Turn off the leds (pwr_led)
Go to solution Solved by Torte,
It largely depends on the system.
A simple "echo 0 > /sys/devices/platform/leds/leds/system-led/brightness" will kill the heartbeat on a T6. (The heartbeat itself is activated in the DTB.)
The other leds should available along the same path (user_led, etc.).
NB I have found no other way of restoring the heartbeat than rebooting.
As mentioned it might be possible or not. Depends on board.
Check /sys for keywords led and trigger.
cat the trigger file/s to get an idea what values it accepts.
  • Solution
I wrote a small guide for customizing the status LED's behaviour on the MKS-Klipad50 board.
The available LEDs and their names in "/sys/class/leds/" will be different on other boards, but the general behaviour should be the same. Just make sure to change the filenames like "firefly:blue:user" in the examples to those available on your system.
Below is the brightness file I found in the /sys folder. Unfortunately, I can't turn off the pwr_led light no matter what I try. I have been able to turn off the light on devices such as raspberry 3b and king3399 before, so I don't know if it is a system problem?
# root @ nanopct4 in /sys [12:13:15]
$ find . -name "*brightness*"
./devices/platform/gpio-leds/leds/status_led/brightness
./devices/platform/gpio-leds/leds/status_led/max_brightness
./devices/platform/fe330000.mmc/leds/mmc2::/brightness
./devices/platform/fe330000.mmc/leds/mmc2::/max_brightness
(Please ignore, this doesn't apply to the NanoPC T4)
You can try if the LEDs show up after "sudo modprobe pinctrl-rk805".
The switch from rockchip64 kernel 6.6.x to 6.12.x included a change that made the "pinctrl-rk805" being built as a module instead of compiled-in. That module does not get autoloaded, so it has to be added to /etc/modules.
On the Klipad50, the gpio-leds are attached to the rk805 gpio bank, which is not known to the system without that kernel module. Only after loading that module, the LEDs appeared under /sys/class/leds and started working.
Edit:
- Board is NanoPC T4 - sorry, I haven't seen the label
- The NanoPC T4 does not have the rk805 controller, so this posting does not apply.
Edit#2:
Do "sudo gpioset 0 13=1" or "sudo gpioset 0 13=0" change the LED state?
Edited by Torte
I managed to disable heartbeat.
I am running HA based on debian trixie and my it was only led i could change to off
echo 0 | sudo tee /sys/class/leds/state-led/brightness
Edited by linuxenjoerno
