Disable ttyS2 console on Radxa ROCK 4C+
Go to solution Solved by IBV,
Hello
I want to disable console on /dev/ttyS2 on a Radxa ROCK 4C+ running
rock@rockpi-4cplus:/boot$ cat /etc/os-release | grep -v URL
PRETTY_NAME="Armbian 25.5.0-trunk.40 noble"
NAME="Ubuntu"
VERSION_ID="24.04"
VERSION="24.04 LTS (Noble Numbat)"
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
UBUNTU_CODENAME=noble
LOGO="armbian-logo"
ARMBIAN_PRETTY_NAME="Armbian 25.5.0-trunk.40 noble"
There are posts and other information out there.
For instance:
https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-toggle-boot-output
which leads to
http://redsymbol.net/linux-kernel-boot-parameters/
rock@rockpi-4cplus:/boot$ grep console armbianEnv.txt
console=both
The information found so far, implies there are options like: none, serial, both, and another
But what is the another option?
So that I can disable console on /dev/ttyS2  and use that for other purposes.
Without compromising the Docs reccomandation: To disable console entirely (not recommended) set console to none
Thanks @SteeMan
Made me stumble upon something similar.
Found armbianmonitor
rock@rockpi-4cplus:~$ sudo armbianmonitor -u
Checked the log.
[    2.614818] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[    2.616480] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
Changed armbianEnv.txt from:
console=both
To:
console=ttyS0
Then a reboot.  That didn't work.
So changing the boot.cmd from:
setenv console "both"
To:
setenv console "ttyS0"
Then
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
and reboot.
ttyS2 console are still enabled.
Connections are verified by reading the connected pins after forcing communication
root@rockpi-4cplus:/home/rock# stty -F /dev/ttyS2 115200 cs8 -parenb -cstopb
root@rockpi-4cplus:/home/rock# while true; do echo -n "A" > /dev/ttyS2; sleep 0.25; done
Connected pins 8 & 10:
image.png.a39beaf27747dac33277379d545350cf.png image.png.5f8de15357c7d734c2bc0a7b4c9bbbb8.png
And log still says:
[ 2.615671] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 2.616076] serial serial0: tty port ttyS0 registered
[ 2.617411] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[ 2.617621] printk: legacy console [ttyS2] enabled
What would be the next step here?
Continuing ...
root@rockpi-4cplus:~# cp /boot/dtb/rockchip/rk3399-rock-4c-plus.dtb rk3399-rock-4c-plus.dtb.backup
root@rockpi-4cplus:~# dtc -I dtb -O dts -o rk3399-rock-4c-plus.dts rk3399-rock-4c-plus.dtb.backup
rk3399-rock-4c-plus.dts: Warning (unit_address_vs_reg): /usb@fe800000: node has a unit name, but no reg or ranges property
rk3399-rock-4c-plus.dts: Warning (unit_address_vs_reg): /usb@fe900000: node has a unit name, but no reg or ranges property
rk3399-rock-4c-plus.dts: Warning (avoid_unnecessary_addr_size): /dsi@ff960000: unnecessary #address-cells/#size-cells without "ranges", "dma-ranges" or child "reg" property
rk3399-rock-4c-plus.dts: Warning (avoid_unnecessary_addr_size): /dsi@ff968000: unnecessary #address-cells/#size-cells without "ranges", "dma-ranges" or child "reg" property
rk3399-rock-4c-plus.dts: Warning (unique_unit_address): /pcie@f8000000: duplicate unit-address (also used in node /pcie-ep@f8000000)
root@rockpi-4cplus:~# vi rk3399-rock-4c-plus.dts
rk3399-rock-4c-plus.dts is attached.
Here is the relevant sections I've found:
	model = "Radxa ROCK 4C+";
	aliases {
		serial2 = "/serial@ff1a0000";
	serial@ff1a0000 {
		compatible = "rockchip,rk3399-uart\0snps,dw-apb-uart";
		reg = <0x00 0xff1a0000 0x00 0x100>;
		clocks = <0x08 0x53 0x08 0x162>;
		clock-names = "baudclk\0apb_pclk";
		interrupts = <0x00 0x64 0x04 0x00>;
		reg-shift = <0x02>;
		reg-io-width = <0x04>;
		pinctrl-names = "default";
		pinctrl-0 = <0x49>;
		status = "okay";
		phandle = <0xe7>;
	__symbols__ {
		uart2 = "/serial@ff1a0000";
What should I do to disable /dev/ttyS2 console?
This would disable it entirely, which is probably not what you want...
