Ian Goodacre Posted Tuesday at 09:45 PM Posted Tuesday at 09:45 PM (edited) I am adding support for a new board: NanoPi R2S Plus. I have added it to the kernel and it works in testing so far. Now I am attempting to add the new board to u-boot. The u-boot configuration for NanoPi R2S does not enable the eMMC and I want to install to boot from eMMC. Using my modified kernel and u-boot for NanoPi R2S I am able to run armbian-install because in the system booted from SD card the eMMC is enabled. But after installing to eMMC, shutting down and removing the SD card, boot fails because u-boot cannot access the eMMC. Looking at the device tree for NanoPi R2S in u-boot, not surprisingly, eMMC is not enabled: NanoPi R2S does not have eMMC memory. So, I am attempting to patch u-boot to add support for the NanoPi R2S Plus board, enabling eMMC and the WAN network adapter, as I did in the kernel. I am attempting to create a patch for u-boot using command: `./compile.sh nanopi-r2s-plus uboot-patch` After a bit I see: ``` [✨] Starting [ interactive patching process for u-boot ] [🌱] Creating commit to start from clean source [🌱] Patches will be created [ with the following maintainer information ] [🌱] MAINTAINER (Real name): [ John Doe ] [🌱] MAINTAINERMAIL (Email): [ john.doe@somewhere.on.planet ] [🌿] If those are not correct, set them in your environment, command line, or config file and restart the process [🚸] Make your changes in this directory: [ /home/ian/ig3/armbian-build/cache/sources/u-boot-worktree/u-boot/v2022.07 ] [🚸] Press <ENTER> after you are done [ editing files in /home/ian/ig3/armbian-build/cache/sources/u-boot-worktree/u-boot/v2022.07 ] Press ENTER to show a preview of your patch, or type 'stop' to stop patching... ``` In a separate window I went to the indicated directory and added two files: configs/nanopi-r2s-plus-rk3328_defconfig arch/arm/dts/rk3328-nanopi-r2s-plus.dts I didn't modify any of the existing files. I returned to the window running compile.sh and pressed the ENTER key and I saw: ``` [🌱] OK, here's how your diff looks like [ showing patch diff ] ───────┬──────────────────────────────────────────────────── │ File: /home/ian/ig3/armbian-build/output/patch/ │ u-boot-rockchip64-current.patch <EMPTY> ───────┴──────────────────────────────────────────────────── [🚸] Are you happy with this patch? [ Type 'yes' to accept, 'stop' to stop patching, or anything else to keep patching ] Are you happy with the diff above? Type 'y' or 'yes' to accept, 'stop' to stop patching, anything else to keep patching: n ``` I was expecting to see a patch that creates the two new files. I presume '<EMPTY>" indicates that no changes were detected. This is the first time I have tried using the uboot-patch command. I may be overlooking something very obvious. I have checked to ensure I created the files in the correct location: ``` ian@armbianbuild:~/ig3/armbian-build/cache/sources/u-boot-worktree/u-boot/v2022.07$ ls -l configs/nanopi-r2s-plus-rk3328_defconfig -rw-r--r-- 1 root root 2617 Mar 4 20:37 configs/nanopi-r2s-plus-rk3328_defconfig ian@armbianbuild:~/ig3/armbian-build/cache/sources/u-boot-worktree/u-boot/v2022.07$ ls -l arch/arm/dts/rk3328-nanopi-r2s-plus.dts -rw-r--r-- 1 root root 943 Mar 4 21:08 arch/arm/dts/rk3328-nanopi-r2s-plus.dts ``` All the existing files are owned by root, so I assume the permissions are OK. Should it handle the creation of new files in the u-boot tree? Or does it only handle changes to existing files? Any suggestions would be appreciated. Edited yesterday at 04:34 AM by Ian Goodacre 0 Quote
Werner Posted yesterday at 04:39 AM Posted yesterday at 04:39 AM Hm indeed there is something wrong. Tested something similar but the patch file was shown empty. Though this used to work in the past. I suggest to report this here https://github.com/armbian/build/issues since this is clearly an framework issue. Edit: Alright, there seems to be a cosmetic bug. New files aren't shown for whatever reason in the patchfile preview. However if you press y to finish up patching the patchfile in the output folder looks just fine. From 0000000000000000000000000000000000000000 Mon Sep 17 00:00:00 2001 From: John Doe <john.doe@somewhere.on.planet> Date: Wed, 5 Mar 2025 05:41:52 +0100 Subject: Patching u-boot rk35xx files arch/arm/dts/rk3328-nanopi-r2s-plus.dts configs/nanopi-r2s-plus-rk3328_defconfig Signed-off-by: John Doe <john.doe@somewhere.on.planet> --- arch/arm/dts/rk3328-nanopi-r2s-plus.dts | 1 + configs/nanopi-r2s-plus-rk3328_defconfig | 1 + 2 files changed, 2 insertions(+) diff --git a/arch/arm/dts/rk3328-nanopi-r2s-plus.dts b/arch/arm/dts/rk3328-nanopi-r2s-plus.dts new file mode 100644 index 00000000000..f33568d63c5 --- /dev/null +++ b/arch/arm/dts/rk3328-nanopi-r2s-plus.dts @@ -0,0 +1 @@ +gzuweggzuerguiwigwegi diff --git a/configs/nanopi-r2s-plus-rk3328_defconfig b/configs/nanopi-r2s-plus-rk3328_defconfig new file mode 100644 index 00000000000..9561b6e6ed7 --- /dev/null +++ b/configs/nanopi-r2s-plus-rk3328_defconfig @@ -0,0 +1 @@ +iuhgiuagiauhigahihgiawugiawugiwu -- Created with Armbian build tools https://github.com/armbian/build 0 Quote
