Marvin-03 Posted Sunday at 09:35 PM Posted Sunday at 09:35 PM (edited) Am 3.1.2026 um 22:15 schrieb L. Jorge Soares: resetting ... sunxi_set_gate: (CLK#35) unhandled U-Boot SPL 2026.01-rc4_armbian-2026.01-rc4-S0e0a-P5fd4-H5aa4-Vd69a-B4d1d-R448a (Jan 03 2026 - 15:39:28 -0500) DRAM: 4096 MiB Failed to set core voltage! Can't set CPU frequency Trying to boot from MMC1 NOTICE: BL31: v2.12.0(debug):armbian NOTICE: BL31: Built : 14:33:47, Jan 3 2026 NOTICE: BL31: Detected Allwinner A523 SoC (1890) NOTICE: BL31: Found U-Boot DTB at 0xa0a8d48, model: OrangePi 4A INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: Maximum SPI INTID supported: 287 INFO: Configuring SPC Controller INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a55: CPU workaround for erratum 1530923 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 ns16550_serial serial@2500000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2026.01-rc4_armbian-2026.01-rc4-S0e0a-P5fd4-H5aa4-Vd69a-B4d1d-R448a (Jan 03 2026 - 15:39:28 -0500) Allwinner Technology CPU: Allwinner A523 (SUN55I) Model: OrangePi 4A DRAM: 4 GiB Core: 65 devices, 21 uclasses, devicetree: separate WDT: Not starting watchdog@2050000 MMC: mmc@4020000: 0, mmc@4021000: 1, mmc@4022000: 2 Loading Environment from FAT... ** No valid partitions found ** In: serial@2500000 Out: serial@2500000 Err: serial@2500000 Net: No ethernet found. Hit any key to stop autoboot: 0 PCIe: Acquiring resources... PCIe: Failed to parse num-lanes, using default: 1 PCIe: Failed to get switch-sel GPIO: -2 PCIe: Hardware init failed with error -2 Device 0: unknown device switch to partitions #0, OK mmc0 is current device ** Invalid partition 1 ** Couldn't find partition mmc 0:1 PCIe: Acquiring resources... PCIe: Failed to parse num-lanes, using default: 1 PCIe: Failed to get switch-sel GPIO: -2 PCIe: Hardware init failed with error -2 No ethernet found. missing environment variable: pxeuuid Retrieving file: pxelinux.cfg/00000000 No ethernet found. Retrieving file: pxelinux.cfg/0000000 No ethernet found. Retrieving file: pxelinux.cfg/000000 No ethernet found. Retrieving file: pxelinux.cfg/00000 No ethernet found. Retrieving file: pxelinux.cfg/0000 No ethernet found. Retrieving file: pxelinux.cfg/000 No ethernet found. Retrieving file: pxelinux.cfg/00 No ethernet found. Retrieving file: pxelinux.cfg/0 No ethernet found. Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi No ethernet found. Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. Retrieving file: pxelinux.cfg/default-arm No ethernet found. Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found PCIe: Acquiring resources... PCIe: Failed to parse num-lanes, using default: 1 PCIe: Failed to get switch-sel GPIO: -2 PCIe: Hardware init failed with error -2 No ethernet found. No ethernet found. Can you test these commands in u-boot? mmc list mmc info mmc dev 0 mmc part fatls mmc 0:1 ext4ls mmc0:2 mmc read 0x40000000 0 1 It seems like mega doesnt work anymore without login. Here are the images on gdrive: https://drive.google.com/drive/folders/1jEIWmzZgT5t39jRz7GwZpFOAdjdQBLtG?usp=drive_link Edited Sunday at 09:37 PM by Marvin-03 0 Quote
L. Jorge Soares Posted Sunday at 10:33 PM Posted Sunday at 10:33 PM @Marvin-03 Here are the results of the commands provided, hope this help. Thanks for the link of your image builds, will try them out. Quote => mmc list mmc@4020000: 0 (SD) mmc@4021000: 1 mmc@4022000: 2 => mmc info Device: mmc@4020000 Manufacturer ID: 3 OEM: 5344 Name: AFGCD Bus Speed: 50000000 Mode: SD High Speed (50MHz) Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 29.7 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes => mmc dev 0 switch to partitions #0, OK mmc0 is current device => mmc part Partition Map for mmc device 0 -- Partition Type: EFI => fatls mmc 0:1 ** Invalid partition 1 ** Couldn't find partition mmc 0:1 => ext4ls mmc 0:2 ** Invalid partition 2 ** Couldn't find partition mmc 0:2 => fatls mmc0:1 ** No device specified ** Couldn't find partition mmc0:1 <NULL> => ext4ls mmc0:2 ** No device specified ** Couldn't find partition mmc0:2 <NULL> => mmc read 0x40000000 0 1 MMC read: dev # 0, block # 0, count 1 ... 1 blocks read: OK => 0 Quote
