Julio Amorales Posted January 19 Posted January 19 (edited) I switched armbian repo to stable via armbian-config 24.11.2. The first thing it did, judging by /var/log/apt/history.log, was purging linux-image*: Start-Date: 2025-01-04 22:47:25 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y purge linux-image* Requested-By: user (1000) Purge: linux-image-current-sunxi64:arm64 (24.11.1) End-Date: 2025-01-04 22:47:27 Then it proceeded to purge and reinstall dtb and armbian-firmware, but not linux-image: Start-Date: 2025-01-04 22:48:34 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y purge linux-dtb* Requested-By: user (1000) Purge: linux-dtb-current-sunxi64:arm64 (24.11.1) End-Date: 2025-01-04 22:48:35 Start-Date: 2025-01-04 22:48:54 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 --allow-downgrades -y install linux-dtb-current-sunxi64 Requested-By: user (1000) Install: linux-dtb-current-sunxi64:arm64 (24.11.1) End-Date: 2025-01-04 22:48:55 Start-Date: 2025-01-04 22:49:18 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y purge armbian-firmware* Requested-By: user (1000) Purge: armbian-firmware:arm64 (24.11.2) End-Date: 2025-01-04 22:49:19 Start-Date: 2025-01-04 22:49:47 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 --allow-downgrades -y install armbian-firmware Requested-By: user (1000) Install: armbian-firmware:arm64 (24.11.2) End-Date: 2025-01-04 22:50:01 I don't know if this is an error in the script, or in package dependencies, but getting an unbootable system was very unpleasant Edited January 19 by Julio Amorales 0 Quote
MaxT Posted January 19 Posted January 19 Had a very same issue just recently. Guess there is no check in armbian-config whether package was downloaded before removing an old one and in case of multiple packages this is done one by one package rather than downloading all required before processing further.Failure to download might relate to mirror availability - seems that every new download might be from a different mirror- in my case dtbs were installed, but kernel only removed.Ad-hoc solution- keep bootable usb or sd to chroot and fix. 0 Quote
Igor Posted 8 hours ago Posted 8 hours ago On 1/19/2025 at 9:20 PM, MaxT said: Guess there is no check in armbian-config whether package was downloaded before removing an old one and in case of multiple packages this is done one by one package rather than downloading all required before processing further. This is the mechanism: https://github.com/armbian/configng/blob/main/tools/modules/system/module_armbian_firmware.sh#L106-L107 In case anyone can spot the bug. Digging into ... Trying to reproduce - fail: Spoiler v25.5 rolling for NanoPi K1 Plus running Armbian Linux 6.6.72-current-sunxi64 igorp@nanopik1plus:~$ sudo tail -f /var/log/apt/history.log [sudo] password for igorp: Start-Date: 2025-02-06 13:36:03 Commandline: apt-get -y -qq -o Dpkg::Use-Pty=0 -o APT::Get::List-Cleanup=0 --no-install-recommends install armbian-config Install: armbian-config:arm64 (25.5.0-trunk.5.0206.130706), whiptail:arm64 (0.52.23-1+b1, automatic), libtext-iconv-perl:arm64 (1.7-8, automatic), libnewt0.52:arm64 (0.52.23-1+b1, automatic) End-Date: 2025-02-06 13:36:05 Start-Date: 2025-02-07 07:05:54 Commandline: apt upgrade Upgrade: armbian-config:arm64 (25.5.0-trunk.5.0206.130706, 25.5.0-trunk.5.0206.155506) End-Date: 2025-02-07 07:05:55 Start-Date: 2025-02-07 07:07:21 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y autopurge linux-image* Purge: linux-image-current-sunxi64:arm64 (25.5.0-trunk.4) End-Date: 2025-02-07 07:07:23 Start-Date: 2025-02-07 07:07:40 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y install --allow-downgrades linux-image-current-sunxi64 Install: linux-image-current-sunxi64:arm64 (24.11.1) End-Date: 2025-02-07 07:08:35 Start-Date: 2025-02-07 07:08:53 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y autopurge linux-dtb* Purge: linux-dtb-current-sunxi64:arm64 (25.5.0-trunk.4) End-Date: 2025-02-07 07:08:54 Start-Date: 2025-02-07 07:09:08 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y install --allow-downgrades linux-dtb-current-sunxi64 Install: linux-dtb-current-sunxi64:arm64 (24.11.1) End-Date: 2025-02-07 07:09:09 Start-Date: 2025-02-07 07:09:28 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y autopurge armbian-firmware* Purge: armbian-firmware:arm64 (25.5.0-trunk.4) End-Date: 2025-02-07 07:09:28 Start-Date: 2025-02-07 07:09:49 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y install --allow-downgrades armbian-firmware Install: armbian-firmware:arm64 (24.11.3) End-Date: 2025-02-07 07:10:09 Recreated ! Nightly to stable, fine, going back to nightly it fails - it just removes packages, while not installing new due to repo troubles. Start-Date: 2025-02-07 07:14:22 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y autopurge linux-image* Purge: linux-image-current-sunxi64:arm64 (24.11.1) End-Date: 2025-02-07 07:14:24 Start-Date: 2025-02-07 07:14:45 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y autopurge linux-dtb* Purge: linux-dtb-current-sunxi64:arm64 (24.11.1) End-Date: 2025-02-07 07:14:46 Start-Date: 2025-02-07 07:15:07 Commandline: apt-get -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y autopurge armbian-firmware* Purge: armbian-firmware:arm64 (24.11.3) End-Date: 2025-02-07 07:15:08 0 Quote
Solution Igor Posted 4 hours ago Solution Posted 4 hours ago This https://github.com/armbian/configng/pull/424/files should fix it. Update will be avail in couple of minutes after the merge. Thank you! apt update & upgrade will update armbian-config where this works as expected. Until next bug found ... 0 Quote
