Jorge Cury Posted January 20, 2025 Posted January 20, 2025 Hi everybody, I installed Deb 12 Cinnamon Armbian flavor. This: dl.armbian.com/orangepi5-plus/Bookworm_current_cinnamon-backported-mesa When I open system setup there is no Idiom/Language Icon. So all apps remains in English. Even if I run "sudo dpkg-reconfigure keyboard-configuration" and "sudo dpkg-reconfigure locales" I found an issue running "armbian-config"/localization/change Keyboard layout, on console this msg "setupcon: We are not on the console, the console is left unconfigured." But if I run "sudo dpkg-reconfigure keyboard-configuration" from a terminal window no error. Thanks, Cury 0 Quote
Werner Posted January 20, 2025 Posted January 20, 2025 If this works from terminal but not from within armbian-config I suggest to report here: https://github.com/armbian/configng/issues 0 Quote
Jorge Cury Posted January 21, 2025 Author Posted January 21, 2025 Hi Werner, Issue about armbian-config openned. Idiom/Language issue remains unsolved. See you soon, Cury 0 Quote