Marvin-03 Posted Monday at 01:55 PM Posted Monday at 01:55 PM vor 15 Stunden schrieb L. Jorge Soares: => mmc list mmc@4020000: 0 (SD) mmc@4021000: 1 mmc@4022000: 2 => mmc info Device: mmc@4020000 Manufacturer ID: 3 OEM: 5344 Name: AFGCD Bus Speed: 50000000 Mode: SD High Speed (50MHz) Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 29.7 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes => mmc dev 0 switch to partitions #0, OK mmc0 is current device => mmc part Partition Map for mmc device 0 -- Partition Type: EFI => fatls mmc 0:1 ** Invalid partition 1 ** Couldn't find partition mmc 0:1 => ext4ls mmc 0:2 ** Invalid partition 2 ** Couldn't find partition mmc 0:2 => fatls mmc0:1 ** No device specified ** Couldn't find partition mmc0:1 <NULL> => ext4ls mmc0:2 ** No device specified ** Couldn't find partition mmc0:2 <NULL> => mmc read 0x40000000 0 1 MMC read: dev # 0, block # 0, count 1 ... 1 blocks read: OK => Did you get an error when using balena etcher? I tried flashing the image myself and it wouldnt create any partitions. I uploaded an image with a repaired partition table to gdrive and mega. Alternatively, you can use gparted to repair the image yourself. Just put: sudo gdisk /path/to/Armbian-unofficial_26.02.0-trunk_Orangepi4a_trixie_edge_6.18.0.img r (recovery), then d (recreate primary header), then w (write) into wsl or linux. 0 Quote
L. Jorge Soares Posted Monday at 02:42 PM Posted Monday at 02:42 PM I did get an alert from BalenaEtcher, when writting the IMG file to SD. It reported not having a BOOT partition. I continued through the alert and the PI board did boot to the prompt results I originally reported. I am going try you image now and will let you know. 0 Quote
L. Jorge Soares Posted Monday at 03:14 PM Posted Monday at 03:14 PM (edited) @Marvin-03 ** run the commands to fix partitions on my IMG build, just like you mentioned and it fixed it.** Your Orangepi4a img is working, I am able to BOOT. But I am accessing the board through the console. Confirmation of the boot is below. I also had a look at the partitions from the IMG created of the GIT build and your own image. See details below. Quote _ _ _ __ __ _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ ___ _ _ _ _ ___ / _|/ _(_)__(_)__ _| | / _ \| '_| ' \| '_ \ / _` | ' \___| || | ' \/ _ \ _| _| / _| / _` | | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| \_,_|_||_\___/_| |_| |_\__|_\__,_|_| v26.02 rolling for Orange Pi 4a running Armbian Linux 6.18.0-edge-sun55iw3 Packages: Debian stable (trixie) Support: DIY (custom image) IPv4: (LAN) 10.10.10.191 (WAN) ##.##.##.## Performance: Load: 14% Uptime: 4 minutes Memory usage: 4% of 3.83G Usage of /: 7% of 29G Tips: Armbian config utility https://tinyurl.com/yc39n6m3 Commands: Configuration : armbian-config Monitoring : htop root@orangepi4a:~# This is the partitions list of the IMG build of GIT Quote Disk /dev/sdc: 29.72 GiB, 31914983424 bytes, 62333952 sectors Disk model: MassStorageClass Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x00000000 Device Boot Start End Sectors Size Id Type /dev/sdc1 1 62333951 62333951 29.7G ee GPT This is the partition list of your IMG for comparison Quote Disk /dev/sdc: 29.72 GiB, 31914983424 bytes, 62333952 sectors Disk model: MassStorageClass Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 09A4CB82-9D1D-424A-BA48-7D406DF8EF24 Device Start End Sectors Size Type /dev/sdc1 8192 1056767 1048576 512M Linux extended boot /dev/sdc2 1056768 5683199 4626432 2.2G Linux root (ARM-64) Edited Monday at 04:54 PM by L. Jorge Soares 0 Quote
L. Jorge Soares Posted Monday at 09:26 PM Posted Monday at 09:26 PM @Marvin-03 Looks like your GIT no longer has the changes for OrangePI4a board available. 0 Quote
Werner Posted Tuesday at 08:07 AM Posted Tuesday at 08:07 AM Looks like stuff got lost due to force-push. Check this how it looked before: https://github.com/rvdr/build/activity?ref=spi-nvme-patches 1 Quote
Marvin-03 Posted Tuesday at 03:29 PM Posted Tuesday at 03:29 PM (edited) Am 5.1.2026 um 22:26 schrieb L. Jorge Soares: Looks like your GIT no longer has the changes for OrangePI4a board available. I updated my patches to the new style (using series.conf) and that took some time. They are back online, as are some new images. I post more updates at the opi discord btw. The image doesnt work stable atm. Network works, pcie and spi flash doesnt. Edited 17 hours ago by Marvin-03 1 Quote
JuanEsf Posted 23 hours ago Posted 23 hours ago https://drive.google.com/drive/folders/1dx0TApPAEjFDz24Rm22J4jgtIbJrYYHC?usp=drive_link build log: url for test... 0 Quote