Kwiboo Posted yesterday at 06:07 AM Posted yesterday at 06:07 AM Support for NanoPi R2S Plus was added in U-Boot v2025.01. Suggest you update U-Boot from v2022.07 to v2025.01. 0 Quote
Solution Ian Goodacre Posted yesterday at 06:48 AM Author Solution Posted yesterday at 06:48 AM Reported and updated: the indication of an 'empty' patch is false. Accept it and a non-empty patch file is produced. 0 Quote
Ian Goodacre Posted yesterday at 06:50 AM Author Posted yesterday at 06:50 AM @Kwiboo Thank you very much! I wasn't aware. I'll look into how to update u-boot for my build. There's always something new to learn... 0 Quote
Ian Goodacre Posted yesterday at 08:10 AM Author Posted yesterday at 08:10 AM (edited) So I tried adding "BOOTBRANCH='tag:v2025.01'" to my compile command and I can see that it gets u-boot with that tag but it then attempts to apply all the patches for the platform rockchip64 from patch dir u-boot-rockchip64 and fails because those patches are written against v2022.07 (I assume, because that's the version of u-boot that compile was using before I added BOOTBRANCH and those builds didn't fail). Is there a way I can use the newer version of u-boot for my build without fixing the patches for all the other rockchip64 boards? For a first attempt, I would like to use u-boot v2025.01 as-is, without patches, merely selecting its configuration for nanopi-r2s-plus. I don't want to change what happens for the other boards. My board is NanoPi R2S Plus and, as far as I know, Armbian build framework didn't have configuration specific for this board. I had been using the configuration for NanoPi R2S but now I would like to get the eMMC and WAN network adapter working. These don't work with the NanoPi R2S configuration because of hardware differences: NanoPi R2S doesn't have eMMC and the boards have different chip for the WAN network adapter. I have patched the kernel so both eMMC and WAN port work. Now I would like to enable boot from eMMC which requires changing the device tree in u-boot to enable the eMMC and, while I am at it, I might as well change it to enable the WAN port too. Now that I have a workaround for the uboot-patch problem I could continue developing a patch for u-boot v2022.07 and worry about later versions later but using a more recent u-boot version where it 'just works' seems appealing. But I am not familiar with the Armbian build framework so don't immediately know how to proceed, other than to keep learning how the build framework works. Edit: I just found config/boards/README.md - a wealth of information, and also BOOTPATCHDIR in many board configurations, which I expect will allow me to resolve the failing patches with v2025.01. Edited yesterday at 08:59 AM by Ian Goodacre 0 Quote
Ian Goodacre Posted 14 hours ago Author Posted 14 hours ago I have build completing with u-boot v2025.01. I can't test at the moment but building without errors is close and now I can add patches easily enough. The essential parameters were `BOOTBRANCH="tag:v2025.01"` and `BOOTPATCHDIR="v2025.01"`. Not documented at [Build Switches](https://docs.armbian.com/Developer-Guide_Build-Switches/) but there are many examples in config/boards. 0 Quote
Ian Goodacre Posted 4 hours ago Author Posted 4 hours ago I have tested my latest build. It boots from SD card. I ran armbian-install to install the system to boot from eMMC with system on a USB drive, shut down, removed the SD card and applied power, and it booted up, proving that u-boot now has access to the eMMC. I haven't proven that the WAN network port works from u-boot. It isn't a priority for me but based on the change I made working in the kernel, I am optimistic that the device tree is correct. So, success at last: I have modified the device tree for u-boot for nanopi-r2s-plus. Actually, I didn't edit the device tree for u-boot in any way, I just changed the board to use a more recent version of u-boot that has native support for NanoPi R2S Plus and proved that eMMC access works from e-boot. Thanks to Werner and Kwiboo. 0 Quote
Werner Posted 2 hours ago Posted 2 hours ago 11 hours ago, Ian Goodacre said: . Not documented at [Build Switches] Probably because they are not intended to be used as build switches but in board configuration file 0 Quote
