Meestor_X Posted February 15 Posted February 15 (edited) So, looking to create a CLI version of armbian-install. Only has to work with the rockpi-s and from the SD card to the eMMC. Looking at this script: If it works to clone the SD to eMMC (with some changes?) then I need to tell armbian to boot from the eMMC when the SD card isn't inserted, same way that armbian-install does. Do I simply change the UUID line in /boot/armbianEnv.txt to the UUID of the eMMC, or do I need to edit /etc/fstab or ?? Edited February 15 by Meestor_X 0 Quote
Meestor_X Posted February 16 Author Posted February 16 Edited both /boot/armbianEnv.txt and /etc/fstab but it still doesn't boot. Blue light never even comes on. 0 Quote
Meestor_X Posted February 21 Author Posted February 21 Can anyone point me in the right direction on what needs to be done to make a partition boot? 0 Quote
Meestor_X Posted Tuesday at 10:51 PM Author Posted Tuesday at 10:51 PM Wish I could find an ELI5 document for how to create a bootable copy of an Armbian image using the command line. 0 Quote
Werner Posted Wednesday at 04:59 AM Posted Wednesday at 04:59 AM the bootloader needs to be installed on emmc separately. armbian-install usually takes care of that. How to debug boot issues: https://debug.armbian.de 0 Quote
Meestor_X Posted Wednesday at 03:18 PM Author Posted Wednesday at 03:18 PM Thank you for your reply. Do you know what the command is for installing the bootloader? I want to automate the process and armbian-install doesn't seem to have a way to be run via command line. Reading and following the operation of armbian-install is next to impossible. 0 Quote
Meestor_X Posted Wednesday at 04:08 PM Author Posted Wednesday at 04:08 PM Would these be the correct commands? dd if=/usr/lib/linux-u-boot-current-rockpi-s/idbloader.bin of=/dev/mmcblk0 seek=64 conv=notrunc status=none dd if=/usr/lib/linux-u-boot-current-rockpi-s/uboot.img of=/dev/mmcblk0 seek=16384 conv=notrunc status=none dd if=/usr/lib/linux-u-boot-current-rockpi-s/trust.bin of=/dev/mmcblk0 seek=24576 conv=notrunc status=none Are the "seek" numbers always the same or do they need to be calculated? 0 Quote
Torte Posted Thursday at 08:16 AM Posted Thursday at 08:16 AM You can take a look at the postinstall script from the u-boot package. It should be called sth like "/var/lib/dpkg/info/linux-u-boot-current-rockpi-s.postinst" and should be quite small, so easier to understand. You can extract the required commands from there. Assuming it is similar to my u-boot installer, this could result in a script like this: #!/bin/bash source /usr/lib/u-boot/platform_install.sh write_uboot_platform "$DIR" /dev/mmcblk0 sync That way you don't have to handle the hardcoded sector offsets yourself (not sure, if these offsets would ever change - but if they do, then that will probably be reflected in the platform_install script). 0 Quote