It looks like the the the kernel is not picking up the console parameter:
Kernel command line: root=UUID=d0636019-ca11-404a-9874-04e6cbfedf37 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=8dc56fe2-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory
[    0.000000] Unknown kernel command line parameters "splash ubootpart=8dc56fe2-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
Maybe post here the boot.cmd and armbianEnv.txt
Well spotted, thanks
armbianEnv.txt
verbosity=1
bootlogo=true
console=ttyS0
overlay_prefix=rockchip
rootdev=UUID=d0636019-ca11-404a-9874-04e6cbfedf37
rootfstype=ext4
boot.cmd (complete file attached):
rock@rockpi-4cplus:~$ grep -i console /boot/boot.cmd
if test "${console}" = "display" || test "${console}" = "both"; then setenv consoleargs "console=tty1"; fi
if test "${console}" = "serial" || test "${console}" = "both"; then setenv consoleargs "console=ttyS2,1500000 ${consoleargs}"; fi
if test "${earlycon}" = "on"; then setenv consoleargs "earlycon ${consoleargs}"; fi
        setenv consoleargs "splash plymouth.ignore-serial-consoles ${consoleargs}"
        setenv consoleargs "splash=verbose ${consoleargs}"
setenv bootargs "root=${rootdev} rootwait rootfstype=${rootfstype} ${consoleargs} consoleblank=0 loglevel=${verbosity} ubootpart=${partuuid} usb-storage.quirks=${usbstoragequirks} ${extraargs} ${extraboardargs}"
boot.cmd
It looks like if you set console="display" in armbianEnv.txt then the console kernel param will be set to tty1. This might resolve your problem.
Marked as solution.  To answer my question wider;
The console option, that are not specified in Armbian Documentation are: display
All four options listed below:
console=both
console=serial
console=display
console=none
To disable console entirely (not recommended) set console to none.
Forgive me.
I apparently don't test thoroughly enough.
Now:
rock@rockpi-4cplus:~$ cat /boot/armbianEnv.txt
verbosity=1
bootlogo=true
console=display
rootfstype=ext4
rock@rockpi-4cplus:~$ sudo mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
Image Name:
Created:      Sat Mar  8 18:21:32 2025
Image Type:   ARM Linux Script (uncompressed)
Data Size:    3843 Bytes = 3.75 KiB = 0.00 MiB
Load Address: 00000000
Entry Point:  00000000
Contents:
   Image 0: 3835 Bytes = 3.75 KiB = 0.00 MiB
rock@rockpi-4cplus:~$ sudo reboot
Broadcast message from root@rockpi-4cplus on pts/1 (Sat 2025-03-08 18:22:02 UTC):
The system will reboot now!
Remote side unexpectedly closed network connection
Even so, I can see my communication with Waveshare SIM7020E NB-IoT HAT are interrupted by console login request.
How do I fulfill the disable ttyS2 console?
rock@rockpi-4cplus:~$ sudo picocom /dev/ttyS2
picocom v3.1
Terminal ready
*** local echo: yes ***
*** baud: 115200
*** baud: 115200 ***
AT
AT
OK
rockpi-4cplus login:
Check if getty is running on ttyS2 and stop it:
sudo systemctl stop getty@ttyS2
rock@rockpi-4cplus:~$ picocom /dev/ttyS2 --baud 115200 --echo
picocom v3.1
Terminal ready
AT
AT
OK
ockpi-4cplus login:
ERROR
Terminating...
Thanks for using picocom
rock@rockpi-4cplus:~$ sudo systemctl status getty@ttyS2
○ getty@ttyS2.service - Getty on ttyS2
     Loaded: loaded (/usr/lib/systemd/system/getty@.service; disabled; preset: enabled)
     Active: inactive (dead)
       Docs: man:agetty(8)
             man:systemd-getty-generator(8)
             https://0pointer.de/blog/projects/serial-console.html
For reasons I cannot explain, I see getty@ttyS2 inactive at systemctl.
Still it interrupts the UART.
Also tried this:
[sudo] password for rock:
       Docs: man:agetty(8)
rock@rockpi-4cplus:~$ sudo systemctl stop getty@ttyS2
rock@rockpi-4cplus:~$ sudo systemctl disable getty@ttyS2
       Docs: man:agetty(8)
  • Solution
check the status of serial-getty@ttyS2.service  and disable it.
systemctl status serial-getty@ttyS2.service
systemctl disable serial-getty@ttyS2.service
Also can you please post your kernel command line again to check the console= param:
cat /proc/cmdline
According to the doc (https://0pointer.de/blog/projects/serial-console.html) systemd will spawn a serial getty for the console specified in the kernel command line.
Summary:
  1. /boot/armbianEnv.txt
    console=display
  2. systemctl disable getty@ttyS2
    Maybe not necessary ... ?
  3. systemctl disable serial-getty@ttyS2.service
Thanks everyone :)
