did not boot. If I understood Nick A's message correctly: 'Orangepi 4a uses the same radxa-a5e_defconfig. https://github.com/warpme/minimyth2/blob/master/script/bootloaders/board-t527.orangepi_4a/Makefile', I needed to select the radxa-a5e board from the list.
Here's what I did:
bash
git clone https://github.com/NickAlilovic/build.git --branch warpme-6.12 --single-branch cd build ./compile.sh
I selected the radxa-a5e board, edge, bookworm, server, standard. The image was compiled, and then I wrote it to the eMMC via Balena Etcher.
After powering on, the board shows no signs of activity. I suspect that some patch or bootloader was not included in the image. Unfortunately, my knowledge is insufficient to understand what I did wrong and how to fix the issue. I kindly ask for your help.
After looking at the Minimyth2 sources again. Orangepi 4a uses the same u-boot. But the exlinux.conf changes the fdt. (flat device tree) before it boots the kernel.
fdt /dtbs/allwinner/sun55i-t527-orangepi-4a.dtb
https://github.com/warpme/minimyth2/blob/master/script/bootloaders/board-t527.orangepi_4a/files/extlinux.conf
My build uses boot-sun50i-next.cmd instead of exlinux.conf.
https://github.com/NickAlilovic/build/blob/warpme-6.12/config/sources/families/sun55iw3.conf
# DO NOT EDIT THIS FILE
# Please edit /boot/armbianEnv.txt to set supported parameters
https://github.com/NickAlilovic/build/blob/warpme-6.12/config/bootscripts/boot-sun50i-next.cmd
So to change the dtb you need to add this in your /boot/armbianEnv.txt
fdtfile=sun55i-t527-orangepi-4a.dtb
Remember this is early mainline uboot and linux bring up work. There's no HDMI. You'll need a USB to TTL serial converter connected to your uart pins.
Edited by Nick A
I'm continuing to try compiling the image.
I created a file named "orangepi-4a-dts.csc" with the following content (idk is that correct)
BOARD_NAME="Orangepi-4a"
BOOT_LOGO="desktop"
function post_family_tweaks__radxa_cubie-a5e() {
	display_alert "Applying wifi firmware"
	pushd "$SDCARD/lib/firmware"
	ln -s "aic8800/SDIO/aic8800D80" "aic8800_sdio" # use armbian-firmware
	popd
placed it in /build/config/boards.
started the build with the command
./compile.sh EXPERT="yes" KERNEL_GIT="FULL"
Select
Show a kernel configuration menu before compilation (just for check is CAN из selected)
Board: orangepi-4a-dts
Kernel: edge
Release package base: bookworm
Image type: Image with console interface (server)
			Standard image with console interface
Run build
Flash with BalenaEtcher to eMMC and try to start my OPI4A
And again, no any kind of activity after board starts, only red led is light up
Build log attached. Please, help with bilding img for this board
log-build-no-uuidgen-yet-8696-91019.log.ans
While I was writing the message, Nick A already replied. I'll check it now and let you know the result.
Does this mean that HDMI will not work at all with this image?
Nope, you are better off sticking with vender supplied images if you need hdmi support. It may take months before there's a working hdmi.
Edited by Nick A
I would be glad, but I really need CAN BUS support, which is not available in the official images. I haven't been able to add CAN kernel modules to the official image by any means.
HDMI is not the most essential feature. If SSH and CAN work correctly, that will suffice for me as a temporary solution even over an extended period.
Edited by ZlobniyDaemon
Does this need to be done in the already assembled image or in the files before assembly?
There's a board that's similar to orangepi 4a called Avaota A1.
https://github.com/armbian/build/blob/main/config/boards/avaota-a1.csc
This script uses the legacy kernel and drivers that come with the Avaota A1 vender image. Orangepi probably uses a similar kernel source so I don't know if it will make any difference.
	legacy)
		KERNELSOURCE='https://github.com/AvaotaSBC/linux.git'
		# This is Allwinner's new BSP kernel,
		# which consists of a specific version of the mainline kernel source code and a folder containing BSP driver source code files.
		KERNELBRANCH="branch:linux-5.15"
		declare -g KERNEL_MAJOR_MINOR="5.15"
		KERNELPATCHDIR="sun55iw3-syterkit-${BRANCH}"
		LINUXCONFIG="linux-sun55iw3-syterkit-${BRANCH}"
https://github.com/armbian/build/blob/main/config/sources/families/sun55iw3-syterkit.conf
orangepi 4a
https://github.com/orangepi-xunlong/orangepi-build/blob/next/external/config/sources/families/sun55iw3.conf
https://github.com/orangepi-xunlong/orangepi-build/blob/next/external/config/sources/arm64.conf
Edited by Nick A
Already assembled image. After you write to your SDcard. Edit the file /boot/armbianEnv.txt.
Again this is early bring up work. This will only boot off SDcard not your internel eMMC.
Edited by Nick A
Is it possible that there are any non-minimal builds on earlier kernel versions?
Have you tried building your own orangepi 4a image using the orangpi build scripts? Maybe the build script will let you edit the kernel config or you can replace it with your own.
https://github.com/orangepi-xunlong/orangepi-build/tree/next
https://github.com/orangepi-xunlong/orangepi-build/blob/0a00a8bc4d7874643203c38fe3c62943931397b3/external/config/kernel/linux-5.15-sun55iw3-current.config
