philippe perquin Posted March 7, 2025 Posted March 7, 2025 (edited) Hi, it seem that Armbian_community_25.5.0-trunk.185_Orangepi5-max build break the HDMI output, in gnome and bookworm. I try to boot the two with SD card. existing sytem that make an apt upgrade, the 185 also seem to broke all the system. regards, Edited March 7, 2025 by philippe perquin 0 Quote
mando Posted March 7, 2025 Posted March 7, 2025 I also can't get gnome or bookworm to boot with Mar 6 releases 0 Quote
SuperKali Posted March 7, 2025 Posted March 7, 2025 Could you please share your dmesg log? Which kernel version are you using? Please provide some information to help us understand the issue. 0 Quote
philippe perquin Posted March 8, 2025 Author Posted March 8, 2025 it's the version from download link seem to 6.12. i can't give you log, from card no acces and updated version from ssd will stay on error now. regards, 0 Quote
Erez Alster Posted March 9, 2025 Posted March 9, 2025 Are you able to boot your sbc? I'm getting constant green light. there is nothing to see in the UART. Previous images with kernel 6.1.99 are working correctly. Any idea? 0 Quote
mando Posted March 18, 2025 Posted March 18, 2025 Quick update New builds dated 17th March don't work either. Exactly the same problem - no boot. All I get is a flashing blue light. The February build works fine - no wifi - but at least it boots 0 Quote
mando Posted April 7, 2025 Posted April 7, 2025 Ubuntu and Debian versions dated 3rd April work fine until updated, then wifi disappears 0 Quote
Glibbr Posted April 9, 2025 Posted April 9, 2025 (edited) I can confirm that 25.5.0-trunk.256 and following work but all trunks after 256 (301 and 334) break WiFi and BT. Edited April 9, 2025 by Glibbr 0 Quote
mando Posted April 20, 2025 Posted April 20, 2025 Apr15th Ubuntu and Debian versions still behaving the same way - wifi works fine until updates then disappears 0 Quote
philippe perquin Posted May 12, 2025 Author Posted May 12, 2025 there is annoucement for a better support in, but they not give the build : 0 Quote
Werner Posted May 12, 2025 Posted May 12, 2025 26 minutes ago, philippe perquin said: but they not give the build https://docs.armbian.com/User-Guide_FAQ/#why-is-there-no-image-for-board-with-bookwormjammynobletrixie-and-minimalclignomekdexfce-with-vendorlegacycurrentedge-kernel 0 Quote
Werner Posted May 16, 2025 Posted May 16, 2025 5 minutes ago, mando said: May 15 versions not booting No logs - no issue. https://debug.armbian.de 0 Quote
mando Posted May 21, 2025 Posted May 21, 2025 How do I get a log if the OS won't evenstart to boot? 0 Quote
SteeMan Posted May 21, 2025 Posted May 21, 2025 47 minutes ago, mando said: How do I get a log if the OS won't evenstart to boot? As long as the board isn't dead it is starting to boot. That is why Werner directed you to how to capture the uboot booting messages via a uart connection to the board. 1 Quote
mando Posted May 23, 2025 Posted May 23, 2025 Apologies. Didn't realise that. I have no means of connecting to uart - I'll want until a bootable version shows up. 0 Quote
