wolph Posted December 11, 2015 Posted December 11, 2015 Hello! I'm trying to make image for olinuxino lime A10. Prebuild image does not have /dev/uinput and /dev/hidraw for my touchscreen, and built without CONFIG_DRM_KMS_HELPER, so i can't replace broken EDID for my HDMI display. A month ago i succesfully build ubuntu image with uinput and hidraw support. But now - i need to rebuild it again, but kernel compilation fails with this error: LD drivers/media/usb/built-in.o LD drivers/media/built-in.o make: *** [drivers] Error 2 [ error ] Kernel was not built [ @host ] And I don't know where to find error description. The last error was missing libssl-dev. Regards. 1
Igor Posted December 11, 2015 Posted December 11, 2015 We are preparing a new build script, give it a try. http://forum.armbian.com/index.php/topic/404-stable-vs-mainline-for-next/ Logs are in output/debug folder
wolph Posted December 11, 2015 Author Posted December 11, 2015 We are preparing a new build script, give it a try. http://forum.armbian.com/index.php/topic/404-stable-vs-mainline-for-next/ Logs are in output/debug folder With this script - building finished with success. But, unfortunately - black screen after u-boot and armbian logo. Green LED and black screen.
Igor Posted December 11, 2015 Posted December 11, 2015 Ok, tell me which kernel version and/or system did you build? Poslano z mojega MI 2S z uporabo Tapatalk
Andrés Rengifo Posted February 17, 2016 Posted February 17, 2016 I have the same problem while compiling kernel. I am trying to compile wheezy (without desktop and default branch) for the A20-OLinuXino-MICRO board .
Igor Posted February 17, 2016 Posted February 17, 2016 I have the same problem while compiling kernel. I am trying to compile wheezy (without desktop and default branch) for the A20-OLinuXino-MICRO board . Where do you want to compile it? Are you using more or less stock Ubuntu Trusty X86 PC?
Igor Posted February 17, 2016 Posted February 17, 2016 You need 14.04.x Ubuntu to avoid problems and manual fixing.
